UniqueID attribute of the Basic Information Cluster is empty
In some cases, the UniqueID attribute of the Basic Information Cluster is empty (no value is set).
CONFIG_CHIP_LAST_FABRIC_REMOVED_ERASE_ONLY is enabled.
Environment:
- Board: nRF5340 DK
- SDK: NCS v2.9.2
- Sample: Door Lock
- prj.conf: CONFIG_CHIP_LAST_FABRIC_REMOVED_ERASE_ONLY=y
Steps to Reproduce:
1. Perform commissioning.
2. Perform decommissioning (remove the fabric).
3. Perform re-commissioning.
4. Read the UniqueID attribute from the Basic Information Cluster.
$ chip-tool basicinformation read unique-id 2 0
[1790241304.713] [467304:467304] [DL] ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_tool_kvs
[1790241304.715] [467304:467304] [DL] ChipLinuxStorage::Init: Attempt to re-initialize with KVS config file: /tmp/chip_kvs, IGNORING.
[1790241304.720] [467304:467304] [DL] ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_factory.ini
[1790241304.720] [467304:467304] [DL] ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_config.ini
[1790241304.720] [467304:467304] [DL] ChipLinuxStorage::Init: Using KVS config file: /tmp/chip_counters.ini
[1790241304.726] [467304:467304] [DL] Wrote settings to /tmp/chip_counters.ini
[1790241304.726] [467304:467304] [DL] NVS set: chip-counters/reboot-count = 3 (0x3)
[1790241304.727] [467304:467304] [DL] Got Ethernet interface: eth0
[1790241304.727] [467304:467304] [DL] Found the primary Ethernet interface:eth0
[1790241304.728] [467304:467304] [DL] Got WiFi interface: wlan0
[1790241304.731] [467304:467304] [DL] Found the primary WiFi interface:wlan0
[1790241304.731] [467304:467304] [PAF] WiFiPAF: WiFiPAFLayer::Init()
[1790241304.731] [467304:467304] [IN] UDP::Init bind&listen port=0
[1790241304.731] [467304:467304] [IN] UDP::Init bound to port=51880
[1790241304.731] [467304:467304] [IN] BLEBase::Init - setting/overriding transport
[1790241304.731] [467304:467304] [IN] WiFiPAFBase::Init - setting/overriding transport
[1790241304.731] [467304:467304] [IN] TransportMgr initialized
[1790241304.731] [467304:467304] [FP] Initializing FabricTable from persistent storage
[1790241304.732] [467304:467304] [TS] Last Known Good Time: 2023-10-14T01:16:48
[1790241304.734] [467304:467304] [FP] Fabric index 0x1 was retrieved from storage. Compressed FabricId 0x4FC239DB662DA104, FabricId 0x0000000000000001, NodeId 0x000000000001B669, VendorId 0xFFF1
[1790241304.737] [467304:467304] [DMG] Ember attribute persistence requires setting up
[1790241304.737] [467304:467304] [ZCL] Using ZAP configuration...
[1790241304.743] [467304:467304] [DL] Avahi client registered
[1790241304.743] [467304:467304] [CTL] System State Initialized...
[1790241304.743] [467304:467304] [CTL] Setting attestation nonce to random value
[1790241304.743] [467304:467304] [CTL] Setting CSR nonce to random value
[1790241304.743] [467304:467304] [IN] UDP::Init bind&listen port=5550
[1790241304.743] [467304:467304] [IN] UDP::Init bound to port=5550
[1790241304.743] [467304:467304] [IN] TransportMgr initialized
[1790241304.744] [467304:467306] [DL] CHIP task running
[1790241304.744] [467304:467306] [DL] HandlePlatformSpecificBLEEvent 32786
[1790241304.745] [467304:467306] [CTL] Setting attestation nonce to random value
[1790241304.745] [467304:467306] [CTL] Setting CSR nonce to random value
[1790241304.746] [467304:467306] [CTL] Generating NOC
[1790241304.747] [467304:467306] [FP] Validating NOC chain
[1790241304.749] [467304:467306] [FP] NOC chain validation successful
[1790241304.750] [467304:467306] [FP] Updated fabric at index: 0x1, Node ID: 0x000000000001B669
[1790241304.750] [467304:467306] [TS] Last Known Good Time: 2023-10-14T01:16:48
[1790241304.750] [467304:467306] [TS] New proposed Last Known Good Time: 2021-01-01T00:00:00
[1790241304.750] [467304:467306] [TS] Retaining current Last Known Good Time
[1790241304.758] [467304:467306] [FP] Metadata for Fabric 0x1 persisted to storage.
[1790241304.762] [467304:467306] [TS] Committing Last Known Good Time to storage: 2023-10-14T01:16:48
[1790241304.764] [467304:467306] [CTL] Joined the fabric at index 1. Fabric ID is 0x0000000000000001 (Compressed Fabric ID: 4FC239DB662DA104)
[1790241304.764] [467304:467306] [IN] UDP::Init bind&listen port=5551
[1790241304.764] [467304:467306] [IN] UDP::Init bound to port=5551
[1790241304.764] [467304:467306] [IN] TransportMgr initialized
[1790241304.780] [467304:467306] [TOO] Sending command to node 0x2
[1790241304.781] [467304:467306] [CSM] FindOrEstablishSession: PeerId = [1:0000000000000002]
[1790241304.781] [467304:467306] [CSM] FindOrEstablishSession: No existing OperationalSessionSetup instance found
[1790241304.781] [467304:467306] [DIS] OperationalSessionSetup[1:0000000000000002]: State change 1 --> 2
[1790241304.781] [467304:467306] [DIS] Resolving 4FC239DB662DA104:0000000000000002 ...
