ZMS Storage limitations
Hi there, I am developing a bluetooth application and would like to have some on board temperature logging as well. I am using ZMS to do this, with an 8 byte struct. I notice that this means every temperature record uses 1 ATE which is 16 Bytes, It seems somewhat wasteful to use half of the storage space I have as an overhead for ZMS. Is there a more space efficient solution to do this ?
I am also interested in increasing the partition space but there are these image slots that are using up the rest of the space (device tree portion pasted below). Do you know if I can take over these if I want to use OTA FW update in the future ?
        /* node '/soc/rram-controller@5004b000' defined in zephyr\dts\vendor\nordic\nrf54l_05_10_15.dtsi:732 */
                rram_controller: rram-controller@5004b000 {
                        compatible = "nordic,rram-controller"; /* in zephyr\dts\vendor\nordic\nrf54l_05_10_15.dtsi:733 */
                        reg = < 0x5004b000 0x1000 >;           /* in zephyr\dts\vendor\nordic\nrf54l_05_10_15.dtsi:734 */
                        #address-cells = < 0x1 >;              /* in zephyr\dts\vendor\nordic\nrf54l_05_10_15.dtsi:735 */
                        #size-cells = < 0x1 >;                 /* in zephyr\dts\vendor\nordic\nrf54l_05_10_15.dtsi:736 */
                        interrupts = < 0x4b 0x1 >;             /* in zephyr\dts\vendor\nordic\nrf54l_05_10_15.dtsi:737 */
                        /* node '/soc/rram-controller@5004b000/rram@0' defined in zephyr\dts\vendor\nordic\nrf54l_05_10_15.dtsi:739 */
                        cpuapp_rram: rram@0 {
                                compatible = "soc-nv-flash";   /* in zephyr\dts\vendor\nordic\nrf54l_05_10_15.dtsi:740 */
                                erase-block-size = < 0x1000 >; /* in zephyr\dts\vendor\nordic\nrf54l_05_10_15.dtsi:741 */
                                write-block-size = < 0x10 >;   /* in zephyr\dts\vendor\nordic\nrf54l_05_10_15.dtsi:742 */
                                reg = < 0x0 0x165000 >;        /* in zephyr\dts\vendor\nordic\nrf54l15.dtsi:28 */
                                /* node '/soc/rram-controller@5004b000/rram@0/partitions' defined in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:23 */
                                partitions {
                                        compatible = "fixed-partitions"; /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:24 */
                                        #address-cells = < 0x1 >;        /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:25 */
                                        #size-cells = < 0x1 >;           /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:26 */
                                        /* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@0' defined in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:27 */
                                        boot_partition: partition@0 {
                                                label = "mcuboot";     /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:28 */
                                                reg = < 0x0 0x10000 >; /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:29 */
                                        /* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@10000' defined in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:31 */
                                        slot0_partition: partition@10000 {
                                                label = "image-0";         /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:32 */
                                                reg = < 0x10000 0x51000 >; /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:33 */
                                        /* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@61000' defined in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:35 */
                                        slot0_ns_partition: partition@61000 {
                                                label = "image-0-nonsecure"; /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:36 */
                                                reg = < 0x61000 0x51000 >;   /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:37 */
                                        /* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@b2000' defined in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:39 */
                                        slot1_partition: partition@b2000 {
                                                label = "image-1";         /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:40 */
                                                reg = < 0xb2000 0x51000 >; /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:41 */
                                        /* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@103000' defined in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:43 */
                                        slot1_ns_partition: partition@103000 {
                                                label = "image-1-nonsecure"; /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:44 */
                                                reg = < 0x103000 0x51000 >;  /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:45 */
                                        /* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@15c000' defined in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:48 */
                                        storage_partition: partition@15c000 {
                                                label = "storage";         /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:49 */
                                                reg = < 0x15c000 0x9000 >; /* in nrf54l15-connectkit\boards\makerdiary\nrf54l15_connectkit\nrf54l15_connectkit_nrf54l15_cpuapp.dts:50 */
                                        /* node '/soc/rram-controller@5004b000/rram@0/partitions/partition@154000' defined in nrf54l15-connectkit\mesh_bt\boards\nrf54l15_connectkit_nrf54l15_cpuapp.overlay:142 */
                                        temp_log_partition: partition@154000 {
                                                label = "temp_log";        /* in nrf54l15-connectkit\mesh_bt\boards\nrf54l15_connectkit_nrf54l15_cpuapp.overlay:143 */
                                                reg = < 0x154000 0x8000 >; /* in nrf54l15-connectkit\mesh_bt\boards\nrf54l15_connectkit_nrf54l15_cpuapp.overlay:144 */
    If I understood your situation correctly, you want to use ZMS as a FIFO. I would then recommend you to not go with ZMS, but instead go with FCB (Flash Circular Buffer) directly. You can also see this recommendation in the docs here.
    If you want OTA capabilities you want to keep all these partitions. It is possible to resize them but if you want to do that, there are quite a few requirements in order for it to work (especially alignment constrains). You can find the doc here.
    However, I see that you added the "temp_log" partition. But you should put that partition inside the storage partition. You can see the documentation about it here.
    Simon
    Thanks for your answer. For a different application that still needs to store data in non volatile storage i need to know what is the maximum size I can give to the partition. OTA is not a consideration for this one. Could you please point me to an example project to help with this.
    Thanks.
    I think you can try to follow this video (link) we made.
    As you don't want the OTA you probably don't want the bootloader too, which mean you can remove the "boot" and "slot1" partitions.
    And then you can create / extend the partition to suit your needs.
    If you want more help on this can you maybe be a bit more precise on what you exactly want to achieve ?
    Simon
