nfc_t2t_setup returns -1
I'm evaluating the nrf54l15dk and am trying to make a small application where nrf54 appears as a tag. Upon initialization the `nfc_t2t_setup` returns -1 which does not appear in the documentation.  Another thing is that vscode says that `nfc_t2t_lib.h` can't be located and all the `NFC_T2T_EVENT_...` also the code, however compiles just fine
I'm using nRF Connect SDK v3.4.0-99553055607b
prj.con contains
CONFIG_TFM_SECURE_UART=n
CONFIG_TFM_LOG_LEVEL_SILENCE=y
CONFIG_LOG=y
CONFIG_SPI=y
CONFIG_NFC_T2T_NRFXLIB=y
CONFIG_NFC_NDEF=y
CONFIG_NFC_NDEF_MSG=y
CONFIG_NFC_NDEF_RECORD=y
CONFIG_NFC_NDEF_TEXT_RECORD=y
  • Hi Anton
    The -1 error code points to the call not being permitted/possible, so it sounds like something isn't enabled correctly here. Do you have the log of the build and can upload that. Also, the build output .config file so we can see what has actually been set when the application is built?
    If you're having trouble I'd recommend trying one of the NFC samples as is on the DK to confirm that other samples work as intended.
    Simon
  • Hi Simon,
    I've loaded `record_text` nfc sample, upon running it returns, generated .config attached
    SB_CONFIG_BOARD="nrf54l15dk"
    SB_CONFIG_BOARD_REVISION=""
    SB_CONFIG_BOARD_NRF54L15DK=y
    SB_CONFIG_BOARD_NRF54L15DK_NRF54L15_CPUAPP_NS=y
    SB_CONFIG_BOARD_QUALIFIERS="nrf54l15/cpuapp/ns"
    SB_CONFIG_SOC="nrf54l15"
    SB_CONFIG_SOC_SERIES="nrf54l"
    SB_CONFIG_SOC_FAMILY="nordic_nrf"
    SB_CONFIG_SOC_FAMILY_NORDIC_NRF=y
    SB_CONFIG_SOC_SERIES_NRF54L=y
    SB_CONFIG_SOC_NRF54L15=y
    SB_CONFIG_SOC_NRF54L15_CPUAPP=y
    # Sysbuild image configuration
    SB_CONFIG_RA_SECOND_CORE_LAUNCHER_NAME="cm85"
    # Modules
    # Available modules.
    # nrf (/home/anton/ncs/v3.4.0/nrf)
    # SB_CONFIG_PARTITION_MANAGER is not set
    SB_CONFIG_BUILD_OUTPUT_BIN=y
    SB_CONFIG_BUILD_OUTPUT_HEX=y
    SB_CONFIG_BOARD_IS_NON_SECURE=y
    SB_CONFIG_APPCORE_REMOTE_BOARD_TARGET_CPUCLUSTER="cpuapp"
    SB_CONFIG_APPCORE_REMOTE_DOMAIN="CPUAPP"
    SB_CONFIG_SUPPORT_FLPRCORE=y
    SB_CONFIG_FLPRCORE_REMOTE_BOARD_TARGET_CPUCLUSTER="cpuflpr"
    # Fast lightweight peripheral processor core (FLPR) configuration
    SB_CONFIG_SUPPORT_FLPRCORE_EMPTY=y
    SB_CONFIG_FLPRCORE_NONE=y
    # SB_CONFIG_FLPRCORE_EMPTY is not set
    # SB_CONFIG_HPF is not set
    # end of Fast lightweight peripheral processor core (FLPR) configuration
    # Secure Bootloader
    # SB_CONFIG_SECURE_BOOT_APPCORE is not set
    # end of Secure Bootloader
    # Bluetooth Fair Pair
    SB_CONFIG_BT_FAST_PAIR_MODEL_ID=0x1000000
    SB_CONFIG_BT_FAST_PAIR_ANTI_SPOOFING_PRIVATE_KEY=""
