Using nRF Connect SDK v3.4.1 with an nRF9151.
CONFIG_NRF_CLOUD_AGNSS currently has unconditional dependencies on:
nrf_cloud_coap_agnss_data_get() accepts a struct nrf_cloud_coap_agnss_request containing caller-supplied net_info.My application already obtains MCC, MNC, TAC, and cell ID and supplies them directly.
Therefore, the modem-info library is not needed for the A-GNSS request.
Enabling it has a significant cost in this memory-constrained application. In particular, nRF Cloud allocates:
I tested an application-side Kconfig override that enables NRF_CLOUD_AGNSS while leaving MODEM_INFO disabled. The result:
- Builds and links successfully
- Boots successfully on the nRF9151
- Filtered A-GNSS fetch and injection work successfully
- Saves 5,016 bytes of flash
- Saves 2,424 bytes of RAM
Could the A-GNSS Kconfig dependency be relaxed so MODEM_INFO is only required when the SDK must obtain network information itself?
For example, could NCS support two configurations:
- Network information obtained through
MODEM_INFO - Network information always supplied by the caller through
request.net_info
It also appears that device-status encoding calls get_modem_info() whenever a non-null modem-info structure is provided, even when its device, network, and sim fields are all NRF_CLOUD_INFO_NO_CHANGE. Avoiding that query may be another useful optimisation.
Should I raise this in the Github SDK repo, or is DevZone appropriate?
