Product / environment
- SoC: nRF52840
- Current field firmware: nRF Connect SDK v2.4.1 (ZBOSS/Zigbee from that release)
- Target firmware: nRF Connect SDK v3.4.0 with the Zigbee R23 add-on (ncs-zigbee)
- Device role: Zigbee Router (mains-powered), with ZCL attribute reporting configured
- Update mechanism in the field: Zigbee OTA
Background
We are migrating our deployed product from NCS v2.4.1 to v3.4.0, which also bumps the ZBOSS stack (to the R23 add-on). The update will be delivered to field devices over Zigbee FOTA.
While preparing this migration we identified two known issues that appear relevant to our case, both listed in your documentation:
1. KRKNWK-19894 — DFU from NCS v2.5.x or older to v2.6.0+ preserves NVRAM whose `ZB_NVRAM_ZCL_REPORTING_DATA` structure is incompatible with the new firmware, causing corrupted (empty) attribute reporting and, in some cluster configurations, a fatal error on every boot. Our devices come from v2.4.1 and use ZCL reporting, so we expect to hit this.
2. NCSISB-1204 — an interrupted NVRAM write (e.g. power loss during a write) leaves a corrupted record that makes ZBOSS raise a fatal error on boot, resulting in a permanent boot loop / brick.
We understand the documented workaround for KRKNWK-19894 is to erase the NVRAM (fully, or specifically the `ZB_NVRAM_ZCL_REPORTING_DATA` dataset) after the upgrade, at the cost of losing configuration and requiring re-commissioning.
Questions
1. Recommended migration procedure: What is Nordic's recommended way to migrate a fielded Zigbee device from NCS v2.4.1 (old ZBOSS) to v3.4.0 with the R23 add-on, when the update is delivered over Zigbee FOTA? Is there an officially recommended sequence or reference we should follow for this specific stack transition?
2. Mitigating the known issues: Beyond a full/targeted NVRAM erase, is there any recommended way to mitigate KRKNWK-19894 and NCSISB-1204 for our scenario? For NCSISB-1204, the documentation says to request a fixing patch from DevZone — could you confirm whether a fix is already included in the v3.4.0 / R23 ZBOSS binaries, or whether a separate patch is still required?
3. Preserving network membership (avoiding NVRAM erase): Is there a procedure that would allow the device to remain joined to the Zigbee network across this migration — i.e. migrate or convert the existing NVRAM content to the new layout rather than erasing it — so that end users are not forced to re-commission? If any form of NVRAM migration/conversion is feasible, we would prefer that over a wipe.
4. Rollback / downgrade support: Is it possible to support rollback to the previous firmware version (v2.4.1-based) after this migration? Our concern is that once the NVRAM has been written by the new (R23) stack, an older image reading that NVRAM may hit the same layout incompatibility. Is there a supported way to make a downgrade safe?
Note: for safety reasons we cannot confirm the new image in advance. The update must remain revertible, so the new image runs tentatively and can be rolled back if it fails to come up.
Any guidance, reference material, or a fixing patch for the above would be greatly appreciated.
Thank you in advance