[1790241304.782] [467304:467306] [DIS] Lookup started for 4FC239DB662DA104-0000000000000002
[1790241304.783] [467304:467306] [DL] Avahi resolve found
[1790241304.783] [467304:467306] [DIS] Node ID resolved for 4FC239DB662DA104-0000000000000002
[1790241304.783] [467304:467306] [DIS] 	Hostname: F691A7A78058A837
[1790241304.783] [467304:467306] [DIS] 	IP Address #1: fd11:25::fcbb:fd84:b83f:2815
[1790241304.783] [467304:467306] [DIS] 	Port: 5540
[1790241304.784] [467304:467306] [DIS] 	Mrp Interval idle: 3000 ms
[1790241304.784] [467304:467306] [DIS] 	Mrp Interval active: 2200 ms
[1790241304.784] [467304:467306] [DIS] 	Mrp Active Threshold: 300 ms
[1790241304.784] [467304:467306] [DIS] 	TCP Client Supported: 0
[1790241304.784] [467304:467306] [DIS] 	TCP Server Supported: 0
[1790241304.784] [467304:467306] [DIS] 	ICD: not present
[1790241304.784] [467304:467306] [DIS] Lookup clearing interface for non LL address
[1790241304.785] [467304:467306] [DIS] UDP:[fd11:25::fcbb:fd84:b83f:2815%veth5875779]:5540: new best score: 5 (for 4FC239DB662DA104-0000000000000002)
[1790241304.785] [467304:467306] [DIS] Checking node lookup status for 4FC239DB662DA104-0000000000000002 after 3 ms
[1790241304.785] [467304:467306] [DIS] Keeping DNSSD lookup active
[1790241304.982] [467304:467306] [DIS] Checking node lookup status for 4FC239DB662DA104-0000000000000002 after 201 ms
[1790241304.982] [467304:467306] [DIS] OperationalSessionSetup[1:0000000000000002]: Updating device address to UDP:[fd11:25::fcbb:fd84:b83f:2815]:5540 while in state 2
[1790241304.983] [467304:467306] [DIS] OperationalSessionSetup[1:0000000000000002]: State change 2 --> 3
[1790241304.983] [467304:467306] [IN] SecureSession[0xffff8c00bb30]: Allocated Type:2 LSID:33639
[1790241304.983] [467304:467306] [SC] Initiating session on local FabricIndex 1 from 0x000000000001B669 -> 0x0000000000000002
[1790241304.985] [467304:467306] [EM] <<< [E:8739i S:0 M:92132059] (U) Msg TX from 1179AA5E57D2C7F0 to 0:0000000000000000 [0000] [UDP:[fd11:25::fcbb:fd84:b83f:2815]:5540] --- Type 0000:30 (SecureChannel:CASE_
[1790241304.986] [467304:467306] [EM] ??1 [E:8739i S:0 M:92132059] (U) Msg Retransmission to 0:0000000000000000 scheduled for 3359ms from now [State:Idle II:3000 AI:2200 AT:300]
[1790241304.986] [467304:467306] [SC] Sent Sigma1 msg to <0000000000000002, 1> [II:500ms AI:300ms AT:4000ms]
[1790241304.986] [467304:467306] [DIS] OperationalSessionSetup[1:0000000000000002]: State change 3 --> 4
[1790241305.536] [467304:467306] [EM] >>> [E:8739i S:0 M:47193904 (Ack:92132059)] (U) Msg RX from 0:0000000000000000 [0000] to 1179AA5E57D2C7F0 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
[1790241305.536] [467304:467306] [EM] Found matching exchange: 8739i, Delegate: 0xffff8c00b848
[1790241305.536] [467304:467306] [EM] Rxd Ack; Removing MessageCounter:92132059 from Retrans Table on exchange 8739i
[1790241305.758] [467304:467306] [EM] >>> [E:8739i S:0 M:47193905 (Ack:92132059)] (U) Msg RX from 0:0000000000000000 [0000] to 1179AA5E57D2C7F0 --- Type 0000:31 (SecureChannel:CASE_Sigma2) (B:751)
[1790241305.758] [467304:467306] [EM] Found matching exchange: 8739i, Delegate: 0xffff8c00b848
[1790241305.758] [467304:467306] [EM] CHIP MessageCounter:92132059 not in RetransTable on exchange 8739i
[1790241305.758] [467304:467306] [SC] Received Sigma2 msg
[1790241305.758] [467304:467306] [SC] Found MRP parameters in the message
[1790241305.769] [467304:467306] [SC] Peer <0000000000000002, 1> assigned session ID 6213
[1790241305.769] [467304:467306] [SC] Sending Sigma3
[1790241305.770] [467304:467306] [EM] <<< [E:8739i S:0 M:92132060 (Ack:47193905)] (U) Msg TX from 1179AA5E57D2C7F0 to 0:0000000000000000 [0000] [UDP:[fd11:25::fcbb:fd84:b83f:2815]:5540] --- Type 0000:32 (Secu
[1790241305.770] [467304:467306] [EM] ??1 [E:8739i S:0 M:92132060] (U) Msg Retransmission to 0:0000000000000000 scheduled for 2614ms from now [State:Active II:3000 AI:2200 AT:300]
[1790241305.770] [467304:467306] [SC] Sent Sigma3 msg
[1790241306.236] [467304:467306] [EM] >>> [E:8739i S:0 M:47193906 (Ack:92132060)] (U) Msg RX from 0:0000000000000000 [0000] to 1179AA5E57D2C7F0 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
[1790241306.237] [467304:467306] [EM] Found matching exchange: 8739i, Delegate: 0xffff8c00b848
[1790241306.237] [467304:467306] [EM] Rxd Ack; Removing MessageCounter:92132060 from Retrans Table on exchange 8739i
[1790241306.448] [467304:467306] [EM] >>> [E:8739i S:0 M:47193907 (Ack:92132060)] (U) Msg RX from 0:0000000000000000 [0000] to 1179AA5E57D2C7F0 --- Type 0000:40 (SecureChannel:StatusReport) (B:34)
[1790241306.448] [467304:467306] [EM] Found matching exchange: 8739i, Delegate: 0xffff8c00b848
[1790241306.449] [467304:467306] [EM] CHIP MessageCounter:92132060 not in RetransTable on exchange 8739i
[1790241306.449] [467304:467306] [SC] Success status report received. Session was established
[1790241306.456] [467304:467306] [SC] SecureSession[0xffff8c00bb30, LSID:33639]: State change 'kEstablishing' --> 'kActive'
[1790241306.456] [467304:467306] [IN] SecureSession[0xffff8c00bb30]: Activated - Type:2 LSID:33639
[1790241306.456] [467304:467306] [IN] New secure session activated for device <0000000000000002, 1>, LSID:33639 PSID:6213!
[1790241306.457] [467304:467306] [DIS] OperationalSessionSetup[1:0000000000000002]: State change 4 --> 5
[1790241306.457] [467304:467306] [TOO] Sending ReadAttribute to:
[1790241306.457] [467304:467306] [TOO] 	cluster 0x0000_0028, attribute: 0x0000_0012, endpoint 0
[1790241306.457] [467304:467306] [DMG] SendReadRequest ReadClient[0xffff8c00eaf0]: Sending Read Request
[1790241306.457] [467304:467306] [DMG] 0 data version filters provided, 0 not relevant, 0 encoded, 0 skipped due to lack of space
[1790241306.457] [467304:467306] [EM] <<< [E:8740i S:33639 M:106557212] (S) Msg TX from 000000000001B669 to 1:0000000000000002 [A104] [UDP:[fd11:25::fcbb:fd84:b83f:2815]:5540] --- Type 0001:02 (IM:ReadRequest
[1790241306.458] [467304:467306] [EM] ??1 [E:8740i S:33639 M:106557212] (S) Msg Retransmission to 1:0000000000000002 scheduled for 2645ms from now [State:Active II:3000 AI:2200 AT:300]
[1790241306.458] [467304:467306] [DMG] MoveToState ReadClient[0xffff8c00eaf0]: Moving to [AwaitingIn]
[1790241306.458] [467304:467306] [EM] <<< [E:8739i S:0 M:92132061 (Ack:47193907)] (U) Msg TX from 1179AA5E57D2C7F0 to 0:0000000000000000 [0000] [UDP:[fd11:25::fcbb:fd84:b83f:2815]:5540] --- Type 0000:10 (Secu
