How do I integrate the nRF51/nRF52 in my Unity based Android Application?
I've been using a HC-05 (bluetooth v2.0) to communicate between my Unity-Android app and my Arduino microcontroller. It's working fine, however, if my prototype continues to advance (or go into production), I want to use the nrf51.
Does anyone know any plugins, libraries or articles / blog posts for communicating between a Unity built application and the nRF51?
So far I've been relying on the Unity's 'Android & Microcontrollers / Bluetooth' extension library, tweaking it here and there, but I'm not sure how will this perform if I exchange the HC-05 with the nRF51422.
Technical specifications — if helps with getting a better answer, otherwise, ignore this: I'm using the bluetooth in slave mode. I am using Serial Port as the communication method — as far as I know, Unity only accepts Serial (please correct me on this). My priority is on data reaction time — sending 8 bytes every 20ms. Not intended for desktop, only Android and iOS only.
  • Hi, how did you get the serial communication between Android Unity app and an Arduino board using a HC-05 module? I want to achieve the exact same thing, but I don't know the portName for Android devices? How did you do it?
  • It was a long time ago, so I apologise for not having a very precise answer. From what I remember, the way you connect and communicate via bluetooth 2 to MacOS, iOS, Android and Windows was different. So you have to split your code for each of the 4 cases. For Android, if I remember correctly, the Port Name was just the name of the module itself (eg: "HC-05" or whatever you named your device to show up on your phone). Another alternative is to get the MAC address of your module and connect via mac — if you don't plan on mass manufacturing and it's just a one time project, MAC should be simpler and easier to manage. Good luck!
