nRF93M1 HTTP client fails to download HTTPS file from GitHub with %HTTP ERROR: 19
Description
I am trying to use the native HTTP/HTTPS AT commands of the nRF93M1 to
download a firmware image for an external host MCU.
Hardware and software
- Development kit: nRF93M1 DK, PCA10232 revision 0.4.0
- nRF93M1 modem firmware: mfw_nrf93m1_1.4.1
- Host MCU application: nRF Connect SDK v3.3.0
- Zephyr OS: v4.3.99
- UART communication between the host MCU and nRF93M1
- LTE Cat 1 bis registration and PDP context activation succeed
- The HTTP operation is performed before CMUX and PPP are enabled
Firmware URL
raw.githubusercontent.com/.../fw.bin
File information
SHA-256:
ffc547b5edb80e57ff84144a7b28aa171bc228de6697dfd093badaa4cf35c5bd
The URL works correctly from a PC and returns:
HTTP/1.1 200 OK
Content-Length: 353964
Content-Type: application/octet-stream
Accept-Ranges: bytes
Steps to reproduce
The modem is placed in flight mode first, the SIM is checked, and then LTE
is enabled:
AT+CFUN=4
AT+CPIN?
AT+CEREG=5
AT+CGEREP=1
AT+CFUN=1
Network registration and PDP context activation are successful:
+CGEV: ME PDN ACT 1
+CEREG: 1,"32C9","04A7C920",7
AT+CGPADDR=1
+CGPADDR: 1,"6.224.170.255"
OK
The SSL and HTTP contexts are configured as follows:
AT%SSLCFG="seclevel",0,0
OK
AT%SSLCFG="sni",0,1
OK
AT%HTTPCFG="sslctxid",0
OK
AT%HTTPCFG="contextid",1
OK
The URL length is 66 bytes:
AT%HTTPURL=66,60
CONNECT
OK
A range request for the first 1024 bytes is then started:
AT%HTTPGETEX=0,1024
OK
When reading the HTTP response, the modem returns SSL error 19:
AT%HTTPREAD
%HTTP ERROR: 19
Complete relevant log
nRF93 > AT+CGMR
nRF93 < mfw_nrf93m1_1.4.1
nRF93 < OK
nRF93 > AT+CFUN=4
nRF93 < OK
Waiting 2000 ms for flight mode...
nRF93 > AT+CPIN?
nRF93 < +CPIN: READY
nRF93 < OK
nRF93 > AT+CGSN=1
nRF93 < +CGSN: "<IMEI>"
nRF93 < OK
nRF93 > AT+CEREG=5
nRF93 < OK
nRF93 > AT+CGEREP=1
nRF93 < OK
nRF93 > AT+CFUN=1
nRF93 < OK
nRF93 < +CEREG: 2
nRF93 < +CGEV: ME PDN ACT 1
nRF93 < +CEREG: 1,"32C9","04A7C920",7
nRF93 > AT+CGPADDR=1
nRF93 < +CGPADDR: 1,"6.224.170.255"
nRF93 < OK
nRF93 > AT%SSLCFG="seclevel",0,0
nRF93 < OK
nRF93 > AT%SSLCFG="sni",0,1
nRF93 < OK
nRF93 > AT%HTTPCFG="sslctxid",0
nRF93 < OK
nRF93 > AT%HTTPCFG="contextid",1
nRF93 < OK
nRF93 > AT%HTTPURL=66,60
nRF93 < CONNECT
nRF93 < OK
nRF93 > AT%HTTPGETEX=0,1024
nRF93 < OK
nRF93 > AT%HTTPREAD
nRF93 < %HTTP ERROR: 19
Details in the attached file.
Firmware URL
https://raw.githubusercontent.com/kietpt2704/fota_test/main/fw.bin
File information
SHA-256:
HTTP/1.1 200 OK
Steps to reproduce
is enabled:
AT+CFUN=4
AT+CPIN?
AT+CEREG=5
AT+CGEREP=1
AT+CFUN=1
+CGEV: ME PDN ACT 1
AT+CGPADDR=1
OK
OK
AT%SSLCFG="sni",0,1
OK
OK
OK
AT%HTTPURL=66,60
CONNECT
OK
AT%HTTPGETEX=0,1024
OK
AT%HTTPREAD
%HTTP ERROR: 19
nRF93 > AT+CGMR
nRF93 < OK
nRF93 > AT+CFUN=4
nRF93 < OK
nRF93 > AT+CPIN?
nRF93 < OK
nRF93 > AT+CGSN=1
nRF93 < OK
nRF93 > AT+CEREG=5
nRF93 < OK
nRF93 > AT+CGEREP=1
nRF93 < OK
nRF93 > AT+CFUN=1
nRF93 < OK
nRF93 < +CEREG: 2
nRF93 < OK
nRF93 < OK
nRF93 < OK
nRF93 < OK
nRF93 < OK
nRF93 < CONNECT
nRF93 < OK
nRF93 < OK
nRF93 > AT%HTTPREAD
Alternative tests
I also tested the following sequence:
AT%HTTPGET
OK
AT%HTTPREADFILE="fw.bin"
%HTTP ERROR: 19
The result was the same.
