Which n Value (3, 4, or 5) Should Be Used for nRF54L15 Bluetooth Qualification Intermodulation Testing?
Hello Nordic team,
I have a question regarding the Bluetooth LE RF-PHY Intermodulation Characteristics test (Bluetooth Core Specification Vol. 6, Part A, Section 4.4).
The specification states that for the intermodulation test, n can be 3, 4, or 5, and compliance with at least one of these alternatives is required.
While reviewing the nRF54L15 Product Specification, I found the RX intermodulation performance specification listed as "5th offset channel" for both 1 Mbps and 2 Mbps operation. This appears to correspond to the n = 5 condition defined in the Bluetooth Core Specification.
We are currently preparing Bluetooth SIG qualification for an nRF54L15-based product, and the test lab has asked us which n value should be used for the Intermodulation Characteristics test.
Could you please clarify the following?
1. Does the "5th offset channel" specification correspond to n = 5 as defined in Bluetooth Core Specification Vol. 6, Part A, Section 4.4?
2. Which n value (3, 4, or 5) was used for Nordic's Bluetooth SIG qualification testing of the nRF54L15?
3. If Nordic qualification data is referenced or reused, should the same n value be used for our Bluetooth SIG qualification testing?
Thank you for your support.
    Yes. The nRF54L15 Product Specification's "5th offset channel" parameters correspond directly to the n = 5 alternative defined in Bluetooth Core Specification.
    Nordic characterizes and qualifies RX intermodulation performance using n = 5 for both 1 Mbps and 2 Mbps operation. This is consistent with the parameter naming in the Product Specification and with Nordic qualification practice on other nRF5-series devices (e.g. nRF5340).
    Since Bluetooth Core Spec only requires passing one of the three alternatives (n = 3, 4, or 5) , and different data rates may even use different alternatives , your test lab is not obligated to match Nordic's choice exactly. That said, if you are inheriting or referencing Nordic qualification data/QDID for the RF-PHY layer (unmodified RF front end), using n = 5 keeps your results consistent with the characterized data in the Product Specification and avoids any ambiguity.
    Thank you for the detailed explanation and clarification.
    This answers our question regarding the Intermodulation Characteristics test and confirms that the "5th offset channel" specification corresponds to n = 5. It is also very helpful to understand Nordic's qualification approach and the recommendation when referencing Nordic qualification data.
    We appreciate your support and the additional background information.
