nRF Academy Intermediate Course - Lesson 1 Exercise 1: Issue with Debugging
I tried following the exercise until the part where you start a debugging session. I looked at the thread viewer and the result was different than what was on the exercise. The picture below shows that the running thread is the idle thread instead of the main thread. Execution is supposed to break by default at main(). I tried manually putting a breakpoint in the main function but it didn't work either.
After that I tried changing the build configuration and unchecked "Include debug thread information". Somehow this fixed the problem. The result I'm getting in the thread viewer matches what's on the exercise. I can still see the thread names and stack usage even with the "Include debug thread information" unchecked.
Edit: I continued the exercise and am unable to see the details of the message queue in the watch list like in the exercise. Could this be because I unchecked "Include debug thread information"?
  • Hello Edvin,
    The watch list looks the same as what you have. In the previous post, I put both device_message_queue and &device_message_queue just to see if it made a difference. I want the watch list to look like the picture below from the nRF Intermediate course.
    Here is the output from generating support information.
      "platform": {
        "os": "win32",
        "osVersion": "Windows 10 Pro",
        "osKernel": "10.0.19045",
        "vscode": "1.143.0",
        "electron": "43.7.7",
        "node": "v24.21.0",
        "appName": "Visual Studio Code",
        "appHost": "desktop"
      "system": {
        "date": "2026-10-28T22:48:08.499Z",
        "vscodeRoot": "c:\\Users\\Brian\\AppData\\Local\\Programs\\Microsoft VS Code\\2d0b7506a3\\resources\\app",
        "vscodeUptime": "00:26:16",
        "osUptime": "1004:30:49",
        "cpu": "AMD Ryzen 5 PRO 4650U with Radeon Graphics"
      "workspace": {
        "name": "l1_e1_sol",
        "workspaceFile": null,
        "folders": [
          "c:\\nordicfw\\ncsinter\\l1_e1_sol"
      "sdks": [
          "version": "v3.4.1",
          "path": "c:\\ncs\\v3.4.1",
          "active": true
      "activeBuild": "/nordicfw/ncsinter/l1_e1_sol/build/l1_e1_sol",
      "apps": [
          "workspace": "c:\\nordicfw\\ncsinter\\l1_e1_sol",
          "uri": "c:\\nordicfw\\ncsinter\\l1_e1_sol",
          "buildConfigurations": [
              "id": "/nordicfw/ncsinter/l1_e1_sol/build",
              "name": "build",
              "boardId": "nrf54l15dk/nrf54l15/cpuapp",
              "type": "Sysbuild",
              "isChild": false,
              "isStale": false,
              "taskBindings": {
                "build": [],
                "pristineBuild": [],
                "flash": [],
                "eraseAndFlash": []
              "sdk": "c:\\ncs\\v3.4.1",
              "toolchain": "nRF Connect SDK Toolchain v3.4.1"
              "id": "/nordicfw/ncsinter/l1_e1_sol/build/l1_e1_sol",
              "name": "build/l1_e1_sol",
              "type": "Zephyr",
              "isChild": true,
              "isStale": false,
              "taskBindings": {
                "build": [],
                "flash": [],
                "eraseAndFlash": []
      "toolchains": [
          "path": "c:\\ncs\\toolchains\\4f5b6ad6dd",
          "displayName": "nRF Connect SDK Toolchain v3.4.1",
          "compilerTools": [
            "Zephyr SDK (arm) 1.0.1",
            "Zephyr SDK (riscv) 1.0.1"
          "active": true
      "connectedDevices": [
          "serialNumber": "001057749757",
          "boardVersion": "PCA10156",
          "deviceFamily": "NRF54L_FAMILY",
          "deviceName": "nRF54L15",
          "deviceVersion": "NRF54L15_xxAA_REV2",
          "jlinkDeviceNames": {
            "NRFDL_DEVICE_CORE_APPLICATION": "nRF54L15_M33",
            "NRFDL_DEVICE_CORE_FLPR": "nRF54L15_RV32"
          "jlinkObFirmwareVersion": "J-Link OB-nRF5340-NordicSemi compiled Jun 11 2026 13:12:28",
          "protectionStatus": "NRFDL_PROTECTION_STATUS_NONE",
          "protectionStatusCore": "NRFDL_DEVICE_CORE_APPLICATION"
      "tools": {
        "_": "Toolchain: nRF Connect SDK Toolchain v3.4.1",
        "C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\zephyr-sdk\\gnu\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "1.0.1",
        "C:\\Program Files\\SEGGER\\JLink_V982\\JLink.exe": "9.82",
        "nrfjprog": "not needed",
        "C:\\ncs\\toolchains\\4f5b6ad6dd\\nrfutil": "8.1.1",
        "C:\\ncs\\toolchains\\4f5b6ad6dd\\nrfutil\\home\\bin\\nrfutil-device.exe": "2.20.0",
        "C:\\ncs\\toolchains\\4f5b6ad6dd\\cmake": "4.2.1",
        "C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\bin\\Scripts\\west.exe": "1.5.0",
