About a procedure with UART as disable
Because of the power-saving support, I want to disable the UART before Call the sd_app_evt_wait().
I referred to two following sites to know the procedure of the case. 1.https://devzone.nordicsemi.com/question/5186/how-to-minimize-current-consumption-for-ble-application-on-nrf51822/?answer=5187#post-id-5187
2.https://devzone.nordicsemi.com/question/1119/handling-the-uart-when-sleeping/
However, there is for difference at the point that execute the following code when disable does UART in a procedure written as 1 to 2.
// Set TXD, RXD, CTS, RTS as high outputs
// Alternatively use NRF_GPIO->PIN_CNF to set pull resistors
NRF_GPIO->DIRSET = (1 << UART_TXD_GPIO) | (1 << UART_RXD_GPIO) | (1 << UART_RTS_GPIO) | (1 << UART_CTS_GPIO);
NRF_GPIO->OUTSET = (1 << UART_TXD_GPIO) | (1 << UART_RXD_GPIO) | (1 << UART_RTS_GPIO) | (1 << UART_CTS_GPIO);
As a result of having tried each procedure, I became able to reuse UART in 2 procedures, but UART did not become reusable in 1 procedure.
When disable does UART, is it right to perform in a procedure listed in 2?
  • Hi satokato,
    Are you using simple_uart code? In procedure 1) the code is changing the pin directions when disabling but not setting them back to their usable state when you have to re-use UART again. I do not think you need reset the GPIO direction as that will not change power consumption.
    The code in the procedure 2) simple_uart_putstring which starts UART when needed to transmit and stops when last byte is transmitted is perfect. simple_uart_put will make sure that the it waits until the byte is transmitted before stopping the the uart.
    But the given solutions were only for TX, That will keep RX ON all time. If you want to toggle RX also then you can do like below
    uint8_t simple_uart_get(void)
        NRF_UART0->TASKS_STARTRX = 1;
        while (NRF_UART0->EVENTS_RXDRDY != 1)
            // Wait for RXD data to be received
        NRF_UART0->EVENTS_RXDRDY = 0;
        NRF_UART0->TASKS_STOPRX = 1;
        return (uint8_t)NRF_UART0->RXD;
    Note that if you switch RX on as you need, then you need to know when the peer device will transmit else you this device might be sleeping with RX off when the other device sends byte and it will be lost.
  • I think it should work OK. I think we can now mark this case as accepted by clicking the gray circle with ✓
