Thingy:53 Zigbee End Device — Configure Reporting failures + malformed Report Attributes flood
On a custom Zigbee End Device application for the Thingy:53 (NCS v2.9.3), ZCL Configure Reporting commands sent by Zigbee2MQTT are rejected with ZCL status FAILURE for almost every cluster/attribute except Temperature Measurement and two genOnOff instances, even though the attribute descriptors, endpoint declarations and reporting-context sizing all look correct against the ZBOSS headers. Separately, the device spontaneously and continuously emits malformed Report Attributes frames for msRelativeHumidity (~8 msg/s, confirmed to survive a full device power-cycle), independent of whatever reporting configuration is active. We've ruled out everything visible from prj.conf, the ZBOSS module's own Kconfig, and our application source — the remaining behaviour appears to be inside the precompiled ZBOSS reporting engine.
Environment
Board
Thingy:53 (nRF5340)
SDK
nRF Connect SDK v2.9.3, ZBOSS production libraries
Zephyr
v3.7.99-ncs2-3
Role
Zigbee End Device
Coordinator / gateway
Zigbee2MQTT (external converter), zigbee-herdsman
App
Custom multi-endpoint sensor app — 7 endpoints
Endpoint / cluster map:
EP
Clusters
Reportable attributes
10 (env)
Basic, Identify, msTemperatureMeasurement, msPressureMeasurement, msRelativeHumidity, msIlluminanceMeasurement, genPowerCfg
temp, pressure, humidity, illuminance, battery voltage/percentage
11 (imu)
custom 0xFC01, genBinaryInput
6 custom float attrs, motion (boolean)
12 (mag)
custom 0xFC02
4 custom float attrs
13 (air)
custom 0xFC03
3 custom float attrs
30 (light)
genOnOff, genLevelCtrl, custom 0xFC04
onOff (boolean), currentLevel (uint8)
31 (buzzer)
genOnOff
onOff (boolean)
32 (cfg)
custom 0xFC05
(write-only config, not reported)
Each custom endpoint is built with a small macro (ZB_DECLARE_CUSTOM_EP) wrapping ZB_AF_DECLARE_ENDPOINT_DESC() + ZBOSS_DEVICE_DECLARE_REPORTING_CTX(ctx, 8) — 8 reporting slots per endpoint, well above the 1–6 reportable attributes any single endpoint actually has.
Symptom 1 — Configure Reporting rejected with ZCL status FAILURE for most clusters
After joining, our Z2M external converter's configure() runs ~17 bind + Configure Reporting + Read commands across the 7 endpoints. In a log capture triggered by an explicit bridge/request/device/configure MQTT request (bypassing Z2M's own reconfigure-gating, so we know for certain this actually executed on the device), the device responded:
msTemperatureMeasurement.configReport([{attribute:'measuredValue', minimumReportInterval:10, maximumReportInterval:300, reportableChange:10}])  -> SUCCESS
msRelativeHumidity.configReport([{attribute:'measuredValue', minimumReportInterval:0xFFFF, maximumReportInterval:0xFFFF, reportableChange:0}])   -> FAILURE
msPressureMeasurement.configReport([{attribute:'measuredValue', minimumReportInterval:10, maximumReportInterval:300, reportableChange:1}])        -> FAILURE
msIlluminanceMeasurement.configReport([{attribute:'measuredValue', minimumReportInterval:10, maximumReportInterval:300, reportableChange:1}])     -> FAILURE
genPowerCfg.configReport([{attribute:'batteryPercentageRemaining', minimumReportInterval:60, maximumReportInterval:3600, reportableChange:1}])   -> FAILURE
64513 (custom IMU cluster).configReport([...6 float attrs...])        -> FAILURE
64514 (custom MAG cluster).configReport([...4 float attrs...])        -> FAILURE
64515 (custom AIR cluster).configReport([...3 float attrs...])        -> FAILURE
genBinaryInput.configReport([{attribute:'presentValue', minimumReportInterval:0, maximumReportInterval:300, reportableChange:1}])                -> FAILURE
genLevelCtrl.configReport([{attribute:'currentLevel', minimumReportInterval:0, maximumReportInterval:300, reportableChange:1}])                  -> FAILURE
genOnOff.configReport([{attribute:'onOff', minimumReportInterval:0, maximumReportInterval:300, reportableChange:0}])  (light, EP30)              -> SUCCESS
genOnOff.configReport([{attribute:'onOff', minimumReportInterval:0, maximumReportInterval:300, reportableChange:0}])  (buzzer, EP31)             -> SUCCESS
Initially this looked like "only the first Configure Reporting call per endpoint in a burst succeeds, every later one fails" (temperature was 1st on EP10, both onOff calls were the only/1st call on their endpoints). We tested this directly:
  • Added a 300 ms delay after every individual bind/configureReporting/read step (not just between endpoint blocks) — made zero difference, identical failures, even though the whole sequence now took ~10x longer. This rules out a command-queue/timing race.
