NCS 3.4.0 - Thingy91X - PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY magic
Using McuBoot without external flash seems to work not anymore.
According nrf/sysbuild/Kconfig.sysbuild:
config PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY
depends on the deprecated PARTITION_MANAGER. But for unknown reasons, it seems to be still there. Even in a pretty magic way.
I removed (for test only) from that Kconfig.sysbuild and from all Kconfig of that board.
But building it, it still shows
# NCS subsystem configurations
CONFIG_PM_EXTERNAL_FLASH_HAS_DRIVER=y
CONFIG_PM_EXTERNAL_FLASH_BASE=0
CONFIG_PM_EXTERNAL_FLASH_ENABLED=y
CONFIG_PM_EXTERNAL_FLASH_PATH="/soc/peripheral@40000000/spi@b000/GD25LE255E@0"
CONFIG_PM_EXTERNAL_FLASH_SIZE_BITS=268435456
CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=y
# CONFIG_PM_OVERRIDE_EXTERNAL_DRIVER_CHECK is not set
CONFIG_PM_SRAM_BASE=0x20000000
CONFIG_PM_SRAM_SIZE=0x40000
# end of Partition Manager
in .config.
In the past it was important to disable PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY, but even
SB_CONFIG_PARTITION_MANAGER=n
SB_CONFIG_PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY=n
in sysbuild.conf seems not to work.
Therefore I tried to test it by removing the PM_EXTERNAL_FLASH_MCUBOOT_SECONDARY from Kconfig and so my surprise, that it's still there, is pretty large.
(I removed the build folder, so it's no leftover.)
