Send data on an notification event
hello everybody,
I need to send some data on the value attached with the notification:
 /**@brief Function for adding the notify Level characteristic.
   * @param[in]   p_notify        notify Service structure.
   * @param[in]   p_notify_init   Information needed to initialize the service.
   * @return      NRF_SUCCESS on success, otherwise an error code.
   static uint32_t notification_char_add(ble_notify_t * p_notify, const ble_notify_init_t *  p_notify_init)
uint32_t            err_code;
ble_gatts_char_md_t char_md;
ble_gatts_attr_md_t cccd_md;
ble_gatts_attr_t    attr_char_value;
ble_uuid_t          ble_uuid;
ble_gatts_attr_md_t attr_md;
uint8_t             initial_notification;
uint8_t             encoded_report_ref[BLE_SRV_ENCODED_REPORT_REF_LEN];
uint8_t             init_len;
// Add notify Level characteristic
if (p_notify->is_notification_supported)
    memset(&cccd_md, 0, sizeof(cccd_md));
    // According to notify_SPEC_V10, the read operation on cccd should be possible without
    // authentication.
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&cccd_md.read_perm);
    cccd_md.write_perm = p_notify_init->notification_char_attr_md.cccd_write_perm;
    cccd_md.vloc       = BLE_GATTS_VLOC_STACK;
memset(&char_md, 0, sizeof(char_md));
char_md.char_props.read   = 1;
char_md.char_props.notify = (p_notify->is_notification_supported) ? 1 : 0;
char_md.p_char_user_desc  = NULL;
char_md.p_char_pf         = NULL;
char_md.p_user_desc_md    = NULL;
char_md.p_cccd_md         = (p_notify->is_notification_supported) ? &cccd_md : NULL;
char_md.p_sccd_md         = NULL;
ble_uuid.type = p_notify->uuid_type;
ble_uuid.uuid = UUID_notify_CHAR;
memset(&attr_md, 0, sizeof(attr_md));
attr_md.read_perm  = p_notify_init->notification_char_attr_md.read_perm;
attr_md.write_perm = p_notify_init->notification_char_attr_md.write_perm;
attr_md.vloc       = BLE_GATTS_VLOC_STACK;
attr_md.rd_auth    = 0;
attr_md.wr_auth    = 0;
attr_md.vlen       = 0;
initial_notification = p_notify_init->initial_notification;
memset(&attr_char_value, 0, sizeof(attr_char_value));
attr_char_value.p_uuid    = &ble_uuid;
attr_char_value.p_attr_md = &attr_md;
attr_char_value.init_len  = sizeof(uint8_t *);
attr_char_value.init_offs = 0 ;
attr_char_value.max_len   = 26 ;
attr_char_value.p_value   = &initial_notification;
err_code = sd_ble_gatts_characteristic_add(p_notify->service_handle, &char_md,
                                           &attr_char_value,
                                           &p_notify->notification_handles);
if (err_code != NRF_SUCCESS)
    return err_code;
if (p_notify_init->p_report_ref != NULL)
    // Add Report Reference descriptor
    BLE_UUID_BLE_ASSIGN(ble_uuid, BLE_UUID_REPORT_REF_DESCR);
    attr_md.read_perm = p_notify_init->notification_report_read_perm;
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&attr_md.write_perm);
    attr_md.vlen    = 0;
    init_len = ble_srv_report_ref_encode(encoded_report_ref, p_notify_init->p_report_ref);
    attr_char_value.init_len  = init_len;
    attr_char_value.init_offs = 0;
    attr_char_value.max_len   = attr_char_value.init_len;
    attr_char_value.p_value   = encoded_report_ref;
    err_code = sd_ble_gatts_descriptor_add(p_notify->notification_handles.value_handle,
                                           &attr_char_value,
                                           &p_notify->report_ref_handle);
        return err_code;
    p_notify->report_ref_handle = BLE_GATT_HANDLE_INVALID;
return NRF_SUCCESS;
it works with me, but I have a problem the data size is variable, I need to change the maximum value of attribute : attr_char_value.max_len = 26 ;
to be able to send data without the garbage, otherwise I need a way not to send this garbage data :) :)