  • Reordered so msPressureMeasurement is sent FIRST on EP10 (before temperature) and genLevelCtrl FIRST on EP30 (before onOff) — in that run, pressure succeeded in that position, but genLevelCtrl still failed even as the first command sent to its endpoint, and critically, even the calls that stopped showing FAILURE still never produced live attribute reports in Home Assistant/Z2M afterwards. So "no FAILURE status" does not reliably mean the device's reporting engine is actually scheduling/sending reports for that attribute.
Symptom 2 — Malformed, continuous Report Attributes flood for msRelativeHumidity
Independent of the above, the device continuously emits a Report Attributes frame for msRelativeHumidity's measuredValueroughly every 120 ms (~8.35 msg/s), confirmed via zigbee-herdsman's Failed to parse frame errors and Zigbee2MQTT's own Health page message-rate counter (which matched almost exactly). This is not throttled by minimumReportInterval/maximumReportInterval in any configuration we've sent.
Decoded byte-for-byte from the raw payload ("data":[12,0,0,<seq>,10], <seq> incrementing as expected):
Byte
Value
Meaning
0
0x0C
ZCL frame control: global command, direction server→client, Manufacturer-Specific bit incorrectly SET
1–2
0x00 0x00
Consumed as a (bogus, always-zero) manufacturer code, because of the MS bit above
3
<seq>
Transaction sequence number — correct, increments normally
4
0x0A
Command ID = Report Attributes — correct
(none)
Buffer ends here — attribute ID / type / value payload is completely missing
zigbee-herdsman correctly rejects this as unparseable (RangeError [ERR_OUT_OF_RANGE] ... offset is out of range). This is not a herdsman/Z2M bug — the frame genuinely is malformed/truncated as transmitted by the device.
Tested and ruled out:
  • Simply no longer requesting this attribute's reporting — flood continues unchanged (an already-active device-side report isn't cancelled by not re-asking for it).
  • Explicitly sending the ZCL spec's "deactivate reporting" sentinel (minimumReportInterval = maximumReportInterval = 0xFFFF) — confirmed delivered to the device (via an explicit MQTT-triggered Reconfigure), initially rejected with FAILURE; on a later attempt it was accepted (SUCCESS), but the flood continued completely unaffectedeven after the deactivation command was accepted.
  • Full device power-cycle (not a reflash — just power off/on) — flood resumed at an unchanged rate (~7.8 msg/s measured over a 5-minute post-boot window), ruling out any theory involving corrupted/stale RAM state accumulated across repeated test rounds. This reproduces identically from a cold boot.
What we've already ruled out
  • Attribute access flags. Compared the ZBOSS header macros for Temperature/Pressure/Humidity/Illuminance's MeasuredValue descriptors byte-for-byte — all four are declared identically (ZB_ZCL_ATTR_ACCESS_READ_ONLY | ZB_ZCL_ATTR_ACCESS_REPORTING, non-manufacturer-specific). Not a permissions issue.
