multi packets per connection interval
HI,I want to send multi packets per connection interval. I have checked some questions and thread. like thislink text and thislink text.
according to the example throughput , i think i can use the data_send function to achieve multi packets per interval.
since i am using ble_uart example, i add data_send() function and put it in while loop to send data continuously. the data_send code is as follow:
static void data_send(){
uint32_t err_code;
  int n=0;
static uint8_t data[500] = {8};
  err_code=ble_lbs_data_send(&m_lbs, data);
if (err_code != NRF_SUCCESS &&
        err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
        err_code != NRF_ERROR_INVALID_STATE &&
        err_code != BLE_ERROR_NO_TX_BUFFERS)
main function is that
int main(void){
  uint32_t err_code_uart,err_code;
  bool erase_bonds;
  uint8_t  start_string[] = START_STRING;
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS_BLE, APP_TIMER_OP_QUEUE_SIZE_BLE, false);
  uart_init();
  ble_stack_init();
  gap_params_init();
  services_init();
  advertising_init();
  conn_params_init();
    err_code_uart = ble_advertising_start(BLE_ADV_MODE_FAST);
  APP_ERROR_CHECK(err_code_uart);
	m_transfer_completed = false;
// Setup bsp module.
uint8_t data[500]={0};
	int i=0,count=1;
while(1)
           data_send();
			// ble_nus_string_send(&m_nus, data, 20);
the question is when i used data_send(); function to send data, there is no data received in MCP while when i use ble_nus_string_send function, it works.
Can anyone help?
Thank You
  • currently, i am using NRF51 dongle to receive data. it can receive up to 6 packets per interval,right. for example, if i want to achieve three data packets per interval, i just copy and past ble_nus_string_send three time,is it correct?
    uint32_t err_code;
    static uint8_t data[BLE_LBS_DATA_CHAR_LEN] = {0};
        err_code = ble_nus_string_send(&m_nus, data, 20);
        if (err_code == BLE_ERROR_NO_TX_BUFFERS ||
            err_code == NRF_ERROR_INVALID_STATE ||
            err_code == BLE_ERROR_GATTS_SYS_ATTR_MISSING)
    BTW, how can i view the number of packets per interval in MCP?
    Thank You very much
  • It really depends on how often you call data_send(). If you always have available TX buffers, then yes. If you want to see how many packets you send, you can use a ble sniffer like the nRF sniffer.. You can also use the nRF uart app for your smarthphone, and count the packets manually. This will only be possible if you set a very high connection interval though, like over 2 seconds.
