Hi Nordic Team,
I measured the cellular module power consumption on our nRF93M1 DK (Rev 0.4.0) while publishing dummy JSON data to AWS IoT Core every 30 seconds over Airtel India LTE (PPP + mTLS MQTT, NCS v3.5.0-preview5).
PPK2 Measurement Setup:
- Mode: Ampere Meter mode (
100 samples/sec), DK powered viaUSB1with LTE antenna attached - Jumper
P3(nRF54L15): Kept ON - Jumper
P4(nRF93M13.8 Vrail): Removed, wired in series with PPK2 (P4Pin 13V8→VIN, Pin 2VDD_nRF93→VOUT, Pin 3GND→GND)
Measured Results (screenshots attached):
- Overall 30 s cycle average:
~6.88 – 7.01 mA(max110 – 124 mA) - Active MQTT publish burst (
890 ms):35.77 mAavg,124.03 mAmax - RRC Connected tail (
9.67 s):8.65 mAavg,55.45 mAmax - Idle between publishes (
19.15 s,1.28 sDRX paging):4.90 mAavg,18.56 mAmax
Could you please confirm:
- Is this power consumption expected for the nRF93M1 module during AWS MQTT publishing and idle?
- Is my PPK2 measurement setup on
P4correct (or should I change anything such as the sampling rate or mode)?
Thanks & regards,
Abiram