  • Per-endpoint reporting slot table size. ZBOSS_DEVICE_DECLARE_REPORTING_CTX(ctx, 8) — 8 slots per endpoint, no endpoint has more than 6 reportable attributes. zb_zcl_reporting.h and zboss_api_af.h confirm rep_info_count/reporting_info are genuinely per-endpoint fields ("moved here from device descriptor"), correctly wired via ZB_AF_DECLARE_ENDPOINT_DESC().
  • Device-context structure. In this ZBOSS version, zb_af_device_ctx_t (zboss_api_zcl.h) only has ep_count/ep_desc_list — no device-wide reporting fields exist that could be mis-set.
  • Command ordering / timing / device radio queue. A 300 ms delay after every individual step made no difference (see Symptom 1); reordering which cluster is sent first on an endpoint also didn't produce a consistent "first always succeeds" pattern.
  • prj.conf / prj_release.conf. No Zigbee/ZCL/reporting-related Kconfig tunable of any kind — only library/driver enables (CONFIG_ZIGBEE=y, CONFIG_ZIGBEE_ROLE_END_DEVICE=y, CONFIG_ZIGBEE_USE_SOFTWARE_AES=y, CONFIG_ZIGBEE_CHANNEL_SELECTION_MODE_MULTI=y, sensor/ADC/PWM/log/USB settings).
  • ZBOSS module's own Kconfig (nrfxlib/zboss/Kconfig, read in full) — only offers library-variant selection (production / development / ZIGBEE_ENABLE_TRACES debug libraries) and Green Power feature set. Nothing reporting-related.
  • Our own sensor-push application code. zb_device_update_env() (the function that calls zb_zcl_set_attr_val() for temp/pressure/humidity/illuminance every sampling cycle) treats all four attributes with the byte-for-byte identical call pattern. The periodic sampling loop (ZB_SCHEDULE_APP_ALARM-based self-reschedule) pushes fresh values for every sensor unconditionally, every cycle, with no attribute special-cased or skipped.
Minimal repro
The endpoint/cluster declaration pattern (same for every endpoint, only cluster IDs differ):
#define RO_REPORTABLE (ZB_ZCL_ATTR_ACCESS_READ_ONLY | ZB_ZCL_ATTR_ACCESS_REPORTING)
ZB_ZCL_DECLARE_PRESSURE_MEASUREMENT_ATTRIB_LIST(pressure_attr_list, &env_ctx.pres_measure_value,
                                                 &env_ctx.pres_min_measure_value,
                                                 &env_ctx.pres_max_measure_value,
                                                 &env_ctx.pres_tolerance);
static zb_zcl_cluster_desc_t env_cluster_list[] = {
  /* ... Basic, Identify, Temp ... */
  ZB_ZCL_CLUSTER_DESC(ZB_ZCL_CLUSTER_ID_PRESSURE_MEASUREMENT,
                       ZB_ZCL_ARRAY_SIZE(pressure_attr_list, zb_zcl_attr_t),
                       (pressure_attr_list), ZB_ZCL_CLUSTER_SERVER_ROLE,
                       ZB_ZCL_MANUF_CODE_INVALID),
  /* ... Humidity, Illuminance, PowerConfig ... */
#define ZB_DECLARE_CUSTOM_EP(ep_var, ep_id, n_in, cluster_list_arr, ...)                 \
  ZB_AF_SIMPLE_DESC_TYPE(n_in, 0) simple_desc_##ep_var = { ep_id, ZB_AF_HA_PROFILE_ID,    \
    ZB_HA_CUSTOM_ATTR_DEVICE_ID, 0, 0, n_in, 0, { __VA_ARGS__ } };                        \
  ZBOSS_DEVICE_DECLARE_REPORTING_CTX(reporting_info_##ep_var, 8);                         \
  ZB_AF_DECLARE_ENDPOINT_DESC(ep_var, ep_id, ZB_AF_HA_PROFILE_ID, 0, NULL,                \
    ZB_ZCL_ARRAY_SIZE(cluster_list_arr, zb_zcl_cluster_desc_t), cluster_list_arr,         \
    (zb_af_simple_desc_1_1_t *)&simple_desc_##ep_var, 8, reporting_info_##ep_var, 0, NULL)
ZB_DECLARE_CUSTOM_EP(env_ep, EP_ENV, 7, env_cluster_list,
                      ZB_ZCL_CLUSTER_ID_BASIC, ZB_ZCL_CLUSTER_ID_IDENTIFY,
                      ZB_ZCL_CLUSTER_ID_TEMP_MEASUREMENT, ZB_ZCL_CLUSTER_ID_PRESSURE_MEASUREMENT,
                      ZB_ZCL_CLUSTER_ID_REL_HUMIDITY_MEASUREMENT,
                      ZB_ZCL_CLUSTER_ID_ILLUMINANCE_MEASUREMENT, ZB_ZCL_CLUSTER_ID_POWER_CONFIG);
Steps:
