is nRF54 able to use CTRL-AP to reset itself?
I'm aware of https://devzone.nordicsemi.com/f/nordic-q-a/125252/reset-over-ctrl-ap/555253?focus=true
Is it possible for an nRF54 to safely use the CPU access to the AP registers to induce a pin reset on its own as an alternative to triggering a WDR?
I'm looking for software ways to cause the chip to reset to handle the edgecase of a poorly configured watchdog that is locked out.
TAMPC, WDR, and CTRL-AP resets appear to be sufficient to correct this based on the datasheet.  I would not be able to drive a pin reset externally in this situation.
The results from your AI support the idea that this connection exists and can be used, but caveats the safety question:
Based on the knowledge sources, yes — the nRF54L series does expose a CPU-side CTRL-AP RESET register (at peripheral address offset 0x520) that can be written directly by the CPU (not just by an external debugger).
The CPU-side RESET register supports the following values:
Value ID Value Description
NoReset 0 No reset is generated
SoftReset 1 Perform a device soft reset
HardReset 2 Perform a device hard reset
PinReset 4 Perform a device pin reset
So writing 4 (PinReset) to the RESET register at base address 0x50052000 (secure) or 0x40052000 (non-secure) + offset 0x520 should trigger a pin reset from software, without needing an external signal or a watchdog.
A few important caveats the knowledge sources do not fully address, so I want to be transparent about limitations:
  • The knowledge sources confirm the register exists and is CPU-writable (W access), but do not explicitly describe any side effects, restrictions, or security/TrustZone gating that might prevent a non-secure or unprivileged context from writing it. You should verify whether TrustZone configuration restricts access to the secure (SCTRLAP) vs. non-secure (NS) instance.
  • The instance table shows both a secure (0x50052000) and non-secure (0x40052000) base address, so access from non-secure code may be possible depending on your configuration. [Register overview]
  • The knowledge sources do not confirm whether a CPU-initiated PinReset via this register is treated identically to a hardware pin reset in terms of reset domain behavior (e.g., whether it clears the same state as a true pin reset). You should cross-reference the full reset domain documentation in the datasheet to confirm it meets your requirements for clearing a locked watchdog configuration.
In summary: yes, writing PinReset (value 4) to the CPU-side CTRL-AP RESET register appears to be a valid software-initiated pin reset mechanism on the nRF54L15/L10/L05, and is a reasonable alternative to a WDT reset for your described edge case — but verify TrustZone access permissions and reset domain behavior in the full datasheet.
