nRF5340DK debugger failing to flash on-board SoC
nRF5340 DK PCA10095 revision 2.0.0
Probe serial 1050093769.
The onboard debugger fails to connect to the nRF5340.
It successfully programs external targets through P20.
The onboard nRF5340 is successfully programmed through P18 using an nRF54L15 DK.
Without connecting external target to P20, its SWDCLK pin produces bursts, but U5 (target selection switches) pin 3 remains low and U5 pin 15 remains high.
Tested with J-Link V9.82 and V9.96, same result.
P20 VTG measures 0.64 V unloaded and 0.28 V with a temporary 1 kΩ pull-down, without restoring onboard access.
Is there a supported way to inspect or reset the onboard probe’s target selection, or a known interface-firmware issue affecting this revision?