  1. Flash the app, pair with Zigbee2MQTT.
  2. From the coordinator, bind + send Configure Reporting for msTemperatureMeasurement.measuredValue — succeeds, and periodic reports arrive correctly.
  3. Bind + send Configure Reporting for msPressureMeasurement.measuredValue with the same shape of request — device responds with ZCL status FAILURE (or, in some runs, SUCCESS but with no periodic reports ever actually sent).
  4. Observe msRelativeHumidity spontaneously emitting malformed Report Attributes frames (data: [0x0C, 0x00, 0x00, <seq>, 0x0A]) at ~8/s, with no Configure Reporting ever having been accepted for it, and unaffected by sending the 0xFFFF/0xFFFF deactivation command or power-cycling the device.
Questions
  1. Is there a known limitation in ZBOSS v2.9.3's production libraries on how many distinct clusters/attributes a single endpoint (or the whole device) can have actively reporting at once, beyond the application-supplied ZBOSS_DEVICE_DECLARE_REPORTING_CTX() slot count — something not exposed via Kconfig or the public headers?
  2. Is Configure Reporting known to behave differently for genOnOff/msTemperatureMeasurement versus other standard clusters (e.g. msPressureMeasurement, genPowerCfg, genLevelCtrl, genBinaryInput) on an End Device role specifically?
  3. Could a stale/corrupted reporting-table entry on the device explain the msRelativeHumidity frame corruption (Manufacturer-Specific bit set when it shouldn't be) even across a full power-cycle — or does that point at something else entirely (e.g. the attribute's type/size metadata)?
  4. Is CONFIG_ZIGBEE_ENABLE_TRACES the right path to get actionable binary traces for this, and if so, what's the expected workflow for submitting them against a support ticket?
  5. Are there any known issues in this ZBOSS version specific to ZB_ZCL_CLUSTER_SERVER_ROLE_INIT = NULL for custom manufacturer-range clusters (0xFC01–0xFC05) interacting with the reporting engine, versus a built-in cluster with a real init function?
Happy to provide the full src/ tree, .mjs converter, and raw Z2M debug logs on request.
    There is no specific limit for the amount of clusters or attributes on a single endpoint, but there is a limit on the amount of bindings allowed. These limit are configured in memory config files (zb_mem_config_med.h, *_min.h, and *_max.h). If you need different configurations than the defaults, you can create a custom memory config file. This is an advanced feature, and it is documented here: https://ncsdoc.z6.web.core.windows.net/zboss/3.11.6.0/zigbee_mem_cfg_feature_ram.html#zigbee_mem_cfg_ram_feature_sizes
    At this point this is not a familiar phenomenon. However, sniffing the network traffic and studying the packets may shed some lights on what is going wrong and if there are differences in the traffic between the clusters which are working as expected and the ones which are not.
    If you are unfamiliar with how to perform sniffer traces, please refer to our guide here: https://docs.nordicsemi.com/r/bundle/ug_sniffer_802154/page/ug/sniffer_802154/intro_802154.html. Make sure to start the sniffer before starting the network to be able to decrypt the packets. Or if you know the network key, you can add that to the network key list in Wireshark to decrypt the packets.