[1790241306.458] [467304:467306] [EM] Flushed pending ack for MessageCounter:47193907 on exchange 8739i
[1790241306.458] [467304:467306] [DL] HandlePlatformSpecificBLEEvent 32792
[1790241306.752] [467304:467306] [EM] >>> [E:8740i S:33639 M:191114545 (Ack:106557212)] (S) Msg RX from 1:0000000000000002 [A104] to 000000000001B669 --- Type 0001:05 (IM:ReportData) (B:70)
[1790241306.752] [467304:467306] [EM] Found matching exchange: 8740i, Delegate: 0xffff8c00eb00
[1790241306.752] [467304:467306] [EM] Rxd Ack; Removing MessageCounter:106557212 from Retrans Table on exchange 8740i
[1790241306.753] [467304:467306] [DMG] ReportDataMessage =
[1790241306.753] [467304:467306] [DMG] {
[1790241306.753] [467304:467306] [DMG] 	AttributeReportIBs =
[1790241306.753] [467304:467306] [DMG] 	[
[1790241306.753] [467304:467306] [DMG] 		AttributeReportIB =
[1790241306.753] [467304:467306] [DMG] 			AttributeDataIB =
[1790241306.753] [467304:467306] [DMG] 				DataVersion = 0x29433f05,
[1790241306.753] [467304:467306] [DMG] 				AttributePathIB =
[1790241306.753] [467304:467306] [DMG] 					Endpoint = 0x0,
[1790241306.753] [467304:467306] [DMG] 					Cluster = 0x28,
[1790241306.754] [467304:467306] [DMG] 					Attribute = 0x0000_0012,
[1790241306.754] [467304:467306] [DMG] 				}
[1790241306.754] [467304:467306] [DMG] 				Data = "" (0 chars),      <---------------------------------------------------- empty
[1790241306.754] [467304:467306] [DMG] 			},
[1790241306.754] [467304:467306] [DMG] 	],
[1790241306.754] [467304:467306] [DMG] 	SuppressResponse = true,
[1790241306.754] [467304:467306] [DMG] 	InteractionModelRevision = 11
[1790241306.755] [467304:467306] [TOO] Endpoint: 0 Cluster: 0x0000_0028 Attribute 0x0000_0012 DataVersion: 692272901
[1790241306.755] [467304:467306] [TOO]   UniqueID:
[1790241306.755] [467304:467306] [EM] <<< [E:8740i S:33639 M:106557213 (Ack:191114545)] (S) Msg TX from 000000000001B669 to 1:0000000000000002 [A104] [UDP:[fd11:25::fcbb:fd84:b83f:2815]:5540] --- Type 0000:10
[1790241306.755] [467304:467306] [EM] Flushed pending ack for MessageCounter:191114545 on exchange 8740i
[1790241306.756] [467304:467304] [CTL] Shutting down the commissioner
[1790241306.756] [467304:467304] [PAF] WiFiPAF: Closing all WiFiPAF sessions to shutdown
[1790241306.756] [467304:467304] [CTL] Shutting down the controller
[1790241306.756] [467304:467304] [IN] Expiring all sessions for fabric 0x1!!
[1790241306.756] [467304:467304] [IN] SecureSession[0xffff8c00bb30]: MarkForEviction Type:2 LSID:33639
[1790241306.756] [467304:467304] [SC] SecureSession[0xffff8c00bb30, LSID:33639]: State change 'kActive' --> 'kPendingEviction'
[1790241306.756] [467304:467304] [IN] SecureSession[0xffff8c00bb30]: Released - Type:2 LSID:33639
[1790241306.756] [467304:467304] [FP] Forgetting fabric 0x1
[1790241306.756] [467304:467304] [TS] Pending Last Known Good Time: 2023-10-14T01:16:48
[1790241306.757] [467304:467304] [TS] Previous Last Known Good Time: 2023-10-14T01:16:48
[1790241306.757] [467304:467304] [TS] Reverted Last Known Good Time to previous value
[1790241306.757] [467304:467304] [CTL] Shutting down the commissioner
[1790241306.757] [467304:467304] [PAF] WiFiPAF: Closing all WiFiPAF sessions to shutdown
[1790241306.757] [467304:467304] [CTL] Shutting down the controller
[1790241306.757] [467304:467304] [CTL] Shutting down the System State, this will teardown the CHIP Stack
[1790241306.758] [467304:467304] [DMG] All ReadHandler-s are clean, clear GlobalDirtySet
[1790241306.758] [467304:467304] [FP] Shutting down FabricTable
[1790241306.758] [467304:467304] [TS] Pending Last Known Good Time: 2023-10-14T01:16:48
[1790241306.758] [467304:467304] [TS] Previous Last Known Good Time: 2023-10-14T01:16:48
[1790241306.758] [467304:467304] [TS] Reverted Last Known Good Time to previous value
[1790241306.765] [467304:467304] [DL] Wrote settings to /tmp/chip_counters.ini
[1790241306.766] [467304:467304] [DL] NVS set: chip-counters/total-operational-hours = 0 (0x0)
[1790241306.766] [467304:467304] [DL] Inet Layer shutdown
[1790241306.766] [467304:467304] [DL] BLE Layer shutdown
[1790241306.766] [467304:467304] [DL] WiFi-PAF Layer shutdown
[1790241306.766] [467304:467304] [PAF] WiFiPAF: Closing all WiFiPAF sessions to shutdown
[1790241306.766] [467304:467304] [DL] System Layer shutdown
    Could you share the device logs for fabric removal and whether a reboot between decommissioning and recommissioning changes the UniqueID?
    Amanda H.
  • HI,
    Thanks for your reply.
    This is the nRF5340DK log.
    Commissioning complete, nRF5340DK booting up.
    [2026-09-25 09:08:31.396]
    [2026-09-25 09:08:31.396] uart:~$ *** Booting My Application v2.9.2-18b4f40ea698 ***
    [2026-09-25 09:08:31.429] *** Using nRF Connect SDK v2.9.2-4ab7b98fc76f ***
    [2026-09-25 09:08:31.429] *** Using Zephyr OS v3.7.99-aa34a5632971 ***
    [2026-09-25 09:08:31.438] I: 58 [DL]BLE address: EC:DF:6D:EA:EF:D6
    [2026-09-25 09:08:31.457] I: No users indexes stored
    [2026-09-25 09:08:31.467] I: No stored indexes for credential of type: 1
    [2026-09-25 09:08:31.472] I: 91 [DL]CHIP task running
    [2026-09-25 09:08:31.474] I: Init CHIP stack
    [2026-09-25 09:08:31.488] I: 108 [DL]OpenThread ifconfig up and thread start
    [2026-09-25 09:08:31.494] I: 113 [DL]OpenThread started: OK
    [2026-09-25 09:08:31.501] I: 119 [DL]Setting OpenThread device type to SLEEPY END DEVICE
    [2026-09-25 09:08:31.507] I: 125 [SVR]Subscription persistence not supported
    [2026-09-25 09:08:31.510] I: 130 [SVR]Server initializing...
    [2026-09-25 09:08:31.515] I: 133 [TS]Last Known Good Time: 2023-10-14T01:16:48
    [2026-09-25 09:08:31.523] I: 141 [FP]Fabric index 0x2 was retrieved from storage. Compressed FabricId 0x4FC239DB662DA104, FabricId 0x0000000000000001, NodeId 0x0000000000000002, VendorId 0xFFF1
    [2026-09-25 09:08:31.534] I: 157 [DMG]AccessControl: initializing
    [2026-09-25 09:08:31.541] I: 160 [DMG]Examples::AccessControlDelegate::Init
    [2026-09-25 09:08:31.545] I: 165 [DMG]AccessControl: setting
    [2026-09-25 09:08:31.545] I: 168 [DMG]DefaultAclStorage: initializing
    [2026-09-25 09:08:31.545] I: 173 [DMG]DefaultAclStorage: 1 entries loaded
    [2026-09-25 09:08:31.560] E: 178 [IN]IPV6_PKTINFO failed: 109
    [2026-09-25 09:08:31.561] I: 183 [ZCL]Using ZAP configuration...
