nRF91, RAI with PPP
Hello
We are developing a new product using the nRF54LM20 as a main MCU and nRF9151 as the modem. We are looking into using the IP-stack in the main MCU, so running the modem in CMUX/PPP mode using the serial modem application provided by you (https://github.com/nrfconnect/ncs-serial-modem).
I have a few questions regarding this:
  1. To my understanding, the only API for RAI is the socket option API (nrf_setsockopt exposed via #XSOCKETOPT). This makes it impossible to use RAI in combination with PPP since there are no sockets on the modem, right?
    1. The modem aggregates the RAI statuses from all sockets and determines what to do (request release from network or not). In principle, it should be possible to let the user do its own aggregation and signal if more data is expected or not to the modem, via for example an AT-command. Do you have any plans to extend the RAI functionality so RAI can be used in combination with CMUX/PPP?
  2. Are there any other reasons why we should avoid using the CMUX/PPP approach?
Best regards
Mattias
  • Hello Mattias,
    RAI is currently not supported for the PPP socket, and there are no plans on the roadmap to enable this functionality. To date, this is the first request we have received for this feature.
    It's hard to assess this without additional context. The original decision to use PPP was likely driven by specific technical or application requirements. Understanding what the solution is trying to achieve, along with the protocols and architecture involved, would help us provide a more informed recommendation.
    Øyvind
  • Thanks for your reply.
    I would very much like the RAI feature when using PPP, otherwise using PPP gives a power disadvantage. Consider this a feature request. But if this is the first time anyone has requested it I guess it will not get too much attention or priority..
    My question was to see if you know of any other modem features (in particular low-power features) that can't be used if we use PPP (just like RAI). But I guess not. RAI is the one I found.
    Best regards
    Mattias
  • Hi Mattias
    Thanks for adding this feature request. I have forwarded it to our team working with the Serial Modem. It might not be top priority right away, but they are working to provide features customers ask about.
    If you do have any further questions, please do not hesitate to add them here.
    Øyvind
  • Related
