Repurposing I2C Pins without Device PM
I'm working to write a Zephyr-compatible driver for the LP5814 on a board with a nRF5340. The LP5814 is an LED controller that receives commands over an I2C interface. There's a feature of the LP5814 that is proving to be difficult to implement because of how Zephyr controls access to the I2C bus.
The feature in question is the LP5814's low power mode. Entering it requires a simple I2C transaction, but leaving it involves a special sequence of edges on the SDA and SCL pins that belong to the I2C bus. See the timing diagram:
There's an alternate way to enter and exit low power mode, but it looks like it could be vulnerable to being activated with I2C traffic meant for other devices.
Multiple threads in my application access I2C devices. They go through the usual Zephyr-nrfx glue code, which involves a synchronization object so that only one thread can do a transaction at a time. Unfortunately, there isn't a way to acquire this lock without also enabling the I2C peripheral. It would be desired to acquire the lock while keeping the I2C peripheral disabled so that no other I2C-driven device driver could interrupt the wakeup procedure of the LP5814.
We're currently on Zephyr 3.4, so I looked ahead to newer releases to see if such functionality was added. I see that an "exclusive access" pair of functions was added in Zephyr's PR 86721, but it still uses the Device Power Manager get/put functions to drive pinctrl. If I'm not mistaken, I can't finesse pinctrl into respecting the GPIO configuration required for the LP5814 wakeup procedure.
github.com/.../86721
Currently, my work-around is to access the nrfx driver directly so I can shut off the I2C peripheral and reconfigure the pins to my desires, restoring the configurations and reactivating the I2C peripheral when finished. This workaround has to be wrapped in something like a scheduler disable, which feels awful.
I plan to make my application request all I2C operations through a new layer of firmware with a lock that doesn't interact with the Device Power Manager. In-between my main application logic and device drivers are HALs. I will make those HALs use the new layer so the lock is respected and so that I don't have to edit any of the drivers that comes with Zephyr or NCS. I'm worried that System Work Queue work from those drivers will not be able to respect the new design, though.
Is there something I seem to be missing? Is Zephyr/NCS just not really equipped to handle an I2C device that needs the SDA and SCL pins to be repurposed on occasion?
    Sorry for the delay. One of my colleagues suggested a solution that would most likely work fine. It is not going to make your LP5814 driver a generic zephyr driver but at least it would be somewhat clean.
    His solution is to use the new exclusive access API you mentioned in your initial message (link) and using the nrfx_twim API directly, following a similar approach to the one used by i2c_nrfx_twim_recover_bus().
    It would look something like this:
    static int lp5814_wakeup(void)
        ret = i2c_nrfx_twim_exclusive_access_acquire(dev, K_SECONDS(1)); /* wait for exclusive access or time out */
        if (ret) {
            return err
        nrfx_twim_disable(cfg->twim);                            /* releases the pins to GPIO */
        // TODO: bit bang wake up sequence. Do not use any i2c APIs here
       pinctrl_apply_state(cfg->pcfg, PINCTRL_STATE_DEFAULT);  /* restore pin configuration */
       nrfx_twim_enable(cfg->twim);
       i2c_nrfx_twim_exclusive_access_release(dev);
    I hope this helps a bit.
    If you have any question on this solution, feel free to ask.
    Simon
  • I suppose it follows that this solution requires the application to not use the pm_device_runtime_put/get() functions on the bus. We may have a reason for this in the future but for now we don't. We do it on a couple of our SPI buses.
    I think before releasing exclusive access on the LP5814's wakeup procedure I'd run the recover function to ensure the bus's devices aren't in a weird state.
    Thanks for your input, Simon.
    There may be a small misunderstanding here. If you want you can wrap your function with pm_device_runtime_put/get() but it simply doesn't make sense to do it.
    This is already handled inside the driver directly. For example, you can see it quite clearly in the exclusive_access functions (link).
    So using pm_device_runtime manually in your application, will just increment/decrement the counter twice. It most likely won't break anything, but it would be redundant.
    Simon
  • Ahhh, you're right. The exclusive access functions would bump the counter to 1, and regardless of how many gets/puts are done it should never go to zero, which is what causes GPIO configuration changes.
    The gets/puts would have to be unbalanced to cause an issue there. Thanks for the insight.