    [2026-09-25 09:08:31.568] I: 188 [DMG]AccessControlCluster: initializing
    [2026-09-25 09:08:31.574] I: 193 [ZCL]Initiating Admin Commissioning cluster.
    [2026-09-25 09:08:31.574] I: 197 [ZCL]Door Lock server initialized
    [2026-09-25 09:08:31.583] I: 201 [ZCL]Door Lock cluster initialized at endpoint #1
    [2026-09-25 09:08:31.587] I: 206 [ZCL]0xaf166 ep 1 clus 0x0000_0101 attr 0x0000_0013 not supported
    [2026-09-25 09:08:31.591] E: 214 [ZCL]Failed to set DoorLock number of RFID users: 86
    [2026-09-25 09:08:31.696] I: 315 [SVR]Fabric already commissioned. Disabling BLE advertisement
    [2026-09-25 09:08:31.704] I: 322 [DIS]Updating services using commissioning mode 0
    [2026-09-25 09:08:31.710] E: 329 [DIS]Failed to remove advertised services: 3
    [2026-09-25 09:08:31.718] I: 337 [DIS]Advertise operational node 4FC239DB662DA104-0000000000000002
    [2026-09-25 09:08:31.724] E:I: 351 [DL]SRP Client was started, detected server: fdd6:208a:44e0:8102:05c4:a54e:7070:8122
    [2026-09-25 09:08:31.741]  344 [DIS]Failed to advertise operational node: 3
    [2026-09-25 09:08:31.744] E: 363 [DIS]Failed to finalize service update: 3
    [2026-09-25 09:08:31.746] I: 368 [IN]CASE Server enabling CASE session setups
    [2026-09-25 09:08:31.746] I: 373 [SVR]Joining Multicast groups
    [2026-09-25 09:08:31.757] I: 377 [SVR]Server Listening...
    [2026-09-25 09:08:31.760] I: 380 [DL]Device Configuration:
    [2026-09-25 09:08:31.760] I: 383 [DL]  Serial Number: 11223344556677889900
    [2026-09-25 09:08:31.769] I: 387 [DL]  Vendor Id: 65521 (0xFFF1)
    [2026-09-25 09:08:31.769] I: 391 [DL]  Product Id: 32774 (0x8006)
    [2026-09-25 09:08:31.774] I: 394 [DL]  Product Name: not-specified
    [2026-09-25 09:08:31.774] I: 398 [DL]  Hardware Version: 0
    [2026-09-25 09:08:31.784] I: 401 [DL]  Setup Pin Code (0 for UNKNOWN/ERROR): 20202021
    [2026-09-25 09:08:31.784] I: 406 [DL]  Setup Discriminator (0xFFFF for UNKNOWN/ERROR): 3840 (0xF00)
    [2026-09-25 09:08:31.791] I: 413 [DL]  Manufacturing Date: 2022-01-01
    [2026-09-25 09:08:31.791] I: 417 [DL]  Device Type: 65535 (0xFFFF)
    [2026-09-25 09:08:31.791] I: 420 [SVR]SetupQRCode: [MT:8IXS142C00KA0648G00]
    [2026-09-25 09:08:31.803] I: 425 [SVR]Copy/paste the below URL in a browser to see the QR Code:
    [2026-09-25 09:08:31.807] I: 431 [SVR]https://project-chip.github.io/connectedhomeip/qrcode.html?data=MT%3A8IXS142C00KA0648G00
    [2026-09-25 09:08:31.821] I: 441 [SVR]Manual pairing code: [34970112332]
    [2026-09-25 09:08:31.824] E: 446 [DL]Long dispatch time: 353 ms, for event type 2
    [2026-09-25 09:08:31.846] I: 466 [ZCL]ThreadDiagnosticsDelegate: OnConnectionStatusChanged
    [2026-09-25 09:08:32.581] I: 1185 [SVR]Server initialization complete
    [2026-09-25 09:08:32.581] I: 1189 [DIS]Updating services using commissioning mode 0
    [2026-09-25 09:08:32.581] I: 1194 [DIS]Advertise operational node 4FC239DB662DA104-0000000000000002
    [2026-09-25 09:08:32.581] I: 1201 [DL]advertising srp service: 4FC239DB662DA104-0000000000000002._matter._tcp
    [2026-09-25 09:08:32.591] I: 1212 [SWU]Stopping the watchdog timer
    [2026-09-25 09:08:32.596] I: 1216 [SWU]Starting the periodic query timer, timeout: 86400 seconds
    nRF5340DK boot complete.
    Starting decommissioning.
    [2026-09-25 09:09:59.885] I: 88490 [EM]>>> [E:33878r S:0 M:116540948] (U) Msg RX from 0:842EA98982738386 [0000] to 0000000000000000 --- Type 0000:30 (SecureChannel:CASE_Sigma1) (B:196)
    [2026-09-25 09:09:59.887] I: 88504 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20007148
    [2026-09-25 09:09:59.892] I: 88512 [EM]<<< [E:33878r S:0 M:257592796 (Ack:116540948)] (U) Msg TX from 0000000000000000 to 0:842EA98982738386 [0000] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:56765] --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
    [2026-09-25 09:09:59.907] I: 88532 [SC]Received Sigma1 msg
    [2026-09-25 09:09:59.917] I: 88542 [SC]CASE matched destination ID: fabricIndex 2, NodeID 0x0000000000000002
    [2026-09-25 09:10:00.028] I: 88635 [EM]<<< [E:33878r S:0 M:257592797 (Ack:116540948)] (U) Msg TX from 0000000000000000 to 0:842EA98982738386 [0000] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:56765] --- Type 0000:31 (SecureChannel:CASE_Sigma2) (B:751)
    [2026-09-25 09:10:00.035] I: 88656 [EM]??1 [E:33878r S:0 M:257592797] (U) Msg Retransmission to 0:0000000000000000 in 2060ms [State:Active II:500 AI:300 AT:4000]
    [2026-09-25 09:10:00.044] I: 88670 [SC]Sent Sigma2 msg
    [2026-09-25 09:10:00.472] I: 89088 [EM]>>> [E:33878r S:0 M:116540949 (Ack:257592797)] (U) Msg RX from 0:842EA98982738386 [0000] to 0000000000000000 --- Type 0000:32 (SecureChannel:CASE_Sigma3) (B:598)
    [2026-09-25 09:10:00.480] I: 89104 [EM]<<< [E:33878r S:0 M:257592798 (Ack:116540949)] (U) Msg TX from 0000000000000000 to 0:842EA98982738386 [0000] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:56765] --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
    [2026-09-25 09:10:00.503] I: 89125 [SC]Received Sigma3 msg
    [2026-09-25 09:10:00.512] E: 89134 [SC]The device does not support GetClock_RealTimeMS() API: 3.  Falling back to Last Known Good UTC Time
    [2026-09-25 09:10:00.694] E: 89307 [DL]Long dispatch time: 163 ms, for event type 2
