LPN Friendship Communication
I have a few questions regarding ble mesh lpn and friend nodes.
Let's call
Node A (A node that can become a friend node)
Node B (A node that can become an low power node)
Are these scenarios correct. This is what I am observing
Node B has set "bt_mesh_lpn_set"
I am still able to send a message "bt_mesh_model_send", however the acknowledgement is always missed if there is no friend. Always returning -116 on the bt_mesh_send_cb end function.
Node A has established friendship with Node B. However Node B has lost friendship and has not successfully notified node A.
Node A still thinks it is friends with node B. "bt_mesh_model_send" will always fail as it is adding to a friend queue for a node that is no longer friends.
Is there a way of manually triggering a new friend request? lpn_poll only works if friendship has already been established.
Another thing I have noticed is that my coms are as follows
LPN sets data to the Friend via a vendor model of 80 - 100 bytes
Friend receives the data and sends back a vendor model message of 8-12 bytes.
Friend Message is queued and sent on the next friend poll.
More often than not, When the lpn sends data to the friend, it loses friendship
Parents Reply
  • After looking into this a bit closer, I realise that we should do some more investigations about your system.
    What are the configurations for Nodes A and B? I'm thinking specifically about the friend timeout value. You could i.e. send your generated .config files for the two nodes with the Insert->Code option in a reply.
    Do you know why the LPN loses its friendship with Node A? Knowing why the friendship is lost from the LPN's perspective should shed some light on how to modify the nodes to keep friendships more reliably.
    Do you have control over the FW on both nodes?
    Are both nodes running on Nordic HW?
    Maria
