nRF Connect SDK Intermediate, Lesson 9, Exercise 4, problems with nrF53
Hi
SDK 3.4.1
Custom Board but with working USB-Interface from App
https://academy.nordicsemi.com/courses/nrf-connect-sdk-intermediate/lessons/lesson-9-bootloaders-and-dfu-fota/topic/exercise-4-dfu-over-usb/
If I configure it like described, I will get no USB-CDC device. The Serial port is present.
From my current understanding of mcuboot it is wrong to setup
STEP 1.1 - Configure serial recovery to use CDC_ACM, which by default uses the USB
CONFIG_MCUBOOT_SERIAL=y
CONFIG_BOOT_SERIAL_UART=y
It should be
CONFIG_BOOT_SERIAL_UART=n
CONFIG_BOOT_SERIAL_CDC_ACM=y
But with that I got an error:
2026-10-30T09:39:03.377Z C:/ncs/toolchains/4f5b6ad6dd/opt/zephyr-sdk/gnu/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/14.3.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr/subsys/usb/device_next/libsubsys__usb__device_next.a(usbd_cdc_acm.c.obj):C:/ncs/v3.4.1/zephyr/subsys/usb/device_next/class/usbd_cdc_acm.c:1386: multiple definition of `__device_dts_ord_190'; zephyr/libzephyr.a(cdc_acm.c.obj):C:/ncs/v3.4.1/zephyr/subsys/usb/device/class/cdc_acm.c:1229: first defined here
Is the usb-next driver not final in mcuboot for nrf53?
Best regards
John
  • For documentation:
    • Clean exercise 4
    • Changes as diff:
      diff --git a/l9/l9_e4/sysbuild.conf b/l9/l9_e4/sysbuild.conf
      index 277d0a0..3b3365f 100644
      --- a/l9/l9_e4/sysbuild.conf
      +++ b/l9/l9_e4/sysbuild.conf
      @@ -1,4 +1,5 @@
       # Add MCUboot
       SB_CONFIG_BOOTLOADER_MCUBOOT=y
      -SB_CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM=y
      +#Fix Build warning
      +SB_CONFIG_MCUBOOT_USE_ALL_AVAILABLE_RAM=n
      diff --git a/l9/l9_e4/sysbuild/mcuboot/boards/nrf5340dk_nrf5340_cpuapp.overlay b/l9/l9_e4/sysbuild/mcuboot/boards/nrf5340dk_nrf5340_cpuapp.overlay
      index 131d953..539601e 100644
      --- a/l9/l9_e4/sysbuild/mcuboot/boards/nrf5340dk_nrf5340_cpuapp.overlay
      +++ b/l9/l9_e4/sysbuild/mcuboot/boards/nrf5340dk_nrf5340_cpuapp.overlay
      @@ -7,4 +7,8 @@
       /* STEP 2.1 - Configure CDC ACM */
      +&zephyr_udc0 {
      +	cdc_acm_uart0: cdc_acm_uart0 {
      +		compatible = "zephyr,cdc-acm-uart";
      diff --git a/l9/l9_e4/sysbuild/mcuboot/prj.conf b/l9/l9_e4/sysbuild/mcuboot/prj.conf
      index e736ae2..366f8f3 100644
      --- a/l9/l9_e4/sysbuild/mcuboot/prj.conf
      +++ b/l9/l9_e4/sysbuild/mcuboot/prj.conf
      @@ -20,7 +20,8 @@ CONFIG_NCS_APPLICATION_BOOT_BANNER_STRING="MCUboot"
       # Step 1.1 - Configure serial recovery to use CDC_ACM, which by default uses the USB
      -CONFIG_BOOT_SERIAL_UART=y
      +CONFIG_BOOT_SERIAL_UART=n
      +CONFIG_BOOT_SERIAL_CDC_ACM=y
       # Disable console UART, since Serial Recovery uses UART
       CONFIG_UART_CONSOLE=n
      @@ -33,3 +34,8 @@ CONFIG_MCUBOOT_INDICATION_LED=y
       # STEP 1.2 - Enable USB subsystem
      +CONFIG_USB_DEVICE_STACK_NEXT=y
      +CONFIG_MULTITHREADING=y
      +CONFIG_UART_USE_RUNTIME_CONFIGURE=y
      +CONFIG_UART_LINE_CTRL=y
      +#CONFIG_USBD_CDC_ACM_CLASS=y
      \ No newline at end of file
    • Notes:
      • Deprecated USB_DEVICE_DRIVER and USB_DEVICE_STACK is enabled --> Looks wrong
      • MCUMGR_TRANSPORT_UART is disabled --> Looks wrong
      • Failure: region `FLASH' overflowed by 7908 bytes
    • Will increase bootloader Flash size, because USB Next need more from my searching
    Questions:
    • Why it is not needed to change "zephyr,uart-mcumgr" from "uart0" to "&cdc_acm_uart0" in mcuboot overlay?
