nRF54LM20A RSSI Issue
On our current project, we are investigating an approximately 4–5 dB lower than expected BLE RSSI reading on an nRF54LM20A-based product using nRF Connect SDK v3.4.1.
In a conducted setup with a BLE Relay peripheral, the offset remains fairly consistent across different attenuation settings. We observe a similar offset on the nRF54LM20 DK (Evaluation Board) running Nordic's Automated Power Control Central sample (modified to connect to our peripheral and report connected RSSI without automatic TX-power adjustment). Both advertising and connected RSSI show similar behavior on the EVB and our product, which reduces the likeliness that this is a circuit issue.
Our custom firmware reads connected RSSI using BT_HCI_OP_READ_RSSI, without applying an offset or averaging. The Nordic sample uses the same HCI command. Conducted TX checks have not shown any corresponding 5 dB deficit (Most likely not related to RF pathloss).
Could you advise whether a 4–5 dB offset is expected for the nRF54LM20A RSSI measurement, what reference plane/calibration applies, and whether any controller configuration or RSSI accuracy considerations could explain this behavior?
