Does the nRF54L15 support Direction Finding (AoA/AoD) and Channel Sounding together — i.e., can both features run on this specific chip, either simultaneously or at all?
I've seen Nordic staff confirm in other threads that AoA/AoD is "not supported" on the nRF54L series (e.g. case ID 343792), while Channel Sounding is supported. Can you confirm:
1. Does the nRF54L15 support AoA/AoD at all, currently or planned?
2. Does it support Channel Sounding? If yes, which NCS version/sample should I use to evaluate it?
3. If AoA/AoD is added in a future update, could it run alongside Channel Sounding on this same chip, or would the two be mutually exclusive on this silicon?
4. In the "AOA and AOD on nrf54L15" thread, a user mentioned they were able to add a CTE to advertising packets on the nRF54L15 (by adapting the direction_finding_connectionless_tx sample under NCS 3.1.1), and suggested this makes AoA work on this chip. Can you confirm whether this is genuinely functional, and if so, whether it would be reliable/accurate enough for practical AoA use, or if this is not officially supported/validated?
