nrf5340 audio occurred audio interruption when connected to RTT
I am using nrf5340 audio sample with the custom board. The nRF Connect SDK version I used is v3.4.0.
I added the following settings to prj.conf so that the custom board would work.
CONFIG_CLOCK_CONTROL_NRF_K32SRC_RC_CALIBRATION=y
CONFIG_CLOCK_CONTROL_NRF_K32SRC_SYNTH=y
I burned the BIS TX program to a custom board, and the following log appeared.
GW [00:01:22.299,621] <inf> bt_le_audio_tx: Data provided too fast. May happen for sync USB. time_diff_us:  14753 (not in range: 14700 - 3000)
GW [00:01:26.349,670] <inf> bt_le_audio_tx: Data provided too fast. May happen for sync USB. time_diff_us:  14705 (not in range: 14700 - 3000)
GW [00:01:30.299,621] <inf> bt_le_audio_tx: Data provided too fast. May happen for sync USB. time_diff_us:  14735 (not in range: 14700 - 3000)
GW [00:01:34.439,514] <inf> bt_le_audio_tx: Data provided too fast. May happen for sync USB. time_diff_us:  14842 (not in range: 14700 - 3000)
GW [00:01:38.369,506] <inf> bt_le_audio_tx: Data provided too fast. May happen for sync USB. time_diff_us:  14832 (not in range: 14700 - 3000)
At this point, the BIS RX output at the receiving end exhibits intermittent audio output.
When I connect to RTT to view the log, the BIS Rx audio completely cuts out, which seems to be due to a sync loss.
What methods can I use to improve this problem?
