service_changed oddity
Forgive me if there is an obvious answer to this; thanks for your patience.
I'm a long time developer but new to the area of BT in general. After a day or so starting with the examples within the 10.0 SDK, and using SD 110 V8 cleanly unzipped, I've run into a bit of a challenge.
To cut to the chase, the problem seems to be related to "handle confusion" that occurs when the service_changed flag is enabled in the gatts_enable_params.
I've reduced this to a repro outside my app. Start with a cleanly-building cleanly working "uart" example app from the SDK, and verify that it works with nRF Toolbox's UART module. (In my case I'm monitoring the serial port I/O of a RedBear Nano.) Great.
Then, at the top of main.c in the uart example, change IS_SRVC_CHANGED_CHARACT_PRESENT to 1, and rebuild. The UART app will no longer function. No serial output.
(Interestingly, though, when I use the nRF MCP, I can see the UART TX attribute changing! Just no serial output.)
After far too much debugging, it appears that there is some confusion about handles, and which characteristic is thought to be firing the ble event:
  • When operating cleanly, the value_handles for RX==11 and TX==14. When ble_evt_dispatch comes in upon data ready to be written to the UART, the evt_write->handle is 14, which is perfect.
  • When compiled with service_changed enabled, though, the value_handles assigned are RX==14 and TX==17. (I assume this is likely explained by the hidden characteristics automatically added for service_changed events.) However, when ble_evt_dispatch comes in upon data ready to be written to the UART, the evt_write->handle is 14 - which is of course wrong. It should be 17. Where the heck it got 14 is a mystery.
I've looked at the source code all the way down to the softdevice encoder, and I can't find the source of the issue; it looks as though handle values are assigned within the softdevice or elsewhere that I can't determine.
Chances are that this issue is most likely mine, but I don't see it. Guidance? Thanks
