UART receive in background without callback on nRF52 SDK11
Hi, I'm looking for an easy way to use the UART in blocking mode (or something similiar) with a receive buffer that is filled in background:
  • If possible using EasyDMA for better performance and easier software design
  • TX data may either block until all data has been sent or may return immediately and provide an additional function call to check if all data has been sent successfully.
  • RX data shall received in background and stored in a buffer/FIFO. It shall be possible to read data of arbitrary size from the receive buffer without stopping reception.
  • No callbacks or event handlers shall be used (synchroneous control flow in application).
In the past, on the nRF51, we used the app_uart library with FIFO support. Looking at the SDK11 documentation on infocenter.nordicsemi.com, I couldn't find any information about this library (although the directory is still there in the SDK11 archive). Is app_fifo still working on SDK11 on nRF52? Does it take advantage of the EasyDMA feature?
Looking at nrf_drv_uart.h, double buffering is mentioned to provide support for continuous data reception in non-bocking mode. But what does happen if the last received data byte does not fill the buffer to 100%? Will the driver wait for more bytes until the buffer is full, not giving any opportunity to receive data from the partially filled buffer? In other words, is there any possibility to receive "byte streams" of arbitrary length using UART with EasyDMA (something like app_uart with FIFO feature using EasyDMA)?
  • This post contains some information about the UART peripheral and example with the nRF52. See the @hungbui 's answer.
    In SDK11, two issues with the UART have been fixed:
    • UART: Fixed a glitch on TX pin when initializing the driver
    • UART: Fixed the problem that TX bytes were sent in wrong order in app_uart_fifo
    The documentation about the FIFO implementation is available in the "SDK common libraries" section, see this link. The FIFO API has a new function in SDK11.
  • I am also looking for an example of the UART with DMA. I currently use the UART with HFC on the nRF51, but unfortunately there is no DMA with the nRF51 :(
  • @metch: Do you already have a product that uses the nRF51? If not, why not moving to the nRF52 platform if you need efficient UART handling?
  • Thanks for the reply. Although, the post you mentioned doesn't give much new information. My conclusion at the moment is that it is currently not feasible to use the UART with EasyDMA in a FIFO-like scenario (receiving asynchroneous randomly sized data packets) as there is no such driver available.
    I have considered implementing a driver extension on my own. But I'm a bit short on time, so maybe I'll just continue using the old app_uart_fifo without EasyDMA.
  • I am also looking for an example EasyDNA+UART. Nrf51 lost data at high speeds without DMA. Moved to the DDK 52, but now can't understand how to automatically receive a portion of the data, if the flow is interrupted.
1 2 3 4 5
