Custom board issue
We just received our custom board based nRF52832, below nRF52832 schematic image description
I succeed to flash the board. but i have frequency troubles. I made a simple exemple to verify this:
#define TIMEOUT_VALUE                    10                           /**< 10 microsecond timer time-out value. */
#define PIN_OUT 12
void timeout_handler(void * p_context)
        nrf_drv_gpiote_out_toggle(PIN_OUT);
	  ret_code_t err_code;
    nrf_drv_gpiote_out_config_t out_config = GPIOTE_CONFIG_OUT_SIMPLE(false);
    err_code = nrf_drv_gpiote_out_init(PIN_OUT, &out_config);
    err_code = app_simple_timer_init();
		err_code = app_simple_timer_start(APP_SIMPLE_TIMER_MODE_REPEATED,
													 timeout_handler,
													 TIMEOUT_VALUE,
													 NULL);
    for (;;)
When i run this example over Nordic DevKit PCA10040, i get a square wave with period of 20us. when i run the same example over our custom board, i get a square wave with period of ~17us.
Any idea of the cause of this trouble ? please.
Best regards.
  • FormerMember
    0 FormerMember
    sd_softdevice_enable(..) will hang if there is a problem with the low frequency clock source. Could you try to configure the lfclk with the example from the S13x migration document, and check if it works?
    // Example configuration equivalent to the old NRF_CLOCK_LFCLKSRC_RC_250_PPM_TEMP_1000MS_CALIBRATION:
    nrf_clock_lf_cfg_t rc_cfg = {
    .source = NRF_CLOCK_LF_SRC_RC,
    .rc_ctiv = 4, // Check temperature every 4 * 250ms
    .rc_temp_ctiv = 1, // Only calibrate if temperature has changed.
  • FormerMember
    0 FormerMember