    [2026-09-25 09:10:00.694] I: 89318 [EM]<<< [E:33878r S:0 M:257592799 (Ack:116540949)] (U) Msg TX from 0000000000000000 to 0:842EA98982738386 [0000] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:56765] --- Type 0000:40 (SecureChannel:StatusReport) (B:34)
    [2026-09-25 09:10:00.710] I: 89339 [EM]??1 [E:33878r S:0 M:257592799] (U) Msg Retransmission to 0:0000000000000000 in 2108ms [State:Active II:500 AI:300 AT:4000]
    [2026-09-25 09:10:00.732] I: 89353 [SC]SecureSession[0x20005370, LSID:1980]: State change 'kEstablishing' --> 'kActive'
    [2026-09-25 09:10:00.743] I: 89362 [IN]CASE Session established to peer: <000000000001B669, 2>
    [2026-09-25 09:10:00.885] I: 89491 [EM]>>> [E:33879r S:1980 M:108089556] (S) Msg RX from 2:000000000001B669 [A104] to 0000000000000002 --- Type 0001:02 (IM:ReadRequest) (B:51)
    [2026-09-25 09:10:00.890] I: 89510 [EM]<<< [E:33879r S:1980 M:15899676 (Ack:108089556)] (S) Msg TX from 0000000000000002 to 2:000000000001B669 [A104] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:56765] --- Type 0001:05 (IM:ReportData) (B:70)
    [2026-09-25 09:10:00.908] I: 89530 [EM]??1 [E:33879r S:1980 M:15899676] (S) Msg Retransmission to 2:000000000001B669 in 2090ms [State:Active II:500 AI:300 AT:4000]
    [2026-09-25 09:10:00.917] I: 89543 [EM]>>> [E:33878r S:0 M:116540950 (Ack:257592799)] (U) Msg RX from 0:842EA98982738386 [0000] to 0000000000000000 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
    [2026-09-25 09:10:01.202] I: 89813 [EM]>>> [E:33880r S:1980 M:108089557] (S) Msg RX from 2:000000000001B669 [A104] to 0000000000000002 --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
    [2026-09-25 09:10:01.207] I: 89831 [ZCL]OpCreds: Received a RemoveFabric Command for FabricIndex 0x2
    [2026-09-25 09:10:01.217] I: 89839 [EM]<<< [E:33880r S:1980 M:15899677 (Ack:108089557)] (S) Msg TX from 0000000000000002 to 2:000000000001B669 [A104] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:56765] --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
    [2026-09-25 09:10:01.246] I: 89867 [FP]Fabric (0x2) deleted.
    [2026-09-25 09:10:01.250] I: 89870 [ZCL][OnFabricRemoved] Handling a fabric removal from the door lock server [endpointId=1,fabricIndex=2]
    [2026-09-25 09:10:01.257] E: 89880 [ZCL][clearFabricFromCredentials] Unable to clear fabric from credential - couldn't read credential from database [endpointId=1,credentialType=0,credentialIndex=0,fabricIdToRemove=2]
    [2026-09-25 09:10:01.274] I: 89897 [ZCL]OpCreds: Fabric index 0x2 was removed
    [2026-09-25 09:10:01.281] I: 89902 [DIS]Updating services using commissioning mode 0
    [2026-09-25 09:10:01.281] I: 89907 [DL]removing srp service: 4FC239DB662DA104-0000000000000002._matter._tcp
    [2026-09-25 09:10:01.311] I: 89938 [ZCL]OpCreds: RemoveFabric successful
    [2026-09-25 09:10:01.311] I: 89942 [SC]SecureSession[0x20005370, LSID:1980]: State change 'kActive' --> 'kPendingEviction'
    [2026-09-25 09:10:01.327] I: 89952 [EM]<<< [E:33880r S:1980 M:15899678 (Ack:108089557)] (S) Msg TX from 0000000000000002 to 2:000000000001B669 [0000] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:56765] --- Type 0001:09 (IM:InvokeCommandResponse) (B:70)
    [2026-09-25 09:10:01.350] I: 89972 [EM]??1 [E:33880r S:1980 M:15899678] (S) Msg Retransmission to 2:000000000001B669 in 2085ms [State:Active II:500 AI:300 AT:4000]
    [2026-09-25 09:10:01.363] I: 89986 [EM]>>> [E:33879r S:1980 M:108089558 (Ack:15899676)] (S) Msg RX from 2:000000000001B669 [0000] to 0000000000000002 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
    [2026-09-25 09:10:01.381] I: 90002 [EM]Dropping message on inactive session that does not match an existing exchange
    [2026-09-25 09:10:01.391] I: 90023 [EM]>>> [E:33880r S:1980 M:108089559 (Ack:15899678)] (S) Msg RX from 2:000000000001B669 [0000] to 0000000000000002 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
    [2026-09-25 09:10:02.624] I: 91234 [DL]Erasing Thread persistent info...
    [2026-09-25 09:10:02.627] E: 91256 [DL]Long dispatch time: 386 ms, for event type 2
    [2026-09-25 09:10:02.641] I: 91261 [DIS]Updating services using commissioning mode 0
    [2026-09-25 09:10:02.641] I: 91266 [ZCL]ThreadDiagnosticsDelegate: OnConnectionStatusChanged
    [2026-09-25 09:10:02.641] I: 91272 [ZCL]ThreadDiagnosticsDelegate: OnNetworkFaultChanged
    Decommissioning complete.
    Starting re-commissioning.
    [2026-09-25 09:10:27.476] I: 116080 [DIS]Updating services using commissioning mode 1
    [2026-09-25 09:10:27.476] I: 116086 [DIS]Advertise commission parameter vendorID=65521 productID=32774 discriminator=3840/15 cm=1 cp=0
    [2026-09-25 09:10:27.476] I: 116096 [DL]advertising srp service: E065260FF669AFA2._matterc._udp
    [2026-09-25 09:10:27.485] I: 116106 [DL]CHIPoBLE advertising started
    [2026-09-25 09:10:27.485] I: 116110 [DL]NFC Tag emulation started
    [2026-09-25 09:10:49.029] I: 137634 [DL]Current number of connections: 1/1
    [2026-09-25 09:10:49.029] I: 137639 [DL]BLE connection established (ConnId: 0x00)
    [2026-09-25 09:10:49.029] I: 137645 [DL]CHIPoBLE advertising stopped
    [2026-09-25 09:10:49.029] I: 137649 [DL]NFC Tag emulation stopped
    [2026-09-25 09:10:50.535] I: 139143 [BLE]local and remote recv window sizes = 5
    [2026-09-25 09:10:50.535] I: 139147 [BLE]selected BTP version 4
    [2026-09-25 09:10:50.535] I: 139151 [BLE]using BTP fragment sizes rx 244 / tx 244.
