Hi Team,
USB detection is working correctly on the nRF54L20 controller. However, the USB MSC (Mass Storage Class) implementation is not functioning as expected. The device continuously reports Bus Reset and Device Suspended events, resulting in USB storage enumeration failure.
For your reference, I have attached the UART logs. Kindly review and help identify the root cause of the issue.
Uma Maheshwar
Below are the UART logs for your reference :
*** Using Zephyr OS v4.4.2-33fa6a7aac6a ***<CR><LF>
Starting USB Mass Storage Application<CR><LF>
VBUS detection supported - waiting for USB<CR><LF>
Ready - connect USB-C cable<CR><LF>
[00:00:00.025,482] <ESC>[0m<inf> udc_dwc2: Skip pinctrl configuration<ESC>[0m<CR><LF>
03-11-2026 18:02:08.232 [RX] - USBD message: VBUS ready<CR><LF>
USB Connected<CR><LF>
03-11-2026 18:02:08.423 [RX] - Filesystem mounted at /GND_DISK:<CR><LF>
USBD message: Device suspended<CR><LF>
USBD message: Bus reset<CR><LF>
03-11-2026 18:02:09.262 [RX] - [00:00:11.556,848] <ESC>[1;33m<wrn> udc_dwc2: Experimental DMA enabled<ESC>[0m<CR><LF>
[00:00:11.556,858] <ESC>[0m<inf> udc_dwc2: Hibernation enabled<ESC>[0m<CR><LF>
[00:00:11.556,949] <ESC>[0m<inf> flashdisk: Initialize device GND_DISK<ESC>[0m<CR><LF>
[00:00:11.556,957] <ESC>[0m<inf> flashdisk: offset ad000, sector size 512, page size 512, volume size 131072<ESC>[0m<CR><LF>
[00:00:11.683,937] <ESC>[1;33m<wrn> udc: Spurious suspend event<ESC>[0m<CR><LF>
[00:00:11.720,738] <ESC>[0m<inf> udc_dwc2: Prepare RX 0x00 doeptsiz 0x60080040<ESC>[0m<CR><LF>
03-11-2026 18:02:11.868 [RX] - USBD message: Device resumed<CR><LF>
03-11-2026 18:02:15.369 [RX] - USBD message: Device resumed<CR><LF>
03-11-2026 18:02:18.869 [RX] - USBD message: Device resumed<CR><LF>
03-11-2026 18:02:21.127 [RX] - USBD message: VBUS removed<CR><LF>
USB Disconnected<CR><LF>
Filesystem unmounted<CR><LF>