      • Like later for the application.
  • Hi John,
    That is correct, usb next is not an option for the nrf5340. It will alsways select the legacy USB device stack. The kconfig to enable USB next selects only Next for nRF54 series devices
    config BOOT_SERIAL_CDC_ACM
    	bool "CDC ACM"
    	select USB_DEVICE_STACK if !(SOC_NRF54LM20A || SOC_NRF54LM20B)
    	select USB_DEVICE_STACK_NEXT if (SOC_NRF54LM20A || SOC_NRF54LM20B)
    We'll look into the exercise and double check if and what is wrong/not working for the non nRF54LM20 devices.
    Andreas
  • Hi again,
    The author agrees that a fix is required. They will make an update to the course to either highlight the different requirement for the SoCs and/or patch the issue. Resolution is TBD and depends on what is supported in the SDK tag.
    Reassigning the case to them and leaving it as open.
    Thank you for reporting this,
    Andreas
  • Attached are my working example for nrf53 on SDK 3.4.1.
    diff --git a/l9/l9_e4/prj.conf b/l9/l9_e4/prj.conf
    index 9200873..2763b9c 100644
    --- a/l9/l9_e4/prj.conf
    +++ b/l9/l9_e4/prj.conf
    @@ -1,33 +1,19 @@
     CONFIG_GPIO=y
     # Enable MCUboot
    -CONFIG_BOOTLOADER_MCUBOOT=y
     # Enable mcumgr DFU in application
    -CONFIG_MCUMGR=y
     # Enable MCUMGR management for both OS and Images
    -CONFIG_MCUMGR_GRP_OS=y
    -CONFIG_MCUMGR_GRP_IMG=y
     # Configure MCUMGR transport to UART
    -CONFIG_MCUMGR_TRANSPORT_UART=y
     # Dependencies
     # Configure dependencies for CONFIG_MCUMGR
    -CONFIG_NET_BUF=y
    -CONFIG_ZCBOR=y
    -CONFIG_CRC=y
     # Configure dependencies for CONFIG_MCUMGR_GRP_IMG
    -CONFIG_FLASH=y
    -CONFIG_IMG_MANAGER=y
     # Configure dependencies for CONFIG_IMG_MANAGER
    -CONFIG_STREAM_FLASH=y
    -CONFIG_FLASH_MAP=y
     # Configure dependencies for CONFIG_MCUMGR_TRANSPORT_UART
    -CONFIG_BASE64=y
     # STEP 5.3 - Enable USB subsystem
    index 277d0a0..e40de37 100644
    @@ -1,4 +1,3 @@
     # Add MCUboot
    index 131d953..7ca9ce0 100644
    @@ -3,8 +3,13 @@
     	chosen {
     		zephyr,code-partition = &boot_partition;
    +		zephyr,uart-mcumgr = &cdc_acm_uart0;
    +&zephyr_udc0 {
    index e736ae2..2c53899 100644
    @@ -33,3 +34,7 @@ CONFIG_MCUBOOT_INDICATION_LED=y
    +CONFIG_USB_DEVICE_STACK_NEXT=n
    From my point it could be closed.
