hello there i have one nrf51 and other nrf52 kit. can we do i2c communication between these two microcontrollers??
The nRF51 supports TWI master, while nRF52 supports TWI master and slave. So yes.
Yes. The nRF51 can be a TWI master, the nRF52 has both TWI master and TWI slave peripherals. So you can make the nRF51 the master, the nRF52 the slave and run communications between them.
You could also communicate with SPI between the two of them.
thanks. but in i2c we require slave address. can you tell me what is 7 bit slave address of nrf52??
Whatever you like. Read the TWI Slave section in the manual which lists all the registers and things you can configure. The nRF52 slave will even answer to two different slave addresses if you like.