I tested both SSL context 0 and SSL context 1. The SSL context 1
configuration was:
AT%SSLCFG="seclevel",1,0
AT%SSLCFG="sni",1,1
AT%HTTPCFG="sslctxid",1
Both contexts produced %HTTP ERROR: 19.
Cipher compatibility observation
According to the nRF93M1 Cellular AT Commands v0.9 manual, the documented
configurable cipher suites are:
0xC0AD - TLS_ECDHE_ECDSA_WITH_AES_256_CCM
0xC09F - TLS_DHE_RSA_WITH_AES_256_CCM
I tested both cipher suites against raw.githubusercontent.com using OpenSSL:
openssl s_client -connect raw.githubusercontent.com:443 \
  -servername raw.githubusercontent.com \
  -tls1_2 \
  -cipher ECDHE-ECDSA-AES256-CCM
and:
  -tls1_2 \
  -cipher DHE-RSA-AES256-CCM
Both tests were rejected by the server with:
ssl/tls alert handshake failure
SSL alert number 40
This suggests that %HTTP ERROR: 19 may be caused by the lack of a mutually
supported TLS cipher suite. However, I would like Nordic to confirm whether
this is the actual limitation or whether additional SSL configuration is
required.
Questions
1. Is raw.githubusercontent.com compatible with the native HTTPS client in
   mfw_nrf93m1_1.4.1?
2. Does modem firmware 1.4.1 support additional TLS cipher suites that are
   not listed in the AT command manual?
3. Is the command sequence %HTTPGETEX followed by %HTTPREAD correct?
4. Is there any way to obtain more detailed information about
   %HTTP ERROR: 19?
5. Is there a newer nRF93M1 modem firmware with broader TLS cipher-suite
   support?
6. Can the native HTTP client follow an HTTP 301/302 redirect from HTTP to
   HTTPS?
7. For host-MCU FOTA, is using an HTTP port 80 server currently the only
   practical solution when the HTTPS server does not support the modem's CCM
   cipher suites?
Reference
nRF93M1 Cellular AT Commands v0.9:
https://www.nordicsemi.com/-/media/Software-and-other-downloads/Product-Briefs/nrf93m1_cellular_at_commands_v0.9.pdf
    I will try to see if I can reproduce. Do you have a modem trace also?
  • Hello. I have already sent the log in the attachment.  no longer have the latest logs.
  • Hello Håkon,
    Yes. I connected USB2, the dedicated nRF93M1 trace connection, and captured
    the raw modem trace while reproducing the issue.
    Setup:
    - nRF93M1 DK PCA10232 rev 0.4.0
    - Modem firmware: mfw_nrf93m1_1.4.1
    - Trace interface: USB2 / COM9
    - Trace baud rate: 3,000,000
    - logCtrl=2
    - logLevel=0
    - logPortSel=2
    The HTTPS failure was reproduced as follows:
    AT%HTTPGETEX=0,1024
    OK
    AT%HTTPREAD
    %HTTP ERROR: 19
    I have attached:
    - nrf93m1_mfw_1.4.1_https_error19_trace.bin
    - nrf93m1_mfw_1.4.1_https_error19_at_log.txtnrf93m1_mfw_1.4.1_https_error19_trace.bin
    HOST > AT+CEREG?
    AT+CEREG?
    +CEREG: 0,1
    OK
    HOST > AT%SSLCFG="seclevel",0,0
    OK
    HOST > AT%SSLCFG="sni",0,1
    AT%SSLCFG="sni",0,1
    OK
    HOST > AT%HTTPCFG="sslctxid",0
    OK
    HOST > AT%HTTPCFG="contextid",1
    OK
    HOST > AT%HTTPURL=66,60
    AT%HTTPURL=66,60
    CONNECT
    OK
    HOST > AT%HTTPGETEX=0,1024
    AT%HTTPGETEX=0,1024
    OK
    HOST > AT%HTTPREAD
    AT%HTTPREAD
    %HTTP ERROR: 19
  • I managed to fix it myself.
    [00:00:04.872,457] <inf> main: Requesting raw.githubusercontent.com/.../fw.bin
    [00:00:04.934,304] <inf> downloader: Setting up TLS credentials, sec tag count 1
    [00:00:04.940,945] <inf> downloader: Connecting to 185.199.109.133
    [00:01:18.949,494] <inf> main: 353964 / 353964 bytes (100%), 38 kbit/s
    [00:01:18.949,500] <inf> downloader: Download complete
    [00:01:18.951,939] <inf> main: 353964 / 353964 bytes (100%), 38 kbit/s
    [00:01:18.951,964] <inf> main: Download complete
    [00:01:18.951,968] <inf> main: bytes : 353964
    [00:01:18.951,971] <inf> main: duration : 72670 ms
    [00:01:18.951,976] <inf> main: throughput : 38 kbit/s
    [00:01:18.951,979] <inf> main: CRC-32 : 0x410c982a
