Have tried several times to install the SDK into VS code without success. This is one of the errors I am getting:
We are still stuck. No progress.
Sorry for the delay, your case slipped through.
Have you managed to install VS code successfully on on your system. I se you are using widiws II and have NCS v3.4 installed. I hope the installation was successful and you have got NCS up and running now.
To install Edge AI extension, you first need to create an Edge AI account on our webpage. Once you have logged in, you can then go to >> Create a new application in the welcome tab, then you will see the following options
The edge ai add-on falls under NRF SDK add on index- you select that and search for edge AI
Please let me know if this fasttracks your progress. Please get back to us if you have more questiosn on how to use the samples or create models on edge AI webpage. Also curious, are you planning to run your models on neuton (arm cortex m33) or Axon - our specialised NPU accelerator on nRF54LM20B?
Regards
Pallavi
