Central connection attempt times out the peripheral connection
We have an nRF5340 device that maintains a peripheral connection to a central device and then makes several of its own central connections to other peripherals.  We ran into a strange issue where this device attempted to form a central connection, but after 1 second (CONFIG_BT_CREATE_CONN_TIMEOUT) a connection failure was reported with reason 0x02 (BT_HCI_ERR_UNKNOWN_CONN_ID).  Three seconds later (4 seconds after the initial connection attempt which is our supervisor timeout), we got notified that our peripheral connection disconnected with reason 0x08 (BT_HCI_ERR_CONN_TIMEOUT).  The central device also reported the reason as 0x08 (BT_HCI_ERR_CONN_TIMEOUT).  After this timeout, the device was able to advertise and regain its peripheral connection quickly.  There were no radio errors reported in the log.
Each time we see this issue, it happens with the same pattern: a central connection is requested, is unsuccessful and then the peripheral connection times out.  It does not happen with every connection attempt.  Sometimes it happens quickly and other times it can take 30min to reproduce it.
Since we are not actively trying to close the connection we think the issue must be lower in the radio code.  One item we wanted to double check was the behavior of the CLOCK_CONTROL_NRF_ACCURACY_PPM setting.  As I understand it, this setting is used to determine the sleep time and receive window for peripheral connections  For a device that just connects to a central it is easy to visualize the impact.  However, for a device that also behaves as a central while maintaining a peripheral connection it is harder to understand the impact of this setting and how it is used by the scheduler?  Can you shed some light on that?  Could an incorrect PPM setting result in the behavior we are seeing?
Most crystals have a 20ppm accuracy at 25C, but then lose accuracy considerably at temperature up to 150ppm.  Should we be using the nominal accuracy for the PPM configuration, or should we be taking into account the worst case ppm over temperature and with crystal aging?
Thanks.
    Just to clarify:
    These two connections, when you say central and peripheral. Are these two different connections from the same device? First, the central connection fails to establish with BT_HCI_ERR_UNKNOWN_CONN_ID, and then 3 seconds later, another connection from that same device, where the nRF53 is the peripheral times out? Or is the peripheral connection in this context the other device that the central tried to connect to?
    I know you said that this was not easy to reproduce. Is it possible for me to reproduce it on a DK?
    Perhaps it reproduces easier if you turn down the TX power of the peripheral device that the central tries to connect to in the first place?
    What NCS version are you using when you are seeing this?
    Edvin
  • Hi Edvin,
    These are two distinct connections.  First the nRF5340 in question forms acts as the peripheral in a connection to another nRF5340.  This peripheral connection can be active for 30 minutes or more without problems and with the same device making and unmaking multiple new central connections.  Then later it attempts again to create a connection to an nRF52840 but fails.
    We have not tried to reproduce this on dev kits yet.  To me this seems very timing dependent because generally it takes quite a while to reproduce but sometimes it happens almost immediately.  I will look at setting up a test that just continually makes central connections while a peripheral connection is active to see if that aids in reproduction.
    We are using NCS 2.6.6.
  • An incorrect CLOCK_CONTROL_NRF_ACCURACY_PPM can definitely lead to the behavior of the peripheral connection being disconnected due to timeout. This is if you miss enough connection intervals. With an incorrect PPM, you can miss the connection intervals because the window was widened enough.
    Setting the accuracy to the expected values over your use case should reduce the missed connection intervals, but it does have some trade offs. See this section of the DevAcademy:
    https://academy.nordicsemi.com/courses/designing-low-power-bluetooth-le-products/lessons/lesson-5-soc-specific-power-optimization-i/topic/clock-sources/#accuracy
    Mariano
  • I noticed that the app core code was set to 20PPM and the net core code was set to 50PPM.  Are both of these values used or just the one in the net core code?
    I bumped them both to 150PPM, which matches what we expect over our full operating temperature range, and initial testing looks promising, but more testing is needed.
  • Only the net core one is used for controlling the window widening. I can't find anywhere in the code of the app core where the value is used.
    Mariano
