Controlling a RF switch with nRF9151 and nRF93M1
We are designing a board with both nRF9151 and nRF93M1 sharing one antenna through an SPDT RF switch (Infineon BGS12PN10). The switch draws 75 µA when powered,
which is too high for our sleep budget, so we want the modems to control it directly. We have no other RF tuning in the circuit. The only purpose is to actively connect the antenna when a modem needs it, and power the switch off when it is not in use.
The nRF9151 and nRF93M1 are never enabled at the same time. Planned control: - Switch power enable: OR gate of nRF9151 COEX2 and nRF93M1 COEX0 (And a backup signal from nrf9151 host GPIO) - 100 kΩ pull-downs on COEX lines, as required in the documentation For the nRF9151, the Product Specification (section 7.2, Figure 115) shows COEX2 low in Sleep/PWROFF and high while the transceiver is on. For the nRF93M1, the Hardware Design Guide (4568_025, section 3.13) only says COEX pins float in System OFF. We could not find the pin state during System ON power-saving sleep (iDRX, eDRX, PSM with autoPowerSave enabled). Questions:
1. nRF93M1: Can COEX0 and COEX1 be configured as static outputs, independent of band, that are high when the nRF93M1 radio is active and low otherwise, including during power-saving sleep (iDRX, eDRX, PSM)?
If so, which AT command, and what is the lead time from COEX high to first RX/TX activity? If not, do you recommend an RFC pin (%RFC) instead? 2. nRF93M1: What is the COEX pin state during boot, reset and modem firmware update?).
3. nRF9151: What is the minimum lead time from COEX2 high to first RX/TX activity? We need to enable a load switch and let the RF switch settle.
4. Could you share the nRF93M1 AT Commands reference covering COEX configuration?
Best regards
Hartvik Line
Balder
