how to see logs from mcuboot while bootinng of nrf5340
Hi aiswarya.
Use Sysbuild approach, add this config setting in (sysbuild/mcuboot.conf)
CONFIG_LOG=y
CONFIG_MCUBOOT_LOG_LEVEL_INF=y
CONFIG_CONSOLE=y
CONFIG_UART_CONSOLE=y
CONFIG_SERIAL=y
Thanks and regards
Nishant
Hi Aiswarya,
I can see that your question has been answered in this case. But just to confirm, you can set these options in your configuration file for ex. sysbuild/mcuboot.conf:
CONFIG_LOG=y
So, first the MCUboot logs need to be enabled in your project. Then, in serial terminal, you can see your COM or serial port and connect. After this, you can reset the board and the MCUboot messages should be visible in the terminal.
For viewing the logs, I would also recommend you to take a look at the following:
DFU over UART DevAcademy Exercise
Getting logging output with nRF5340 DK documentation
Please let us know if you have any further questions.
Best Regards,
Samruddhi
This works.. Thanks:)
Thiis works . Thanks:)
That's great! I will close this case for now.
Please feel free to reach out if you have any further questions.
Best Regards,
Samruddhi
