Hie,
Can you please confirm if your config is correct nrfutil sdk-manager config show
It should show China.
Another customer here was able to solev the issue by using the following commands
curl -O https://files.nordicsemi.cn/artifactory/NCS/external/bundles/v3/ncs-toolchain-x86_64-linux-43683a87ea.tar.gznrfutil toolchain-manager install --toolchain-bundle ncs-toolchain-x86_64-linux-43683a87ea.tar.gzPlease let me know if this solves your issue or we will investigate it further.
Looking forward to your response.
Regards
Pallavi
问题的关键在于 我根本curl不通,C:\Users\24981>curl -O files.nordicsemi.cn/.../ncs-toolchain-x86_64-linux-43683a87ea.tar.gz
curl: (28) Failed to connect to files.nordicsemi.cn:443 after 21050 ms: Could not connect to server。我明明就在上海,也没有开代理。
Hie,
Let us try to force the nrfutil to bypass the china server and pull you on the golbal server.
Can you please follow this steps and check if it works:
1. nrfutil config set sdk-manager.url https://files.nordicsemi.com/artifactory/ncs-src-mirror/external/sdk-manager/index.json
2. Verify the config change was saved correctly : nrfutil config get sdk-manager.url
3. Clear out any corrupted or half-downloaded index files left behind by the failed connection : nrfutil sdk-manager clean
4. Verify connection and retry operation nrfutil sdk-manager search
Please let me know if this works.
BR
Pallavi
我当然知道这个方法并且已经通过国际源下载了,但是那速度巨慢。我发布这个求助帖子是想让官方给我一个中国源不行的原因并解决,而不是让我去换个方法。
Hie,
It was a server issue which was fixed about an hour ago. The things should be up and running.
Also, can you please reply in English as it is in the nordic policy.
Regards
Pallavi
