I don't know how to handle not-use pins for safety.
There are 31 io pins on nRF51822. I use 8 io pins for our product. But I don't use the other pins.
All of io pins have the same default value after reset as follows.
・Configure pin as an input pin ・Disconnect input buffer ・No pull
In many cases , it is necessary for circuit's safety that the input pins have to be fixed their logic level(H or L) by using external or internal pull up/pull down registers.
In this case what should I do for the not-use pins. If I do nothing for not-use pins (I mean they hace no external or internal pull up/pull down registers), what troubles will happen?
