NSIB + upgradable MCUboot: how can an SMP client read the running MCUboot version?
Setup:
  • nRF54L15 with NCS v3.4.1.
  • NSIB with MCUboot as an upgradable bootloader (S0/S1), built with sysbuild and no Partition Manager.
  • SMP over Bluetooth.
App and MCUboot updates both work. For the app, image list shows slot0: 1.0.0. For MCUboot, the only thing we can query is active_b0_slot, which gives the slot but no version. NSIB only uses the fw_info version, and the semver from SB_CONFIG_SECURE_BOOT_MCUBOOT_VERSION only appears in the update image's header. Copies programmed with west flash (signed_by_b0_mcuboot.hex) don't have that header.
Questions:
  1. What is the intended way for a mobile app to read which MCUboot version a device is running? Or should the backend just keep track of which MCUboot package it sent?
  2. After an MCUboot update, is checking that active_b0_slot changed the recommended way to confirm it worked?
  3. Can production program signed_by_mcuboot_and_b0_mcuboot.hex and its _s1_variant instead of signed_by_b0_*.hex, so the header and semver are there from the start?
Thanks!
    I don't know any good way to retrieve the bootloader version directly from another device. It looks like it is possible to get the version from the application though.
    So remembering the version with periodic updates from the application looks to be a decent way to do it.
    Checking that the slot has changed could indeed be a good confirmation that the updated happened.
    To be honest here, I've never tried to do it, but I don't really see why it wouldn't be possible.
    Let me confirm this internally, and I'll come back to you as soon as I have an answer.
    Simon
  • Thanks Simon. For context on point 3, we tried it on the nRF54L15 DK (NCS v3.4.1, sysbuild, no Partition Manager):
    - `west flash` programs `signed_by_b0_mcuboot.hex` / `signed_by_b0_mcuboot_s1_variant.hex`. `cmake/sysbuild/image_signing_b0.cmake` has a branch that would point the runner at `signed_by_mcuboot_and_b0_${SYSBUILD_NAME}.hex`. But it's inside `if(CONFIG_BOOTLOADER_MCUBOOT)`, which is never true for the MCUboot image itself (it has `CONFIG_MCUBOOT=y`), so that branch never runs. Is that intended?
    - We switched the runner to the `signed_by_mcuboot_and_b0_*` files with a sysbuild hook. NSIB boots both copies, and the version, image hash and key hash TLVs are present from the factory. An MCUboot update over SMP works afterwards, and NSIB still selects by fw_info version.
    - Case 119578 reported the same thing for `merged.hex` on NCS v2.7–2.9.
    Is there any reason production shouldn't program these files, for example a provisioning or NSIB validation step that expects the image without the header?
    Sorry, I'm actually a bit confused, I wasn't able to find anywhere in our documentation where it was said that this is something that should be avoided.
    When I read your question I assumed you read that somewhere in our doc. If it's the case can you please link me where we said that ?
    It actually seems like this is the intended way of doing it. In the output build files description the files signed only by NSIB are even considered intermediate outputs (link).
    Simon
  • Thanks Simon, we agree. The output build files page for v3.4.1 lists signed_by_b0_mcuboot.bin and signed_by_b0_s1_image.bin as "Intermediate file only signed by NSIB", and the signed_by_mcuboot_and_b0_* files as the MCUboot images.
    But then why does west flash program the intermediate signed_by_b0_*.hex files by default? cmake/sysbuild/image_signing_b0.cmake even has a branch that selects signed_by_mcuboot_and_b0_${SYSBUILD_NAME}.hex for the runner. It's inside if(CONFIG_BOOTLOADER_MCUBOOT), though, which is never true for the MCUboot image itself, so it never runs.
    Is that a bug, or is there a reason west flash should use the intermediate files?
    Sorry for the delay, I asked internally and I now a clearer idea of why this happens.
    So this is actually a cleaner way of doing it. The thing is that the MCUBoot signature is only used when MCUBoot is transferring the new MCUBoot image from slot1 to s1 or s0. Once the bootloader firmware is in the right place, MCUBoot signature is not checked anymore, only the NSIB one is checked.
    This means that it is actually a bit cleaner to do it like this as no unused bytes are transferred when writing the program for the first time as this is written directly to s0 and s1.
    So this is not a bug and is normal. If you flash directly to the device, then using signed_by_b0_mcuboot(_s1_variant).bin is cleaner but if you perform an update then the signed_by_mcuboot_and_b0_mcuboot(_s1_variant).bin has to be used.
    If you need more precision feel free to ask.
    Simon
