Queries in IPv6 of COAP server
I am trying to run the coap ipv6 based example code provided in nRF51 IOT SDK. I am using my Linux PC along with a BLE adapter as a BLE enabled router. I can successfully connect to the COAP_SERVER. But the problem is I cannot access the server with coap cu mozilla plugin. Whatever I do it says "Host is unreachable".
After the connection is established, following is the output of my ifconfig bt0:
bt0 Link encap:UNSPEC HWaddr 5C-F3-70-FF-FE-6D-E4-BD-00-00-00-00-00-00-00-00
inet6 addr: 2001:db8::5ef3:70ff:fe6d:e4bd/64 Scope:Global
inet6 addr: 2001:db8::7176:1801:a1b5:acd8/64 Scope:Global
inet6 addr: fe80::5ef3:70ff:fe6d:e4bd/64 Scope:Link
UP POINTOPOINT RUNNING MULTICAST MTU:1280 Metric:1
RX packets:1 errors:0 dropped:0 overruns:0 frame:0
TX packets:16 errors:0 dropped:0 overruns:0 carrier:0 collisions:0 txqueuelen:1
RX bytes:28 (28.0 B) TX bytes:803 (803.0 B)
As can be observed from the output the MAC address of my dongle is 5C-F3-70-FF-FE-6D-E4-BD. So the first and the third inet6 addr (as can be observed from the output) has to be the global and link local address for my dongle. I understand the remaining inet6 addr (i.e. the second one) has to be of the COAP_SERVER. Now,
  1. Is my understanding about inet6 addr of the COAP_SERVER correct?
  2. If yes, then why does it not resemble in any way to the MAC Address of the COAP_SERVER ( 00:7D:43:62:4F:27 is the MAC address as observed during scanning)?
  3. Assigned router prefix is : 2001:db8::/64
    MAC address is: 00:7D:43:62:4F:27
    So the manually generated global inet6 addr must be: 2001:db8::27d:43ff:fe62:4f27
    Is this correct?
  4. I have used the address observed in output of ifconfig (the second inet6 addr) as well as the one generated(manually) from the MAC address in coap cu client, but none of it seems to work. What can be the reason?
Any help would be appreciated.
NOTE: I am running the coap cu plug in on same PC which is acting as BLE enabled router
Chirag
