Hi Nordic Team,
I would like to report a bug I hit while testing my project.
Project configuration:
- Use fota_download with CoAP protocol to download new images (coap://[host_addr]/[file_path])
- CoAP client and server use Block2 option to host firmware fragments
- The server supports maximum Block2 size 128 bytes
Steps to reproduce:
- Start downloading firmware image
- note: the device requests 1024 bytes fragment, when server responds with a 128 bytes fragment, the downloader correctly switches to 128 bytes fragments:
Request #0
Response #0
Request #1
- Break the connection between the server and the device for a few minutes
- The device retries downloading the next fragment:
- After 4 retries, the device retries Block2 parameters to default (as if fota_download started a brand new downloader session and didn't restore required connection parameters):
- When servers connection is restored, the server can't respond to Block2.num=56 with Block2.size=1024 request, because it's unaligned with the 128 bytes transfer supported by the server
Observed:
While the connection is broken, after 4 retries, fota_download reset CoAP Block2,size and Size2 parameters to default
Expected:
fota_download preserves the CoAP Block2 and Size2 parameters throughout all retries
Bonus request:
I see that the CoAP downloader transport module exposes `downloader_transport_coap_set_config()` function that I could use as a workaround setting `cfg->block_size = COAP_BLOCK_128`. However, I can't find how to use this function with fota_download. A sample presenting this would be helpful!
