Two upstream Zephyr networking fixes missing from the NCS zephyr pin — which release?
[Corrected 2026-09-11] This post originally attributed an MPU fault to the missing 7c4ea9a9d5. That was wrong — backporting it did not stop the fault, which looks like a separate Zephyr upstream defect that I will continue to look into. The request below, for the two missing commits (7c4ea9a9d5 and 67ed7813), is unaffected.
--- Original post ---
Setup: nRF54LM20-DK as host, W5500 Ethernet over SPI in MACRAW mode. Our tree is sdk-nrf af15896d9e, pinning zephyr 0e25e661.
Under sustained load (1 MB HTTP GET every 17 s, plus background broadcast/multicast traffic) our board takes an MPU fault in the eth_w5500 thread and halts:
<err> os: ***** MPU FAULT ***** Data Access Violation MMFAR Address: 0x2649
<err> os: Current thread: 0x20000388 (eth_w5500)
<err> os: Halting system
It survived 151 cycles / 47 minutes before faulting.
The cause is drivers/ethernet/eth_w5500.c missing upstream 7c4ea9a9d5 — "drivers: eth: w5500: reject header <= 2 before length subtraction", merged in Zephyr main on 2026-06-16.
That commit describes the mechanism we hit: "A value of 0, 1, or 2 underflows the uint16_t, causing an extremely large allocation followed by a NULL fragment dereference."
Backporting just that guard fixes it. The identical test now runs 182 minutes / 569 cycles with no fault, through 18 load spikes, where it previously crashed at 47 minutes.
While checking, a second fix is also absent from the zephyr revision sdk-nrf main currently pins (62923172, 2026-09-07): 67ed7813 / PR 109758 — "net: ip: icmpv6: drop errors for
mcast/unspecified sources", merged 2026-07-20. That one is already on ncs-v3.4-branch but not on main.
Which NCS release will these land in? We can carry local patches until then, we just need to know how long.
    Those 2 fixes will be available in NCS 3.5.0, but no promised release schedule.
    As you noticed, the ICMP fix is already in the ncs-v3.4 branch and will be part of NCS v3.4.1. I don't think the other patch qualifies for backporting given it was not backported upstream, and we're supposed to stay as close to the upstream v4.4 branch as possible. On main,  it'll be available after the next upmerge, not ETA yet though
    If urgent/high-priority, we could prepare a cherry-pick PR for main, but as you claim you can carry cherry-pick patches on their own, I'm not sure there's much sense in it.
    Amanda H.
  • Thanks — that answers both.
    No need for the cherry-pick. 7c4ea9a9d5 bounds the MACRAW header only from below, and our fault came from an oversized one (16920). Upstream main has no upper bound either, so the crash survives the upmerge: net_pkt_alloc_buffer clamps the allocation to MTU + header, while the copy loop still runs on the unclamped length and walks past the end of the buffer chain. We carry a local guard, so no urgency our side.
