nRF9151: does the 6 ms VDD_GPIO delay apply after an nRESET pin reset?
The nRF9151 hardware design guidelines (power sequence) require VDD_GPIO to be applied at least 6 ms after VDD and ENABLE, after the hardware boot. In our design a voltage supervisor drives nRESET and also, with a delay network, the EN pin of the LDO that supplies VDD_GPIO. VDD and ENABLE stay on during the reset.
1. When the device restarts from the nRESET pin (VDD and ENABLE stay on), does the 6 ms rule apply from nRESET release? That is, must VDD_GPIO be off during the reset and come back at least 6 ms after nRESET goes high?
2. If VDD_GPIO drops and returns while VDD and ENABLE stay on (no reset), what are the GPIO states after it returns – is the configuration kept, or is a reset required?
3. If nRESET is released while VDD_GPIO is still on (it was never removed), is that allowed, or does it cause the undefined GPIO states mentioned in the guidelines?
Thank you.
  • Hi Dew,
    1.
    No, that is not required. The 6 ms rule is about power-up, not pin reset.
    2.
    That is an interesting question. I would assume the GPIO configuration will be kept when VDD_GPIO go low and high again. The reason is that the register configs are powered from VDD not VDD_GPIO. You should verify this on your board. Also note that when VDD_GPIO is low while VDD and enable are high, the leakage current is high, so you should prevent this case anyways.
    3.
    This is essentially the same question as (1.), yes that is allowed.
    Benjamin