    # end of Bluetooth Fair Pair
    # SB_CONFIG_MATTER is not set
    # Wi-Fi
    # SB_CONFIG_WIFI_NRF70 is not set
    # end of Wi-Fi
    # SB_CONFIG_APPROTECT_DISABLE is not set
    # SB_CONFIG_APPROTECT_LOCK is not set
    # SB_CONFIG_APPROTECT_USER_HANDLING is not set
    SB_CONFIG_APPROTECT_NO_SYSBUILD=y
    # SB_CONFIG_SECURE_APPROTECT_DISABLE is not set
    # SB_CONFIG_SECURE_APPROTECT_LOCK is not set
    # SB_CONFIG_SECURE_APPROTECT_USER_HANDLING is not set
    SB_CONFIG_SECURE_APPROTECT_NO_SYSBUILD=y
    SB_CONFIG_SUPPORT_CRACEN=y
    SB_CONFIG_SUPPORT_CRACEN_MICROCODE=y
    # CRACEN
    # end of CRACEN
    # TF-M
    # SB_CONFIG_TFM_OTP_PSA_CERTIFICATE_REFERENCE is not set
    # end of TF-M
    SB_CONFIG_SUPPORT_FIRMWARE_LOADER_BLE_MCUMGR=y
    # SB_CONFIG_CRACEN_KMU_INVALIDATE_PROTECTED_RAM_SLOTS is not set
    SB_CONFIG_ZEPHYR_NRF_MODULE=y
    # end of nrf (/home/anton/ncs/v3.4.0/nrf)
    SB_CONFIG_ZEPHYR_MCUBOOT_MODULE=y
    SB_CONFIG_ZEPHYR_QCBOR_MODULE=y
    SB_CONFIG_ZEPHYR_T_COSE_MODULE=y
    SB_CONFIG_ZEPHYR_MBEDTLS_MODULE=y
    SB_CONFIG_ZEPHYR_OBERON_PSA_CRYPTO_MODULE=y
    SB_CONFIG_ZEPHYR_TRUSTED_FIRMWARE_M_MODULE=y
    SB_CONFIG_ZEPHYR_PSA_ARCH_TESTS_MODULE=y
    SB_CONFIG_ZEPHYR_CJSON_MODULE=y
    SB_CONFIG_ZEPHYR_AZURE_SDK_FOR_C_MODULE=y
    SB_CONFIG_ZEPHYR_CIRRUS_LOGIC_MODULE=y
    SB_CONFIG_ZEPHYR_OPENTHREAD_MODULE=y
    SB_CONFIG_ZEPHYR_NRF_WIFI_MODULE=y
    SB_CONFIG_ZEPHYR_MEMFAULT_FIRMWARE_SDK_MODULE=y
    SB_CONFIG_ZEPHYR_COREMARK_MODULE=y
    SB_CONFIG_ZEPHYR_HOSTAP_MODULE=y
    SB_CONFIG_ZEPHYR_CANOPENNODE_MODULE=y
    SB_CONFIG_ZEPHYR_CHRE_MODULE=y
    SB_CONFIG_ZEPHYR_CMSIS_MODULE=y
    SB_CONFIG_ZEPHYR_CMSIS_DSP_MODULE=y
    SB_CONFIG_ZEPHYR_CMSIS_NN_MODULE=y
    SB_CONFIG_ZEPHYR_CMSIS_6_MODULE=y
    SB_CONFIG_ZEPHYR_DHARA_MODULE=y
    SB_CONFIG_ZEPHYR_FATFS_MODULE=y
    SB_CONFIG_ZEPHYR_HAL_NORDIC_MODULE=y
    SB_CONFIG_ZEPHYR_HAL_ST_MODULE=y
    SB_CONFIG_ZEPHYR_HAL_TDK_MODULE=y
    SB_CONFIG_ZEPHYR_HAL_WURTHELEKTRONIK_MODULE=y
    SB_CONFIG_ZEPHYR_LIBLC3_MODULE=y
    SB_CONFIG_ZEPHYR_LIBMETAL_MODULE=y
    SB_CONFIG_ZEPHYR_LIBSBC_MODULE=y
    SB_CONFIG_ZEPHYR_LITTLEFS_MODULE=y
    SB_CONFIG_ZEPHYR_LORAMAC_NODE_MODULE=y
    SB_CONFIG_ZEPHYR_LVGL_MODULE=y
    SB_CONFIG_ZEPHYR_MIPI_SYS_T_MODULE=y
    SB_CONFIG_ZEPHYR_MLDSA_NATIVE_MODULE=y
    SB_CONFIG_ZEPHYR_NANOPB_MODULE=y
    SB_CONFIG_ZEPHYR_OPEN_AMP_MODULE=y
    SB_CONFIG_ZEPHYR_PERCEPIO_MODULE=y
    SB_CONFIG_ZEPHYR_PICOLIBC_MODULE=y
    SB_CONFIG_ZEPHYR_SEGGER_MODULE=y
    SB_CONFIG_ZEPHYR_TF_M_TESTS_MODULE=y
    SB_CONFIG_ZEPHYR_TF_PSA_CRYPTO_MODULE=y
    SB_CONFIG_ZEPHYR_UOSCORE_UEDHOC_MODULE=y
    SB_CONFIG_ZEPHYR_ZCBOR_MODULE=y
    SB_CONFIG_ZEPHYR_NRFXLIB_MODULE=y
    SB_CONFIG_ZEPHYR_NRF_HW_MODELS_MODULE=y
    SB_CONFIG_ZEPHYR_CONNECTEDHOMEIP_MODULE=y
    # Unavailable modules, please install those via the project manifest.
    # end of Modules
    # SB_CONFIG_WARN_EXPERIMENTAL is not set
    SB_CONFIG_WARN_DEPRECATED=y
    SB_CONFIG_SUPPORT_BOOTLOADER=y
    SB_CONFIG_SUPPORT_BOOTLOADER_MCUBOOT_ZEPHYR=y
    SB_CONFIG_BOOTLOADER_NONE=y