    [2026-09-25 09:10:50.615] I: 139233 [DL]CHIPoBLE connection established (ConnId: 0x00, GATT MTU: 247)
    [2026-09-25 09:10:50.710] I: 139324 [EM]>>> [E:41914r S:0 M:103905166] (U) Msg RX from 0:1089A17B49F46F87 [0000] to 0000000000000000 --- Type 0000:20 (SecureChannel:PBKDFParamRequest) (B:98)
    [2026-09-25 09:10:50.710] I: 139340 [EM]<<< [E:41914r S:0 M:257592800] (U) Msg TX from 0000000000000000 to 0:1089A17B49F46F87 [0000] [BLE] --- Type 0000:21 (SecureChannel:PBKDFParamResponse) (B:154)
    [2026-09-25 09:10:50.737] I: 139356 [SVR]Commissioning session establishment step started
    [2026-09-25 09:10:50.805] I: 139414 [EM]>>> [E:41914r S:0 M:103905167] (U) Msg RX from 0:1089A17B49F46F87 [0000] to 0000000000000000 --- Type 0000:22 (SecureChannel:PASE_Pake1) (B:92)
    [2026-09-25 09:10:50.931] I: 139550 [EM]<<< [E:41914r S:0 M:257592801] (U) Msg TX from 0000000000000000 to 0:1089A17B49F46F87 [0000] [BLE] --- Type 0000:23 (SecureChannel:PASE_Pake2) (B:127)
    [2026-09-25 09:10:50.946] E: 139565 [DL]Long dispatch time: 151 ms, for event type 16388
    [2026-09-25 09:10:51.074] I: 139684 [EM]>>> [E:41914r S:0 M:103905168] (U) Msg RX from 0:1089A17B49F46F87 [0000] to 0000000000000000 --- Type 0000:24 (SecureChannel:PASE_Pake3) (B:59)
    [2026-09-25 09:10:51.074] I: 139699 [EM]<<< [E:41914r S:0 M:257592802] (U) Msg TX from 0000000000000000 to 0:1089A17B49F46F87 [0000] [BLE] --- Type 0000:40 (SecureChannel:StatusReport) (B:30)
    [2026-09-25 09:10:51.097] I: 139716 [SC]SecureSession[0x20005370, LSID:1982]: State change 'kEstablishing' --> 'kActive'
    [2026-09-25 09:10:51.103] I: 139724 [SVR]Commissioning completed session establishment step
    [2026-09-25 09:10:51.109] I: 139730 [DIS]Updating services using commissioning mode 0
    [2026-09-25 09:10:51.109] I: 139736 [DL]removing srp service: E065260FF669AFA2._matterc._udp
    [2026-09-25 09:10:51.121] I: 139742 [SVR]Device completed Rendezvous process
    [2026-09-25 09:10:51.200] I: 139820 [EM]>>> [E:41915r S:1982 M:29260020] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:134)
    [2026-09-25 09:10:51.219] I: 139840 [EM]<<< [E:41915r S:1982 M:162258637] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:257)
    [2026-09-25 09:10:51.438] I: 140045 [EM]>>> [E:41916r S:1982 M:29260021] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:02 (IM:ReadRequest) (B:103)
    [2026-09-25 09:10:51.440] E: 140061 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x0000_0046, attributeId: 0x0000_0007err = 586
    [2026-09-25 09:10:51.448] E: 140072 [DMG]Fail to retrieve data, roll back and encode status on clusterId: 0x0000_0046, attributeId: 0x0000_0006err = 586
    [2026-09-25 09:10:51.457] I: 140085 [EM]<<< [E:41916r S:1982 M:162258638] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:05 (IM:ReportData) (B:192)
    [2026-09-25 09:10:51.564] I: 140180 [EM]>>> [E:41917r S:1982 M:29260022] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:65)
    [2026-09-25 09:10:51.574] I: 140194 [FS]GeneralCommissioning: Received ArmFailSafe (60s)
    [2026-09-25 09:10:51.580] I: 140201 [EM]<<< [E:41917r S:1982 M:162258639] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
    [2026-09-25 09:10:51.707] I: 140315 [EM]>>> [E:41918r S:1982 M:29260023] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:70)
    [2026-09-25 09:10:51.710] I: 140331 [EM]<<< [E:41918r S:1982 M:162258640] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
    [2026-09-25 09:10:51.786] I: 140404 [EM]>>> [E:41919r S:1982 M:29260024] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
    [2026-09-25 09:10:51.799] I: 140419 [ZCL]OpCreds: Certificate Chain request received for PAI
    [2026-09-25 09:10:51.807] I: 140429 [EM]<<< [E:41919r S:1982 M:162258641] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:527)
    [2026-09-25 09:10:52.054] I: 140674 [EM]>>> [E:41920r S:1982 M:29260025] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:62)
    [2026-09-25 09:10:52.074] I: 140689 [ZCL]OpCreds: Certificate Chain request received for DAC
    [2026-09-25 09:10:52.076] I: 140699 [EM]<<< [E:41920r S:1982 M:162258642] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:555)
    [2026-09-25 09:10:52.419] I: 141034 [EM]>>> [E:41921r S:1982 M:29260026] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:94)
    [2026-09-25 09:10:52.424] I: 141049 [ZCL]OpCreds: Received an AttestationRequest command
    [2026-09-25 09:10:52.466] I: 141085 [ZCL]OpCreds: AttestationRequest successful.
    [2026-09-25 09:10:52.472] I: 141094 [EM]<<< [E:41921r S:1982 M:162258643] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:716)
    [2026-09-25 09:10:52.782] I: 141394 [EM]>>> [E:41922r S:1982 M:29260027] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:94)
    [2026-09-25 09:10:52.788] I: 141409 [ZCL]OpCreds: Received a CSRRequest command
    [2026-09-25 09:10:52.861] I: 141469 [ZCL]OpCreds: AllocatePendingOperationalKey succeeded
    [2026-09-25 09:10:52.877] I: 141504 [ZCL]OpCreds: CSRRequest successful.
    [2026-09-25 09:10:52.889] I: 141511 [EM]<<< [E:41922r S:1982 M:162258644] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:393)
    [2026-09-25 09:10:52.905] E: 141526 [DL]Long dispatch time: 133 ms, for event type 16388
    [2026-09-25 09:10:53.225] I: 141845 [EM]>>> [E:41923r S:1982 M:29260028] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:293)
    [2026-09-25 09:10:53.240] I: 141860 [ZCL]OpCreds: Received an AddTrustedRootCertificate command
    [2026-09-25 09:10:53.304] I: 141920 [ZCL]OpCreds: AddTrustedRootCertificate successful.