        "C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\bin\\python.exe": "3.12.4",
        "C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\bin\\ninja.exe": "1.13.2",
        "C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\bin\\gperf.exe": "3.1",
        "C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\bin\\dtc.exe": "1.4.7",
        "C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\bin\\gn.exe": "2223",
        "C:\\ncs\\toolchains\\4f5b6ad6dd\\mingw64\\bin\\git.exe": "git version 2.52.0.",
        "debugger (arm)": "c:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\zephyr-sdk\\gnu\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe",
        "debugger (riscv)": "c:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\zephyr-sdk\\gnu\\riscv64-zephyr-elf\\bin\\riscv64-zephyr-elf-gdb.exe"
      "nrfutil": {
        "nrfutil-device": {
          "version": "2.20.1",
          "binPath": "c:\\Users\\Brian\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2026.9.2823-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device",
          "jlinkInfo": {
            "description": "This version of SEGGER J-Link is different from the J-Link version that was used to test nrfutil device commands",
            "expectedVersion": {
              "version": "JLink_V9.24a",
              "versionFormat": "string"
            "name": "JlinkARM",
            "version": "JLink_V9.82",
        "nrfutil-sdk-manager": {
          "version": "1.16.1",
          "binPath": "c:\\Users\\Brian\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2026.9.2823-win32-x64\\platform\\nrfutil\\bin\\nrfutil-sdk-manager"
      "environment": {
        "_": "SDK: c:\\ncs\\v3.4.1, Toolchain: nRF Connect SDK Toolchain v3.4.1",
        "westEnv": {
          "HOME": "C:\\Users\\Brian",
          "HOMEDRIVE": "C:",
          "HOMEPATH": "\\Users\\Brian",
          "PATH": "C:\\ncs\\toolchains\\4f5b6ad6dd;C:\\ncs\\toolchains\\4f5b6ad6dd\\mingw64\\bin;C:\\ncs\\toolchains\\4f5b6ad6dd\\bin;C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\bin;C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\bin\\Scripts;C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\nanopb\\generator-bin;C:\\ncs\\toolchains\\4f5b6ad6dd\\nrfutil\\bin;C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\zephyr-sdk\\gnu\\arm-zephyr-eabi\\bin;C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\zephyr-sdk\\gnu\\riscv64-zephyr-elf\\bin;c:\\Users\\Brian\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2026.9.2823-win32-x64\\platform\\nrfutil\\lib\\nrfutil-sdk-manager;C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\MATLAB\\R2018a\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\Git\\cmd;C:\\Users\\Brian\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\Brian\\.nrfutil;C:\\Users\\Brian\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\Brian\\AppData\\Local\\Programs\\Microsoft VS Code\\bin\\copilot-shim",
          "ZEPHYR_BASE": "c:\\ncs\\v3.4.1\\zephyr",
          "ZEPHYR_SDK_INSTALL_DIR": "c:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\zephyr-sdk",
          "PYTHONPATH": "C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\bin;C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\bin\\Lib;C:\\ncs\\toolchains\\4f5b6ad6dd\\opt\\bin\\Lib\\site-packages"
        "inherited": {
          "HOMEDRIVE": "C:",
          "Path": "C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\MATLAB\\R2018a\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\Git\\cmd;C:\\Users\\Brian\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\Brian\\.nrfutil;C:\\Users\\Brian\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\Brian\\AppData\\Local\\Programs\\Microsoft VS Code\\bin\\copilot-shim",
          "PATH": "C:\\Windows\\system32;C:\\Windows;C:\\Windows\\System32\\Wbem;C:\\Windows\\System32\\WindowsPowerShell\\v1.0\\;C:\\Windows\\System32\\OpenSSH\\;C:\\Program Files\\MATLAB\\R2018a\\bin;C:\\Program Files\\dotnet\\;C:\\Program Files\\Git\\cmd;C:\\Users\\Brian\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\Brian\\.nrfutil;C:\\Users\\Brian\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Users\\Brian\\AppData\\Local\\Programs\\Microsoft VS Code\\bin\\copilot-shim"
      "terminal": {
        "defaultProfile": null
      "config": {
          "ozonePath": "",
          "applications": [],
          "applicationOptions": {},
          "west": {
            "env": {
              "$base": "terminal"
            "verbose": ""
          "boardRoots": [],
          "taskBindings": {},
          "buildTerminal": {
            "condensedProgress": true