    # SB_CONFIG_BOOTLOADER_MCUBOOT is not set
    SB_CONFIG_SUPPORT_FIRMWARE_LOADER_SMP_SVR=y
    # Build options
    # SB_CONFIG_COMPILER_WARNINGS_AS_ERRORS is not set
    # SB_CONFIG_MERGED_HEX_FILES is not set
    # end of Build options
    *** Booting nRF Connect SDK v3.4.0-99553055607b ***
    *** Using Zephyr OS v4.4.0-bf801e4e3d19 ***
    Starting NFC Text Record sample
    Cannot setup NFC T2T library!
    record_text-config.cfg
    Config file for my application also attached below and build output
     *  Executing task: nRF Connect: Build [pristine]: sample-application/build
    Building sample-application
    west build --build-dir /home/anton/nrf/sample-application/build /home/anton/nrf/sample-application --pristine --board nrf54l15dk/nrf54l15/cpuapp/ns -- -DEXTRA_DTC_OVERLAY_FILE=nrf54l15dk_nrf54l15_cpuapp_ns.overlay -DDEBUG_THREAD_INFO=On -DCONFIG_DEBUG_THREAD_INFO=y -Dsample-application_DEBUG_THREAD_INFO=On
    Loading Zephyr module(s) (Zephyr base): sysbuild_default
    -- Found Python3: /home/anton/ncs/toolchains/fbf7391cab/usr/local/bin/python3.12 (found suitable version "3.12.4", minimum required is "3.12") found components: Interpreter
    -- Cache files will be written to: /home/anton/.cache/zephyr
    -- Found west (found suitable version "1.5.0", minimum required is "0.14.0")
    -- Board: nrf54l15dk, qualifiers: nrf54l15/cpuapp/ns
    Parsing /home/anton/ncs/v3.4.0/zephyr/share/sysbuild/Kconfig
    Loaded configuration '/home/anton/nrf/sample-application/build/_sysbuild/empty.conf'
    Merged configuration '/home/anton/nrf/sample-application/build/_sysbuild/empty.conf'
    Configuration saved to '/home/anton/nrf/sample-application/build/zephyr/.config'
    Kconfig header saved to '/home/anton/nrf/sample-application/build/_sysbuild/autoconf.h'
       * Running CMake for sample-application *
    -- Application: /home/anton/nrf/sample-application
    -- CMake version: 4.2.1
    -- Zephyr version: 4.4.0 (/home/anton/ncs/v3.4.0/zephyr)
    -- Found host-tools: zephyr 1.0.1 (/home/anton/ncs/toolchains/fbf7391cab/opt/zephyr-sdk)
    -- Found toolchain: zephyr 1.0.1 (/home/anton/ncs/toolchains/fbf7391cab/opt/zephyr-sdk)
    -- Found Dtc: /home/anton/ncs/toolchains/fbf7391cab/usr/bin/dtc (found suitable version "1.5.0", minimum required is "1.4.6")
    -- Found BOARD.dts: /home/anton/ncs/v3.4.0/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp_ns.dts
    -- Found devicetree overlay: /home/anton/nrf/sample-application/nrf54l15dk_nrf54l15_cpuapp_ns.overlay
    -- Found devicetree overlay: nrf54l15dk_nrf54l15_cpuapp_ns.overlay
    -- Generated zephyr.dts: /home/anton/nrf/sample-application/build/sample-application/zephyr/zephyr.dts
    -- Generated pickled edt: /home/anton/nrf/sample-application/build/sample-application/zephyr/edt.pickle
    -- Generated devicetree_generated.h: /home/anton/nrf/sample-application/build/sample-application/zephyr/include/generated/zephyr/devicetree_generated.h
    warning: Deprecated symbol NRF_PLATFORM_LUMOS is enabled.
    warning: Experimental symbol TFM_EXPERIMENTAL is enabled.
