Pstorage and NUS not working together
I have a project that uses PStorage and the Nordic UART Service. PStorage is used to store a variable that is updated by the device, irrespective of the Bluetooth, and needs to be sent over the NUS when requested. Without using PStorage, the application works perfectly. However, the variables are lost on reset which is not ideal.
The steps taken to reproduce the issue are as follows:
  1. Initialise PStorage
  2. Initialise BLE (Device Manager is initialised here as well. PStorage is NOT initialised again)
  3. Initialise Peripherals + Register PStorage
  4. Connect to Device via BLE
After connecting to the device, the device will respond to one or 2 commands that do not utilise the PStorage before freezing. On freezing, the only way to start the code again is to restart the device.
In the debugger, app_error_handler is never called and the wdt never times out. However, the device is unresponsive.
Any help would be much appreciated. I am using SDK10, SD8.0.0 on the nRF51822.
EDIT 1:
Attached are my header and C file for the pstorage functions.
pstorage_custom.c
pstorage_custom.h
EDIT 2:
Please find attached an example project that proves the incorrect functionality. The while loop at the end of the pstorage_custom_init() function never ends.
Pstorage-Issues.zip
  • The events from the SoftDevice, both BLE and system events (for pstorage), are run in NRF_APP_PRIORITY_LOW(3) context. You are calling your pstorage functions in this context and you have a while where you are waiting for the flag to be cleared. The flag is cleared by a system event that is run in the same context, so it will not interrupt your while, and thus the flag will not be cleared. Try running your pstorage functions from main context instead. For example set a flag in nus_data_handler() and in your main loop:
    // Enter main loop.
    for (;;)
        if(write_flag)
            	pstorage_custom_read(BLOCK_1, &custom_data);
                custom_data += 1;
                pstorage_custom_update(BLOCK_1, &custom_data);
                write_flag = 0;
        power_manage();
