Why doesn't the nRF9151 support Band 71? It has excellent penetration for IoT applications. Thanks
Thanks for reaching out. There are hardware limitations due to which we don't support Band 71, I am discussing internally as well to find out if we have specific reason for it.
We support 700 MHz to 2200 MHz and 700 MHz also provide strong propagation and indoor penetration for IoT use cases. Can you tell us about your use case where band 71 is required.
Best Regards,
Syed Maysum
I would like to add that it would have a complicated RF Front End (RFFE) as well so we don't support Band 71. Thanks.
Hi Syed - Band 71 matters for healthcare IoT because reliable indoor coverage matters far more than data rate. T-Mobile’s 600 MHz spectrum improves building penetration and extends rural coverage, both relevant to hospitals and clinics. Devices often sit deep inside buildings, in pharmacies, storage rooms and equipment areas. Omitting B71 removes a useful coverage option.
Thanks for pointing it out and it has been noted. Although we don't support Band 71 for nRF91 series but we will consider and evaluate its feasibility for upcoming products.
Best Regards,
Syed Maysum
