Hello everyone.
Absolute novice here but a lot of reading over the last few days has brought me here.
I'm currently watching a little robotic project being developed. After a lot of investigation, I am confident that it contains the following :-
Nordic nRF52832 MCU
DMHC4035LSD H-Bridge
N20 Micro DC Motors Brushed DC x2
QL 701530 Lithium-Polymer cell (3.00 mAh, 3.7V nominal, 1.11 Wh energy output capacity). The robot has been programmed to automatically dock when low charge or when the app is closed or innactive (for xx time).
It's a whiny little beast, not loud but annoying. To get a rough guesstimate, I recorded the audio and ran it through an app and it indicated it was operating at approximately 1khz (with harmonics at 3khz and 5khz). For its intended purpose, this noise will be very distracting, especially when there are multiple robots operating simultaneously.
Everything I have read so far indicates that increasing the pwm to 12khz and higher (16-18 seems to be a sweetspot) will have a net-positive impact on the components and performance but, most importantly, a definite audible improvement for the end user. These devices will never be in continuous use, it will be along the lines of
idle (variable from a few seconds to several minutes/drive (2-3 sec max)/idle.. repeat...
With a maximum powered up duration of, say 6 hours per day but NEVER continuously active (in other words, in 6 hours there may be 10 games played with an average of 30 driving activations per game but the idle times can and will be highly variable).
In layman's terms, what are your thoughts?
I know it's a very open question but, firstly, am I correct in thinking that these components could handle the pwm increase?
Or could the increase be catastrophic? (Gemini Ai says "no" ).
Any and all thoughts and suggestions are very much appreciated (every day is a learning day).
Thank you.