    Please upload the sniffer log as a .pcap file in a reply with the Insert->Image/video/file option.
    This is a feasible hypothesis, as the reporting config is saved in NVRAM (ZB_NVRAM_ZCL_REPORTING_DATA), which persists across power cycles and has to be manually deleted from ZB_NVRAM_ZCL_REPORTING_DATA to be removed. Though again, a sniffer trace should be able to shed some more lights on what exactly is going wrong.
    Before collecting a binary trace, let's start with the sniffer trace. If the sniffer trace is not sufficient to figure out what is going wrong, please follow steps 1-3 here to configure binary trace logging. Regarding sharing the binary trace logs with us, upload a file similarly as for the sniffer trace option. If the file size is too large, try to compress and share the .zip (or other archive format).
    I don't quite understand what you mean with "ZB_ZCL_CLUSTER_SERVER_ROLE_INIT = NULL", since the value for ZB_ZCL_CLUSTER_SERVER_ROLE_INIT should be the initialization function for the relevant cluster. Are you using a cluster which does not need any handler or initialization clusters? Please elaborate so I can understand what you are asking here.
    If your custom clusters should have initialization clusters, please use standard clusters which are similar to your custom clusters and compare intialization procedures between them.
    Maria
  • hi Maria,
    thanks for getting back to me again.
    Update — root cause of the main symptoms found, one cosmetic issue remains.
    Thank you for pointing at the NVRAM. That was the key. After forcing zigbee_erase_persistent_storage(ZB_TRUE) for a single boot (NCS 2.9.3, Thingy:53) and re-pairing:
    • The msRelativeHumidity flood (~8 msg/s, malformed frames with the Manufacturer-Specific bit set) is gone. Humidity now reports as configured (min 10 s / max 300 s / change 1 %RH), and the frames are well-formed (manufacturerSpecific:false, uint16).
    • Configure Reporting now returns status 0 for 11 of 12 requests, where most of them used to fail (pressure, temperature, humidity, illuminance, battery, binary input, level control, both on/off). Binding was never the problem: all 12 Bind responses were SUCCESS in the earlier logs.
    So a stale ZB_NVRAM_ZCL_REPORTING_DATA, persisted across many firmware images with different endpoint/cluster layouts, was the cause. We do not know the exact mechanism (occupied slots vs. an invalid record), but it survived power cycles and DFU updates, as you said.
    Remaining (probably cosmetic) issue. For our custom manufacturer clusters 0xFC01–0xFC03 (float attributes, type 0x39, reportableChange 0.1f), Configure Reporting often returns status 0x01 (FAILURE), but the response records contain uninitialised bytes: direction=0xCD, attrId=0xCCCC (this looks like pieces of the request’s 0.1f = CD CC CC 3D) and direction=0x0A, attrId=0x2C00 (pieces of min=10 / max=300). The result is not size-dependent: the same 4-record request succeeded right after the NVRAM erase and fails on a later Reconfigure, and a 1-record request for the same cluster succeeded.
    Despite the FAILURE response, the device does send Report Attributes for these clusters, which suggests the configuration is applied. Our firmware samples every 60 s, and reports arrive once per sampling cycle for attributes whose value changed by more than the configured 0.1, while an attribute that stayed constant was not reported again. That looks like change-driven reporting, which would need an active reporting record. So this looks like a bug in how the failure response is built, and possibly in the update path of an existing reporting record for float attributes.
    Question: is this a known issue in ZBOSS (NCS 2.9.3) for analog (float) attributes in custom clusters? We cannot do a sniffer capture, but we can provide the Z2M debug logs with the exact request and response frames if that helps.
    Regarding ZB_ZCL_CLUSTER_SERVER_ROLE_INIT = NULL: that applies only to our 5 custom clusters (0xFC01–0xFC05), where we define the init macros as (zb_zcl_cluster_init_t)NULL. All standard clusters use the built-in definitions.
    thanks for your help again,
    Gabor,
