Examples of ADC with temperature and battery voltage, SDK 10/11
Hi all, i'm trying to understand how to program my nrf51 DK in order to perform a temperature measurement with the onboard sensor, convert the battery voltage with the ADC and send it to, for example, my phone with MCP. I have read the three tutorials but now i think i need more example to understand these functions, so i looked on github but i found only a good example which works on SDK 5 or something like that, which of course doesn't work (it doesn't even advertise) when i load it on the board. Is there a way to implement it with SDK 10 or 11 and relative s110 or s130 softdevice, or have an updated code? Thanks in advance.
  • Hi Revo, I suggest you first try running one of the examples included in the SDKs to get familiar with the nRF5x framework and how to compile and run software. Don't forget that you have to program the SoftDevice first (using nRFgo Studio), and that you have to use a SoftDevice that is approved for use with your SDK version. For SDK v11.0.0, this would be S130 v2.0.0 for nRF51 and S132 v2.0.0 for nRF52. S110 and S120 are outdated and not supported anymore, they were replaced by S130.
    If you want to run a sample project that uses SDK v5 (which would be very old), you would need to use the corresponding (outdated) SoftDevice for that project.
    I really suggest getting familiar with the examples included in SDK v11 and run them on your DK:
    • An easy example would be Beacon (the ble_app_beacon) which shows how to send advertising data. You could use the main loop to periodically poll the temperature and battery voltage and update the advertising data (which you can see on MCP without establishing a connection to your BT device). Although you might have to remove the power management function call to prevent you device from sleeping and not updating the temperature and voltage values anymore. I think this would be the fastest and easiest way to send your data, especially if you're new to Bluetooth Smart / Bluetooth Low Energy.
    • A more sophisticated project would be the Heart Rate Sensor (ble_app_hrs). This implementation already implements the Battery Service Profile (BAS, see ble_bas.h). I'm not sure if the battery services currently measures the acutal battery voltage or uses simulated data, though. You could remove the services you don't need (especially the HRS) and add support for temperature measurements.
    Good luck!
  • Thanks really for your explanation. I'm really a novice and i'm still understanding the differences between the various methods to send data, in order to put together the pieces for my real project which i will do later; if i put the data in the advertising structure, i can see it without connecting and that's ok, but this way i can't store that data in the target device (in this case the phone just to try, in my future application i will need to receive with another nRF and send it to the PC via USB), correct?
  • If you want to get familiar with Bluetooth, nake sure to have a look at the Bluetooth Core Specification v4.0 or above, Vol. 03 Part C (GAP, describes Bluetooth network topology) and Part G (GATT, describes how data is represented and communicated) and maybe Part F (ATT which is a level below GATT). You can find the specification link here.
    If you can see advertising data on your target device, you can also store ist there. It depends on your implementation. On the nRF5x, you get an event each time an advertising packet is received. You must filter the advertising packets (find out if it was sent by your desired communication partner) and then you can update a local buffer with the new data. This can happen completely in background, in the event handler (on_ble_evt()), you can store the temperature and voltage in global variables (to prevent race conditions, make sure they are read/written in atomic operations, e.g. reading 16 bit in one function call, not high_byte and low_byte in separate operations) and access them from the main loop. There, you can periodically (or upon change) send them to the UART, and if you use a USB to UART converter IC or adapter cable (make sure it provides <3V signals), you can already connect it to your PC.
    Doing this while using a connection and reading GATT characteristics that contain your values is much more complicated for a beginner as you need to do proper connection handling and have complex system states due to the asynchronous GATT communication protocol.
  • Basic concept when using advertising data:
    Device 1: "Peripheral" or "Broadcaster" role (transmits data, does the advertising)
    • after advertising is started, use sd_ble_gap_adv_data_set() to update the advertising data. You can call this function from the main loop every time you read new voltage and temperature values
    • make sure that your advertising data corresponds to the official advertising data layout: Use a "manufacturer specific data" section for your data (type = 0xff), and set the company id to 0xffff. Make sure that the section length byte has the correct value (if I remember correctly it should be 7 when sending two 16 bit values after the company id).
    • also take care as 16 bit values may not be 16 bit aligned in the advertising data (which is a byte stream), so make sure your compiler doesn't add extra bytes for stuffing and that you don't use 16 oder 32 bit data access operations un unaligned memory addresses.
    Device 2: "Observer" role (receives advertising data)
    • start scanning using sd_ble_gap_scan_start()
    • receive advertising events in on_ble_evt(): if (p_event->header.evt_id == BLE_GAP_EVT_ADV_REPORT) {....}
    • write data extracted from advertising packets into global variables
    • in the main() loop, periodically check the global variables and do something with the data (e.g. send them over UART). You may use nrf_delay_ms() at the end of the loop if you don't wand to send data too fast.
