multi packets per connection interval
HI,I want to send multi packets per connection interval. I have checked some questions and thread. like thislink text and thislink text.
according to the example throughput , i think i can use the data_send function to achieve multi packets per interval.
since i am using ble_uart example, i add data_send() function and put it in while loop to send data continuously. the data_send code is as follow:
static void data_send(){
uint32_t err_code;
  int n=0;
static uint8_t data[500] = {8};
  err_code=ble_lbs_data_send(&m_lbs, data);
if (err_code != NRF_SUCCESS &&
        err_code != BLE_ERROR_INVALID_CONN_HANDLE &&
        err_code != NRF_ERROR_INVALID_STATE &&
        err_code != BLE_ERROR_NO_TX_BUFFERS)
main function is that
int main(void){
  uint32_t err_code_uart,err_code;
  bool erase_bonds;
  uint8_t  start_string[] = START_STRING;
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_MAX_TIMERS_BLE, APP_TIMER_OP_QUEUE_SIZE_BLE, false);
  uart_init();
  ble_stack_init();
  gap_params_init();
  services_init();
  advertising_init();
  conn_params_init();
    err_code_uart = ble_advertising_start(BLE_ADV_MODE_FAST);
  APP_ERROR_CHECK(err_code_uart);
	m_transfer_completed = false;
// Setup bsp module.
uint8_t data[500]={0};
	int i=0,count=1;
while(1)
           data_send();
			// ble_nus_string_send(&m_nus, data, 20);
the question is when i used data_send(); function to send data, there is no data received in MCP while when i use ble_nus_string_send function, it works.
Can anyone help?
Thank You