    [2026-09-25 09:10:53.307] I: 141926 [EM]<<< [E:41923r S:1982 M:162258645] (S) Msg TX from 0000000000000000 to 0:FFFFFFFB00000000 [0000] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:63)
    [2026-09-25 09:10:53.588] I: 142207 [EM]>>> [E:41924r S:1982 M:29260029] (S) Msg RX from 0:FFFFFFFB00000000 [0000] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:566)
    [2026-09-25 09:10:53.600] I: 142222 [ZCL]OpCreds: Received an AddNOC command
    [2026-09-25 09:10:53.610] I: 142227 [FP]Validating NOC chain
    [2026-09-25 09:10:53.730] I: 142340 [FP]NOC chain validation successful
    [2026-09-25 09:10:53.730] I: 142344 [FP]Added new fabric at index: 0x3
    [2026-09-25 09:10:53.730] I: 142348 [FP]Assigned compressed fabric ID: 0xD6F5CEE6A9E420C0, node ID: 0x0000000000000002
    [2026-09-25 09:10:53.736] I: 142356 [TS]Last Known Good Time: 2023-10-14T01:16:48
    [2026-09-25 09:10:53.736] I: 142361 [TS]New proposed Last Known Good Time: 2021-01-01T00:00:00
    [2026-09-25 09:10:53.746] I: 142367 [TS]Retaining current Last Known Good Time
    [2026-09-25 09:10:53.759] I: 142382 [ZCL]OpCreds: ACL entry created for Fabric index 0x3 CASE Admin Subject 0x000000000001B669
    [2026-09-25 09:10:53.761] I: 142391 [DIS]Advertise operational node D6F5CEE6A9E420C0-0000000000000002
    [2026-09-25 09:10:53.774] I: 142398 [DL]advertising srp service: D6F5CEE6A9E420C0-0000000000000002._matter._tcp
    [2026-09-25 09:10:53.777] I: 142406 [ZCL]OpCreds: successfully created fabric index 0x3 via AddNOC
    [2026-09-25 09:10:53.790] I: 142413 [EM]<<< [E:41924r S:1982 M:162258646] (S) Msg TX from 0000000000000000 to 3:FFFFFFFB00000000 [20C0] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
    [2026-09-25 09:10:53.808] E: 142428 [DL]Long dispatch time: 225 ms, for event type 16388
    [2026-09-25 09:10:53.903] I: 142521 [EM]>>> [E:41925r S:1982 M:29260030] (S) Msg RX from 3:FFFFFFFB00000000 [20C0] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:160)
    [2026-09-25 09:10:53.916] I: 142538 [EM]<<< [E:41925r S:1982 M:162258647] (S) Msg TX from 0000000000000000 to 3:FFFFFFFB00000000 [20C0] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
    [2026-09-25 09:10:53.998] I: 142610 [EM]>>> [E:41926r S:1982 M:29260031] (S) Msg RX from 3:FFFFFFFB00000000 [20C0] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:65)
    [2026-09-25 09:10:54.001] I: 142624 [FS]GeneralCommissioning: Received ArmFailSafe (108s)
    [2026-09-25 09:10:54.011] I: 142631 [EM]<<< [E:41926r S:1982 M:162258648] (S) Msg TX from 0000000000000000 to 3:FFFFFFFB00000000 [20C0] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:66)
    [2026-09-25 09:10:54.093] I: 142700 [EM]>>> [E:41927r S:1982 M:29260032] (S) Msg RX from 3:FFFFFFFB00000000 [20C0] to 0000000000000000 --- Type 0001:08 (IM:InvokeCommandRequest) (B:73)
    [2026-09-25 09:10:55.282] I: 143890 [ZCL]ThreadDiagnosticsDelegate: OnConnectionStatusChanged
    [2026-09-25 09:10:55.282] I: 143899 [EM]<<< [E:41927r S:1982 M:162258649] (S) Msg TX from 0000000000000000 to 3:FFFFFFFB00000000 [20C0] [BLE] --- Type 0001:09 (IM:InvokeCommandResponse) (B:65)
    [2026-09-25 09:10:55.291] I: 143914 [DIS]Advertise operational node D6F5CEE6A9E420C0-0000000000000002
    [2026-09-25 09:10:55.297] I: 143921 [SVR]Operational advertising enabled
    [2026-09-25 09:10:56.750] I: 145367 [EM]>>> [E:41928r S:0 M:103905169] (U) Msg RX from 0:F7AF320FD2091F76 [0000] to 0000000000000000 --- Type 0000:30 (SecureChannel:CASE_Sigma1) (B:196)
    [2026-09-25 09:10:56.759] I: 145381 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20007148
    [2026-09-25 09:10:56.766] I: 145389 [EM]<<< [E:41928r S:0 M:257592803 (Ack:103905169)] (U) Msg TX from 0000000000000000 to 0:F7AF320FD2091F76 [0000] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:45020] --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
    [2026-09-25 09:10:56.782] I: 145409 [SC]Received Sigma1 msg
    [2026-09-25 09:10:56.797] I: 145419 [SC]CASE matched destination ID: fabricIndex 3, NodeID 0x0000000000000002
    [2026-09-25 09:10:56.892] I: 145509 [EM]<<< [E:41928r S:0 M:257592804 (Ack:103905169)] (U) Msg TX from 0000000000000000 to 0:F7AF320FD2091F76 [0000] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:45020] --- Type 0000:31 (SecureChannel:CASE_Sigma2) (B:751)
    [2026-09-25 09:10:56.907] I: 145530 [EM]??1 [E:41928r S:0 M:257592804] (U) Msg Retransmission to 0:0000000000000000 in 2087ms [State:Active II:500 AI:300 AT:4000]
    [2026-09-25 09:10:56.907] I: 145543 [SC]Sent Sigma2 msg
    [2026-09-25 09:10:57.588] I: 146194 [EM]>>> [E:41928r S:0 M:103905170 (Ack:257592804)] (U) Msg RX from 0:F7AF320FD2091F76 [0000] to 0000000000000000 --- Type 0000:32 (SecureChannel:CASE_Sigma3) (B:598)
    [2026-09-25 09:10:57.591] I: 146210 [EM]<<< [E:41928r S:0 M:257592805 (Ack:103905170)] (U) Msg TX from 0000000000000000 to 0:F7AF320FD2091F76 [0000] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:45020] --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
    [2026-09-25 09:10:57.607] I: 146231 [SC]Received Sigma3 msg
    [2026-09-25 09:10:57.607] E: 146240 [SC]The device does not support GetClock_RealTimeMS() API: 3.  Falling back to Last Known Good UTC Time
    [2026-09-25 09:10:57.794] E: 146413 [DL]Long dispatch time: 163 ms, for event type 2
    [2026-09-25 09:10:57.794] I: 146424 [EM]<<< [E:41928r S:0 M:257592806 (Ack:103905170)] (U) Msg TX from 0000000000000000 to 0:F7AF320FD2091F76 [0000] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:45020] --- Type 0000:40 (SecureChannel:StatusReport) (B:34)
    [2026-09-25 09:10:57.824] I: 146445 [EM]??1 [E:41928r S:0 M:257592806] (U) Msg Retransmission to 0:0000000000000000 in 2091ms [State:Active II:500 AI:300 AT:4000]
    [2026-09-25 09:10:57.835] I: 146460 [SC]SecureSession[0x20005448, LSID:1981]: State change 'kEstablishing' --> 'kActive'
    [2026-09-25 09:10:57.848] I: 146468 [IN]CASE Session established to peer: <000000000001B669, 3>
    [2026-09-25 09:10:57.985] I: 146597 [EM]>>> [E:41929r S:1981 M:12638737] (S) Msg RX from 3:000000000001B669 [20C0] to 0000000000000002 --- Type 0001:08 (IM:InvokeCommandRequest) (B:59)
    [2026-09-25 09:10:57.992] I: 146616 [FS]GeneralCommissioning: Received CommissioningComplete
    [2026-09-25 09:10:58.001] I: 146623 [FP]Metadata for Fabric 0x3 persisted to storage.
