Sending SAADC over BLE?
I am trying to combine both the SAADC and BLE libraries to be able to read a value from my sensor on the analog pin and then send it over Bluetooth LE to a central dongle.
I have experimented with the /examples/peripheral/saadc example as well as the /examples/ble_peripheral/ble_app_uart. It seems that both of these examples do what I need but separately. However, when I try to combine them I experience a lot of issues.
Firstly, copying the saadc code verbatim over to the ble_app_uart code results in the LED flashing very rapidly and the output over serial to be garbage. I have narrowed down this problem being due to the fact that the APP_TIMER and Timer0 are going at the same time.
Next, I looked at the example code in this very helpful thread: devzone.nordicsemi.com/.../
And for testing purposes added the following code to the on_ble_evt handler for the condition BLE_GAP_EVT_CONNECTED:
printf("\n\rSAADC HAL simple example.\r\n");
nrf_saadc_task_trigger(NRF_SAADC_TASK_START  );
nrf_saadc_task_trigger(NRF_SAADC_TASK_SAMPLE );
nrf_saadc_task_trigger(NRF_SAADC_TASK_STOP  );
This code resulted in UART showing me the values being captured from SAADC, but all of these values are 0.
I am at a loss here after trying to figure this out for several days now. Could anybody steer me into the right direction for accomplishing this task that seems should be very simple?
TL;DR I am trying to connect a peripheral to a central device with BLE. The peripheral will be using SAADC to read the analog input 0 and will send these values to the central device so that the central device can print it out over UART. I cannot seem to figure out how to combine the two examples given.
  • Hi Filip
    Below is an example which is a ble_app_uart example combined with the SAADC example. It is based on nRF5 SDK 11.0.0 and I have tested it with softdevice S132 2.0.0 and the PCA10040 development board.
    ble_app_uart__saadc_timer_driven.zip
    The example samples on pin AIN0/P0.02 and outputs the result both on hardware UART and transfers it over BLE via the NUS service. You can adjust the samling rate by adjusting the SAADC_SAMPLE_RATE_DIVIDER constant and you can adjust the size of the SAADC RAM buffer by adjusting the SAADC_SAMPLES_IN_BUFFER constant.
  • Hi Filip
    I don't see the example stopping after 135 events on my side using PCA10040 v1.1.0 with rev 1 nRF52832 on board. Are you using the same?
    I tried to run the ble_app_uart_c example on my pca10028 board and got it to work right away with the ble_app_uart__saadc_timer_driven example. I connect to a uart terminal program (Realterm in my case) and the output appeared to be rubbish because it was diplaying the result as ASCII characters. If changed display settings to show hex values instead, it shows the correct values. Could that be the problem in your case as well?
  • Hi Filip