          "debugging": {
            "flash": true,
            "bindings": {},
            "justMyCode": false,
            "focusOnNrfDebug": true,
            "logging": "default"
          "flash": {
            "softreset": false,
            "erase": false,
            "recover": false
          "enableTelemetry": false,
          "thirdpartyIntegration": {},
          "toolchainManager": {
            "indexURL": null,
            "installDirectory": null
          "sdkManager": {
            "region": "default"
          "defaultOpenAction": "ask",
          "terminalProfile": {
            "shell": {}
          "remoteDevices": [],
          "buildLogs": {
            "numberOfLogs": 1,
            "timestamped": true
          "mcp": {
            "local": {
              "enabled": true
          "topdir": "${nrf-connect.sdk:2.8.0}"
          "terminalMode": "character",
          "localEcho": false
      "extensions": {
        "internal": {
            "version": "2026.9.2823",
            "path": "c:\\Users\\Brian\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2026.9.2823-win32-x64",
            "isActive": true
            "version": "2026.9.409",
            "path": "c:\\Users\\Brian\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2026.9.409",
            "isActive": true
            "version": "2026.9.977",
            "path": "c:\\Users\\Brian\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2026.9.977",
            "isActive": true
            "version": "2026.9.358",
            "path": "c:\\Users\\Brian\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2026.9.358",
            "isActive": true
        "external": {
          "marus25.cortex-debug": null,
          "ms-vscode.cpptools": "1.34.4",
          "TypeScriptTeam.jsts-chat-features": "0.0.4",
          "ms-vscode.js-debug": "1.140.0",
          "ms-vscode.vscode-js-profile-table": "1.0.11",
          "KyleMicallefBonnici.dts-lsp": "0.14.2",
          "trond-snekvik.gnu-mapfiles": "1.1.0"
  • Hi, we are preparing an October release of the vscode extension with fixes to the debugger. It should correctly stop in `main` now. It also fixes some minor issues with thread viewer and memory viewer.
    The setting "include debug thread information" is critical for the thread viewer to work. This setting enables the KConfig option CONFIG_DEBUG_THREAD_INFO so zephyr writes the thread info into the code. Without it, the thread viewer doesn't know where to get information about threads.
    When you are debugging, you should also set the "Optimization level" to "Optimize for debugging experience" or "no optimization", otherwise the code is shrunk to not match the source (stepping will be confusing) and important debug symbols will be missing from the .elf file.
    "Sometimes if I just edit the build configuration it will keep telling me to do a pristine build even after doing a pristine build already."
    This sounds like a bug, if you are able to tell me which setting you changed, we can look into fixing it. Usually it means the build output is not matching the sources, or some file changed in the build folder.
    "I usually just press debug without flashing after making changes"
    If you click Debug in the actions menu, it will also build and flash. If you change the code or settings, it is recommended to flash so your IDE is not using an elf that does not match the firmware running on the board.
    "I used the application name below the build folder (bottom red arrow) when I started the debugging session and I also do the same for flashing. Is there a difference between using one vs the other?"
    Not for debugging, either one is fine.
    Kristian from the nRF Connect for VSCode team
  • This tree structure is not possible to achieve right now. You have to downgrade to a version older than 2026.9.2797 as that replaced Microsoft MIEngine with a new debug adapter, and we do not have full feature parity yet. We will put this in the backlog so a future release may add tree views for watches.
  • Good news, we will actually squeeze in this feature last minute, so watched variables can expand in the tree view! Look out for the October release tomorrow.
  • Hello Kristian,
    The new update worked, I can expand the variable in the watch list now. I'm also able to edit and then build the build configuration without it constantly telling me to do a pristine build. It also correctly stops at main whereas before it was sometimes inconsistent.
    There's just one very minor problem. The thread viewer doesn't show any threads when you first run the debugger but it does show up once you start stepping.
    Thank you so much for this update!
