Hi
nRF51 dongle is no response from master emulation. I already did erased and flashed again few times but still not resolve.
I'm also restart my PC as well but the issue still there. Kindly advice.
Hi
Could you try to test the PCA10031 with UART example and a terminal on PC ? You can use the UART example in our SDK.
Hi
Regarding UART example for PCA10031, the curent SDK11 is not working. I tried with SDK10 for UART example and it's working.
Found out that, the MCU firmware caused the no response issue on this. I reflashed back the bootloader and master control panel is working.
Hi hs, Could you confirm that you fixed the problem and now can use Master Control Panel and the PCA10031 as the radio backend for MCP ?
I just tried the uart example from SDK v11 on my PCA10031 and it worked well.
Yes. I'm able to use the Master Control Panel now. I just reflashed back with J-Link OB-SAM3U128-V2-NordicSemi 160212.bin. The issue solved.