    [2026-09-25 09:10:58.018] I: 146640 [TS]Committing Last Known Good Time to storage: 2023-10-14T01:16:48
    [2026-09-25 09:10:58.027] I: 146649 [ZCL]OpCreds: Fabric index 0x3 was committed to storage. Compressed Fabric Id 0xD6F5CEE6A9E420C0, FabricId 0000000000000001, NodeId 0000000000000002, VendorId 0xFFF1
    [2026-09-25 09:10:58.049] I: 146665 [FS]GeneralCommissioning: Successfully commited pending fabric data
    [2026-09-25 09:10:58.049] I: 146672 [FS]Fail-safe cleanly disarmed
    [2026-09-25 09:10:58.057] I: 146677 [EM]<<< [E:41929r S:1981 M:4515810 (Ack:12638737)] (S) Msg TX from 0000000000000002 to 3:000000000001B669 [20C0] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:45020] --- Type 0001:09 (IM:InvokeCommandResponse) (B:70)
    [2026-09-25 09:10:58.074] I: 146697 [EM]??1 [E:41929r S:1981 M:4515810] (S) Msg Retransmission to 3:000000000001B669 in 2053ms [State:Active II:500 AI:300 AT:4000]
    [2026-09-25 09:10:58.090] I: 146710 [SVR]Commissioning completed successfully
    [2026-09-25 09:10:58.092] I: 146716 [DIS]Updating services using commissioning mode 0
    [2026-09-25 09:10:58.096] I: 146721 [DIS]Advertise operational node D6F5CEE6A9E420C0-0000000000000002
    [2026-09-25 09:10:58.107] I: 146729 [SC]SecureSession[0x20005370, LSID:1982]: State change 'kActive' --> 'kPendingEviction'
    [2026-09-25 09:10:58.112] I: 146737 [BLE]Releasing end point's BLE connection back to application.
    [2026-09-25 09:10:58.112] I: 146744 [DL]Closing BLE GATT connection (ConnId 00)
    [2026-09-25 09:10:58.128] I: 146750 [SWU]Device commissioned, schedule a default provider query
    [2026-09-25 09:10:58.136] I: 146757 [EM]>>> [E:41928r S:0 M:103905171 (Ack:257592806)] (U) Msg RX from 0:F7AF320FD2091F76 [0000] to 0000000000000000 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
    [2026-09-25 09:10:58.270] I: 146882 [DL]Current number of connections: 0/1
    [2026-09-25 09:10:58.270] I: 146886 [DL]BLE GAP connection terminated (reason 0x16)
    [2026-09-25 09:10:58.603] I: 147209 [EM]>>> [E:41929r S:1981 M:12638738 (Ack:4515810)] (S) Msg RX from 3:000000000001B669 [20C0] to 0000000000000002 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
    Re-commissioning complete.
    Reading Unique ID.
    [2026-09-25 09:11:28.146] E: 176756 [SWU]No suitable OTA Provider candidate found
    [2026-09-25 09:11:28.147] I: 176761 [SWU]No provider available
    [2026-09-25 09:11:48.631] I: 197238 [EM]>>> [E:56606r S:0 M:264294567] (U) Msg RX from 0:C309693323D6A15C [0000] to 0000000000000000 --- Type 0000:30 (SecureChannel:CASE_Sigma1) (B:196)
    [2026-09-25 09:11:48.632] I: 197252 [IN]CASE Server received Sigma1 message . Starting handshake. EC 0x20007148
    [2026-09-25 09:11:48.637] I: 197260 [EM]<<< [E:56606r S:0 M:257592807 (Ack:264294567)] (U) Msg TX from 0000000000000000 to 0:C309693323D6A15C [0000] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:55979] --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
    [2026-09-25 09:11:48.658] I: 197281 [SC]Received Sigma1 msg
    [2026-09-25 09:11:48.669] I: 197291 [SC]CASE matched destination ID: fabricIndex 3, NodeID 0x0000000000000002
    [2026-09-25 09:11:48.771] I: 197381 [EM]<<< [E:56606r S:0 M:257592808 (Ack:264294567)] (U) Msg TX from 0000000000000000 to 0:C309693323D6A15C [0000] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:55979] --- Type 0000:31 (SecureChannel:CASE_Sigma2) (B:751)
    [2026-09-25 09:11:48.780] I: 197402 [EM]??1 [E:56606r S:0 M:257592808] (U) Msg Retransmission to 0:0000000000000000 in 2035ms [State:Active II:500 AI:300 AT:4000]
    [2026-09-25 09:11:48.792] I: 197415 [SC]Sent Sigma2 msg
    [2026-09-25 09:11:49.432] I: 198045 [EM]>>> [E:56606r S:0 M:264294568 (Ack:257592808)] (U) Msg RX from 0:C309693323D6A15C [0000] to 0000000000000000 --- Type 0000:32 (SecureChannel:CASE_Sigma3) (B:598)
    [2026-09-25 09:11:49.438] I: 198061 [EM]<<< [E:56606r S:0 M:257592809 (Ack:264294568)] (U) Msg TX from 0000000000000000 to 0:C309693323D6A15C [0000] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:55979] --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
    [2026-09-25 09:11:49.459] I: 198081 [SC]Received Sigma3 msg
    [2026-09-25 09:11:49.468] E: 198091 [SC]The device does not support GetClock_RealTimeMS() API: 3.  Falling back to Last Known Good UTC Time
    [2026-09-25 09:11:49.646] E: 198265 [DL]Long dispatch time: 163 ms, for event type 2
    [2026-09-25 09:11:49.653] I: 198275 [EM]<<< [E:56606r S:0 M:257592810 (Ack:264294568)] (U) Msg TX from 0000000000000000 to 0:C309693323D6A15C [0000] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:55979] --- Type 0000:40 (SecureChannel:StatusReport) (B:34)
    [2026-09-25 09:11:49.674] I: 198296 [EM]??1 [E:56606r S:0 M:257592810] (U) Msg Retransmission to 0:0000000000000000 in 2069ms [State:Active II:500 AI:300 AT:4000]
    [2026-09-25 09:11:49.688] I: 198311 [SC]SecureSession[0x20005520, LSID:1983]: State change 'kEstablishing' --> 'kActive'
    [2026-09-25 09:11:49.696] I: 198319 [IN]CASE Session established to peer: <000000000001B669, 3>
    [2026-09-25 09:11:49.836] I: 198446 [EM]>>> [E:56607r S:1983 M:129508836] (S) Msg RX from 3:000000000001B669 [20C0] to 0000000000000002 --- Type 0001:02 (IM:ReadRequest) (B:51)
    [2026-09-25 09:11:49.846] I: 198466 [EM]<<< [E:56607r S:1983 M:8401818 (Ack:129508836)] (S) Msg TX from 0000000000000002 to 3:000000000001B669 [20C0] [UDP:[fd11:25::eb56:5766:7a4e:d58f]:55979] --- Type 0001:05 (IM:ReportData) (B:70)
    [2026-09-25 09:11:49.863] I: 198485 [EM]??1 [E:56607r S:1983 M:8401818] (S) Msg Retransmission to 3:000000000001B669 in 2112ms [State:Active II:500 AI:300 AT:4000]
    [2026-09-25 09:11:49.878] I: 198499 [EM]>>> [E:56606r S:0 M:264294569 (Ack:257592810)] (U) Msg RX from 0:C309693323D6A15C [0000] to 0000000000000000 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:26)
    [2026-09-25 09:11:50.041] I: 198657 [EM]>>> [E:56607r S:1983 M:129508837 (Ack:8401818)] (S) Msg RX from 3:000000000001B669 [20C0] to 0000000000000002 --- Type 0000:10 (SecureChannel:StandaloneAck) (B:34)
    yes, Adding a reboot allows the Unique ID to be read correctly.
  • HI,
    This is a closely related issue, but could you tell me what the best code fix would be in the case of UniqueID?
    Sorry for the late reply.
    You can follow the procedure with RebootCount. Here is the example in this PR: https://github.com/nrfconnect/ncs-matter/pull/75
    Amanda H.
