Online Power Profiler for BLE: Transmission duration in connection
I have a question regarding the transmission duration in the Online Power Profiler for BLE (OPP). More precisely, it is about the transmission duration during a connection in the peripheral mode.
Settings:
  "chip": "2",
  "voltage": "3",
  "dcdc": "on",
  "lf_clock": "lfxo",
  "radio_tx": "0",
  "ble_type": "con",
  "ble_int": "100",
  "tx_size": "0",
  "rx_size": "0",
  "phy": "2mbps",
  "slave_latency": "0",
  "central_ppm": "20",
  "peripheral_ppm": "20"
In my understanding, the size and transmission duration an empty BLE packet is
  1. LE 1M PHY
    • 10 byte: 1 byte preamble + 4 byte access address + 2 byte PDU + 3 byte CRC
    • --> 80 µs transmission duration = 10 byte * 8 bit / byte / (10^6 bit / s)
  2. LE 2M PHY
    • 11 byte: 2 byte preamble + 4 byte access address + 2 byte PDU + 3 byte CRC
    • --> 44 µs transmission duration = 11 byte * 8 bit / byte / (2 * 10^6 bit / s)
However, I measure a transmission duration of 128 µs for both the LE 1M PHY and the LE 2M PHY in the OPP. Moreover, increasing the payload by 1 byte increases the transmission duration by 8 µs on the LE 2M PHY, whereas it should be 4 µs.
This results in a transmission duration of 336 µs for 26 byte payload (128 µs + 26 * 8 µs). Now, when the payload is increased by 1 byte to 27 (without packet length extension), the transmission duration decreases to 148 µs. This almost aligns with the theoretical value (44 µs + 27 byte * 4 µs / byte = 152 µs).
Could you please verify if there is a bug?
Thank you!
