USBD Serial Basics
I'm working on an open source smart watch project https://github.com/Protocentral/healthypi-move-fw.
I'm after serial communication with another device, so I need to re-enable the usbd stack. I have successfully managed to flash new firmware with a new gui that I intend to control, but that's not particularly helpful if I can't get bi-directional communication working. It's a bit slow to work without even printf debugging as a tool. I'd appreciate any help to get me up to speed how this all works.
As for the project, it's presenting a few challenges at the moment since I'm completely new to nRF development. I was hoping to find code related to usb because there is a sensor which attaches to the usb port of this watch. However what I've discovered is that the usb stack has been specifically removed from this project and the sensor that comes with it appears to be controlled via very specific pins like an i2c device (which obviously are linked to the usb port). That's cool to know that's possible, but I'm trying to just work with the basics. I'd like to have bidirectional communication going over serial to simply things.
One immediate problem is that just enabling the usbd stack in the prf.conf actually makes the build fail because the application core is too large. I've managed to find buffers which I could shrink, I've talked with the watch's developers a little bit and they've offered suggestions like shrinking the configured heap and stack sizes, etc... I'd prefer to do things without negatively impacting the watch's existing functionality. I think I've managed to give myself just enough room to add the usbd stack back in.
So the remaining portion is just making sense of what exactly I need to do to get that usb port to act as a serial port. If anyone can offer a more specific translation of how the sample code relates to https://github.com/Protocentral/healthypi-move-fw/blob/582fc5376a4750e1c240f0ac9a189680525b3f45/app/src/hw_module.c#L549 the board configuration https://github.com/Protocentral/healthypi-move-fw/blob/582fc5376a4750e1c240f0ac9a189680525b3f45/boards/protocentral/healthypi_move/nrf5340_cpuapp_common.dtsi#L16 and the prf.conf file https://github.com/Protocentral/healthypi-move-fw/blob/main/app/prj.conf would be great. I've managed to flash the device with some modifications that don't appear to crash with the `usb_init()` function re-enabled, but I'm not getting anything back out over VS Code's serial monitor (the current interrupt handler I believe is setup to echo). So I have no clue if what I've done works at all. I have a sneaking suspicion that the "chosen" "zephyr,console" should be cdc_acm_uart0, however when I do that I get errors that `__device_dts_ord_163` is missing which from the documentation appears to be a problem of selecting a non-existent device.
Then finally, I'm not entirely sure if this is possible with this device, it would be nice if the watch could power the other device over usb. I did see configuration options and power mentioned in here: https://github.com/zephyrproject-rtos/zephyr/blob/main/samples/subsys/usb/common/Kconfig.sample_usbd
If that's related, it'd be nice to know. Part of my not being sure that this works is that the second device clearly isn't being powered by the usb port so until I sort out an alternate power source I can't verify what I've done. However since I'm not getting feedback over the serial monitor I have sneaking suspicion what I've done will not work. Any help is welcome. I have gone through some of the USBD documentation, but clearly I'm missing things in order to get this to work.
I am debugging/flashing firmware using an nRF5340 DK, specifically this one: https://www.amazon.com/dp/B0FCVL5JVT using the nRF Connect Extension in Visual Studio Code over the SWD debug out port.
  • Hi Alex,
    Thanks for reaching out. Before we help you can you clarify this. When you say the sensor is controlled “like an i2c device,” do you mean the port is just a connector carrying I2C signals?  If so, no USB protocol is involved, and enabling the USB stack won’t help with the sensor.
    Benjamin
  • Oh, so to explain, there's a peripheral heart rate sensor which has a usb-c connector. That's not the device I intend to control. What I found in the source code is that sensor seemingly works with a few gpio pins, obviously first impressions would make you think, usb-c cable, usb related things are going on. Which is not in fact the case. Unfortunately for me, the usb stack has been completely removed.
    I need serial communication, I think I'm close to getting the usb stack re-enabled and serial working, but clearly I'm missing something. The interrupt handler that's present should echo messages back (so that I can verify that it works). I'm getting nothing. I'm also somewhat working in the dark because usually with microcontrollers I have some printf debugging, but obviously since that's what's missing here. I don't know what progress if any I'm making exactly. I'm somewhat hoping someone can walk me through what I should be doing to get this to work.
    Here are the changes I've made:
    bitbucket.org/.../65f600450417e258a898f6d414ac02117cd49fbf
