Hello Nordic support,
We are designing a battery-powered device using the u-blox NORA-B206-00B module, based on the nRF54L15. u-blox support recommended contacting you regarding an unpowered ADC input condition.
The module is supplied at 2.5 V by an LDO. Battery voltage is measured through the following circuit:
Battery positive to ADC input: 1 MΩ, 1%.
ADC input to GND: 330 kΩ, 1%.
ADC input to GND: 10 nF.
Battery and module share the same ground.
Maximum nominal battery voltage: 4.17 V.
The divider produces approximately 1.035 V with a high-impedance input. However, the battery can remain connected while the module supply is off, so the ADC pin remains connected to this divider when VDD is nominally 0 V, including during power-down transitions.
The upper resistor limits the steady-state current supplied by the battery to approximately 4.2 µA at most, including its 1% tolerance. We understand that the actual injected current depends on the pin protection circuitry, and that the charged 10 nF capacitor may also produce a transient during power-down.
Could you please clarify:
Is this circuit permitted when VDD is off, despite the specified I/O voltage limit of VDD + 0.3 V?
Is there a guaranteed allowable continuous or transient injection current for an ADC-capable GPIO under this condition?
Could it cause back-powering, undefined states, startup problems or long-term reliability issues?
If the direct connection is not permitted, do you recommend disconnecting the battery measurement path whenever VDD is absent?
We are looking for a supported hardware solution, rather than relying solely on the current being small.
The ADC pin assignment is not yet finalized; please let us know if the answer depends on the selected pin.
Thank you for your support.
Achille