    Parsing /home/anton/ncs/v3.4.0/zephyr/Kconfig
    Loaded configuration '/home/anton/ncs/v3.4.0/zephyr/boards/nordic/nrf54l15dk/nrf54l15dk_nrf54l15_cpuapp_ns_defconfig'
    Merged configuration '/home/anton/nrf/sample-application/prj.conf'
    Merged configuration '/home/anton/nrf/sample-application/build/sample-application/zephyr/misc/generated/extra_kconfig_options.conf'
    Merged configuration '/home/anton/nrf/sample-application/build/sample-application/zephyr/.config.sysbuild'
    Configuration saved to '/home/anton/nrf/sample-application/build/sample-application/zephyr/.config'
    Kconfig header saved to '/home/anton/nrf/sample-application/build/sample-application/zephyr/include/generated/zephyr/autoconf.h'
    -- Found GnuLd: /home/anton/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/arm-zephyr-eabi/bin/ld.bfd (found version "2.43.1")
    -- The C compiler identification is GNU 14.3.0
    -- The CXX compiler identification is GNU 14.3.0
    -- Found assembler: /home/anton/ncs/toolchains/fbf7391cab/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc
    -- Found Python3: /home/anton/ncs/toolchains/fbf7391cab/usr/local/bin/python3.12 (found version "3.12.4") found components: Interpreter
    -- Could NOT find Threads (missing: Threads_FOUND)
    -- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS
    -- Performing Test C_COMPILER_SUPPORTS_WFORMAT_SIGNEDNESS - Success
    -- Using ccache: /home/anton/ncs/toolchains/fbf7391cab/usr/bin/ccache
    -- Found gen_kobject_list: /home/anton/ncs/v3.4.0/zephyr/scripts/build/gen_kobject_list.py
    -- Configuring done (4.1s)
    -- Generating done (0.2s)
    -- Build files have been written to: /home/anton/nrf/sample-application/build/sample-application
    -- Configuring done (6.0s)
    -- Generating done (0.0s)
    [1/283] Preparing syscall dependency handling
    [5/283] Generating include/generated/zephyr/version.h
    -- Zephyr version: 4.4.0 (/home/anton/ncs/v3.4.0/zephyr), build: ncs-v3.4.0
    [12/283] Generating ../../tfm/CMakeCache.txt
    -- Found Git: /home/anton/ncs/toolchains/fbf7391cab/usr/local/bin/git (found version "2.52.0")
    CMake Warning (dev) at /home/anton/ncs/v3.4.0/nrf/modules/trusted-firmware-m/tfm_boards/nrf54l15_cpuapp/CMakeLists.txt:37 (install):
      Policy CMP0177 is not set: install() DESTINATION paths are normalized.  Run
      "cmake --help-policy CMP0177" for policy details.  Use the cmake_policy
      command to set the policy and suppress this warning.
    This warning is for project developers.  Use -Wno-dev to suppress it.
    -- Configuring done (0.5s)
    CMake Warning:
      Manually-specified variables were not used by the project:
        QCBOR_PATH
        TFM_CREATE_SIGNING_LAYOUT_OBJECTS
        T_COSE_PATH
    -- Build files have been written to: /home/anton/nrf/sample-application/build/sample-application/tfm
    [241/243] Linking C executable bin/tfm_s.axf
               FLASH:       70532 B       512 KB     13.45%
                 RAM:       47772 B       128 KB     36.45%
    [19/283] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    ----- Installing platform NS -----
    [283/283] Linking C executable zephyr/zephyr.elf
               FLASH:       48644 B       940 KB      5.05%
                 RAM:       11696 B       128 KB      8.92%
            IDT_LIST:           0 B        32 KB      0.00%
    Generating files from /home/anton/nrf/sample-application/build/sample-application/zephyr/zephyr.elf for board: nrf54l15dk/nrf54l15/cpuapp/ns
    [8/8] Completed 'sample-application'
    # Modules
    # Secure Bootloader
    # Wi-Fi
    # end of Wi-Fi
    # CRACEN
    # end of CRACEN
    # TF-M
    # end of TF-M
    # end of Modules
    # Build options
  • Hi Anton
    I've reproduced this on my end, and it seems to be a bug with TF-M and NFC on the nRF54L15, as it does not occur on nRF5340.
    If you build the application with the nrf54l15dk/nrf54l15/cpuapp instead of the /ns target, the application works just fine. I'll open an internal investigation on the /ns target and can keep you up to date on what we find.
    Thank you for the thorough report on your end.
    Simon
